gideonmontes
Post by gideonmontes » 07 Jun 2025, 05:50
Guys, try limiting EEE Max Support Speed ​​to 10 Mbps.
Here's what people write about this setting on the Internet: EEE max support speed usually indicates the maximum network speed (e.g. 1 Gbps or 10 Gbps) up to which EEE technology can be applied. For example, if you have a switch with EEE functionality and its "EEE max support speed" is 1 Gbps, this means that EEE can only be activated on networks with a maximum speed of up to 1 Gbps.
Now let's imagine that we have a network device, such as a switch, and its specifications specify a parameter called "EEE max support speed". If this parameter is, for example, 1 Gbps, this means that EEE will only work on this device for networks where the maximum speed does not exceed 1 Gbps. If the network is running at 10Gbps, EEE will not be activated and the device will operate at full power without turning on power saving mode.
Wherever I look at various video settings, for some reason everyone always recommends setting it to 1 Gbps or more.
1
Снимок экрана 2025-06-07 155010.png (22.87 KiB) Viewed 21413 times
Kal
Post by Kal » 07 Jun 2025, 12:08
gideonmontes wrote: ↑
07 Jun 2025, 05:50
do you have anything for realtek wifi drivers?
gideonmontes
Post by gideonmontes » 08 Jun 2025, 00:25
No, I have a wifi module from Intel installed.
In general, I fixed the floating mouse by installing all the drivers from AMD (chipset), and the desynchronization by changing the EEEMaxSupportSpeed ​​setting to 10 Mbit/s, thereby disabling the energy-saving function. Now they are constantly trying to kick me from the cs2 server.
1
Снимок экрана 2025-06-08 102227.png (58.15 KiB) Viewed 21323 times
gideonmontes
Post by gideonmontes » 08 Jun 2025, 00:35
I installed the driver from here: C:\Program Files (x86)\AMD\Chipset_Software, by running the shortcut "AMD_Chipset_Drivers", and also additionally installed all the drivers from here: C:\AMD\Chipset_Software\Packages\IODriver
I don’t know, but perhaps Intel has the same folders, I gave my 10700kf to my wife’s father, I’ll check when I get there.
2
Снимок экрана 2025-06-08 103321 222222222222.png (76.25 KiB) Viewed 21317 times
1
1
Снимок экрана 2025-06-08 103252 111111111.png (48.96 KiB) Viewed 21317 times
JimCarry
Post by JimCarry » 08 Jun 2025, 01:58
08 Jun 2025, 00:25
1.you have realtek 2.5gb on board nic right ?
2.can you post your whole pc parts
3.what version is your nic driver,because when i was using on board nic i was with the same but i did not have that option
4.can you open powershell and type this: "get-netadapteradvancedproperty" and post the results here?
gideonmontes
Post by gideonmontes » 08 Jun 2025, 02:27
1. Yes, that's right, it's an integrated network card.
2. 7800x3d, rtx 3070, 32GB RAM (6400), benq xl2411p, gigabyte b650 aorus elite ax v2.
3. Version 1125.25.20.2025 from 04/23/2025. The driver was downloaded from the official Realtek website.
1
Снимок экрана 2025-06-08 122629 4444444444.png (218.6 KiB) Viewed 21299 times
JimCarry
Post by JimCarry » 08 Jun 2025, 04:43
08 Jun 2025, 02:27
thanks i am using usb nic right now,but i also have on board 2.5gb realtek but on asus mb,and when i install last driver from realtek site.i did not have so much options like you,so you are saying you only need chipset drivers,and to change EEE Max Support Speed ​​to 10 Mbps ?
gideonmontes
Post by gideonmontes » 08 Jun 2025, 05:00
That's right, I didn't change anything in Windows 11, I just turned off some personalization settings.
ablemor
Post by ablemor » 08 Jun 2025, 05:02
maybe its placebo... drivers fix ur floaty mouse? I dont think
gideonmontes
Post by gideonmontes » 08 Jun 2025, 08:36
ablemor wrote: ↑
08 Jun 2025, 05:02
I don't have a feeling that "IT SEEMS" it got better, I feel that "IT BECAME" better. I understand, placebo, I have deceived myself many times, but not this time. I just decided to share information on this forum, maybe it will help someone too. In any case, this is not a change in registry settings, but just a chipset driver that should be installed anyway and one network card setting.
