Acer 390Hz monitor - XV252QF
bigmanucks
Post by bigmanucks » 19 Aug 2022, 09:21
So the recommended route, if you can achieve 390 fps consistently, is overdrive extreme + vrb extreme?
Also, why does rtings recommend overdrive normal to extreme?
ysenojftw
Post by ysenojftw » 20 Aug 2022, 19:53
Are the colors better on this monitor then my current 360hz Alienware? Was thinking of upgrading not sure if it’s worth or not.
Francopolo
Post by Francopolo » 21 Aug 2022, 12:23
Will the blur busters strobing utility ever support this monitor? I'm sure we'll be able to get much better image clarity if we can tweak the timings ourselves.
cartoon
Post by cartoon » 22 Aug 2022, 23:09
Refull wrote: ↑
15 Aug 2022, 23:36
Ravannok wrote: ↑
11 Aug 2022, 07:36
Hi again.
My monitor arrived today and i have one problem. I turn on the oc in the monitor settings, SO 390hz would be avaliable. But in Windows i can choose max 360:/ anyone knows why? Is my old gpu a problem (rx580 8gb)? What can i do to make it work?
i had to change to a nvidia gpu because of this , even with the rx6600 xt just 360hz was available , acer support...
so about this, i actually managed to get 390hz when i used AMD by downgrading to a really old AMD driver, i cant remember which version but it was somewhere here
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 26 Aug 2022, 09:06
Kacperek
Post by Kacperek » 30 Aug 2022, 22:53
Hi!
I am looking for an high-end DP cable for this monitor, the one that came with it isnt the best.
What cable brand do you recommend? Money is not an issue, i want the best quality i can get
Hekavan
Post by Hekavan » 01 Sep 2022, 09:39
BTRY B 529th FA BN wrote: ↑
26 Aug 2022, 09:06
tl;dr wait, did you guys enable the overclock feature on the monitor to enable 390Hz?
The 390hz is basically overclocked frequency so yes you need to enable the oc from the monitor menu
brandyn
Post by brandyn » 06 Sep 2022, 14:05
Hi, so I get the black flicker problem with the default cable and an amazon basics DP 1.4 cable so i'm using 360hz, my screen also goes black if i move the cable with my foot by accident- i was wondering if a different cable would fix both of these issues for me? I'm in the UK so recommendations have to be EU based. I was wondering if OD is better on normal or extreme for 360hz? I know that normal is recommended for 390hz but what about 360hz? is extreme fine?
Crazyness
Post by Crazyness » 06 Sep 2022, 15:37
if any1 still have manual that comes with monitor ..
pls post the official timings from the manual..it would be great.
every possible timings 240hz 360hz 390hz..etc
tnx in advance
woodyfly
Post by woodyfly » 09 Sep 2022, 19:23
Monitor arrived today with the screen smashed. So dissapointing. Never had this happen
