The full path to fix the problem.
naporitan
Re: The full path to fix the problem.
Post by naporitan » 16 Oct 2025, 09:28
This is what happens if you connect two devices to one USB controller: the polling rate is unstable.
IPI Aurora65 8khz Keyboard
Wlmouse Ying (red) 8khz Mouse
Hyote
Post by Hyote » 16 Oct 2025, 18:09
I used to be skeptical about reverting to default settings but after much trial and error I have to agree with the comments above. Hardware and software engineers make things in a way so they work out of the box. It is only a human conception that settings related to power-savings, higher performance and less resource usage provide benefits over the optimized defaults.
There are a few more overlooked details, that I'm going to share one now:
1. Removing protective film from PC case
They are added for obvious reasons: to protect the devices from dust and also to filter EMI, so do not remove them under any circumstances.
This is yet another mistake contributing to worse conditions.
naporitan
Post by naporitan » 16 Oct 2025, 18:31
Hyote wrote: ↑
16 Oct 2025, 18:09
no.
ablemor
Post by ablemor » 16 Oct 2025, 18:35
I deliberately left the film on the glass panel, but I removed it recently no change.
Hyote
Post by Hyote » 16 Oct 2025, 19:22
Not sensing the irony, we truly are living through dire times.
naporitan
Post by naporitan » 16 Oct 2025, 22:05
:idea: Always buy a monitor from Benq Zowie or Alienware, these monitors have drivers to interact with the OS and have better performance.
:!: I have a 240hz aorus monitor and this monitor does not have a driver and it has scaling issues.
This monitor has the ability to update the firmware, but this does not help to fix the problems.
That is, I set gpu scaling, and the monitor doesn't interact with it correctly.
Lev1n
Post by Lev1n » 17 Oct 2025, 00:27
naporitan wrote: ↑
14 Oct 2025, 04:32
Lev1n wrote: ↑
14 Oct 2025, 03:21
this is cant be real. I have 40 ping to eu servers and game is .5 second delayed.
Post a real time recording not a demo.
Thats the delay im talking about. Its just your enemys are bad.
naporitan
Post by naporitan » 17 Oct 2025, 00:53
Lev1n wrote: ↑
17 Oct 2025, 00:27
naporitan wrote: ↑
14 Oct 2025, 04:32
Lev1n wrote: ↑
14 Oct 2025, 03:21
In that case, buy a 14900ks, remove all limits, cool it with a chiller, and move to a location where the game servers are located. Play with 0 ping and 1000 FPS. This way, you'll get 1 ms of input lag.
joseph_from_pilsen
Post by joseph_from_pilsen » 18 Oct 2025, 08:02
14900KS is not a best cpu for cs2 for a looong time...
But your advice wont work, not your latency to the server but to your opponent matters. If your opponent sits behind lagcompensated 100ms ping wall, you will never have good input vs him which makes high pingers extra annoying. You dodged as fast as he started peeking in your client? Nah, in his you client you didnt even move. You fire back? Not in his client...
Post by Slender » 18 Oct 2025, 09:12
if you find 2546s take it guys, it was like crt on 800x600 1024x768 display scaling. Best monitor.
