Input lag and eSport. Every gamer should know this.
Locked
nuggify
Re: Input lag and eSport. Every gamer should know this.
Post by nuggify » 14 Sep 2020, 14:58
Mylliah wrote:
14 Sep 2020, 04:26
I have been having stuttering, mouse inconsistencies, etc for a while, after searching and testing a lot of fix, what helped me the most was:
1)Aulterra Whole House USB https://aulterra.com/product/whole-house-usb/
Having 10 of them on my computer, 2 of them on my monitor, 1 on my modem, 5 of them on my Cyberpower UPS (2 through the usb port, 3 from the standard power outlet of the ups with usb adapter), 18 of them on my electrical network with adapter.
It has no downside except the price!
2)Greenwave Dirty Electricity https://greenwavefilters.com/ https://www.amazon.com/Greenwave-Dirty- ... B01M5C90XV
Have some but can't use them because it dissipate the dirty electricity it filters around the filters so you have to put the filters far away from conductive materials, and I don't have room to use them so because everywhere I have outlet, there's either metallic pipe, heater, washing machine, modem, computer, but I link it because, seeing the comment on amazon, it seems very effective when you can use them.
3)Removed most of the conductive materials from my home that I could & all the useless thing from inside the computer (like cable audio cable going to the front I/O of the case that I don't use ) or changing my SATA SSD to M2 NVME SSD so there's no more cable!
4)I make sure that most of the cables are shielded, and you should look for the best shielding you can, like the Ugreen TRIPLE shielding display port. https://www.befr.ebay.be/itm/Ugreen-DP- ... 2749.l2649
5)I make sure that my computer use the less watt It can, I saw that the most watt my computer use, the more the stuttering, the mouse inconsistencise are strong! So I change CPU,GPU each generation for better performance by watt, and lock my fps at 60/100hz (100hz for when I use DYAC) @1080p and use tweak to reduce heavily input lag so 60Hz become acceptable!
6)Make sure that your GPU has a backplate that have the less holes you can find in it, the backplate act like a shield, and so reduce the upper part component like cpu & ram electromagnetic radiation to interfere with the gpu and lower parts of the motherboard.
Card like https://www.omgpu.com/wp-content/upload ... te-top.jpg is a card that I would tell you to ABSOLUTELY STAY AWAY!!!
7)All wireless controller emit wifi/bluetooth, and so the wireless frequency goes through the cable, and through all the component inside your computer and create interference, either use a wired controller like the 360 if you want to use a controller, or find a way to disable the wireless component of the controller.
8)The cable must be the minimum length, make sure all of you cable touch themselves the less possible. Do not wrap the cable!
9)Make sure your monitor, computer case are far away from each other!
10)Make sure you deactivate all the useless thing you don't use in your motherboard!
11)I've put aluminium on my case, and grounded it, my monitor stand is grounded too.
12)Some might say it's quack, but I use shungite pyramid at key position, like between my monitor and my case, between the monitor and the keyboard, between the heather and the computer, it reduce issues for me!
Each of these point made the issues less and less strong, like by 70% with all those points combined.
The only thing that left me to do is to move out from my actual home because it is too polluted, even if you filters all the dirty electricty, your case, monitor, cable (even shielded) act like a conductor for the wireless, and it goes through the computer and create interference...
By the way, sorry for my english, I'm belgian!
Hope it will help people that have theses issues! :)
The fact you use a shungite pyramid shows how objective you are with your results. Look I fully realize how crazy this issue can make you but half the things you wrote on here do not even make sense from a logical position. Anyway this problem is not caused by EMF or anything like that which is what a lot of the stuff you wrote about affects. I have tried at least half of the things you wrote and they are only temporary changes as far as the problem is concerned (it will come back). Trying to quantify it like saying its "70%" better is absurd too, when the issue itself changes drastically by the hour.
Mylliah
Post by Mylliah » 15 Sep 2020, 00:25
nuggify wrote:
14 Sep 2020, 14:58
It change by the hour because of the electricity and wireless usage around you...
I live in an appartment that has an elevator, the issues goes up everytime it is used.
Everytime people goes out to work in my appartement, the issues attenuate since they leave with their phone and don't use their electrical device, but at dawn, when people come back, it become worse...
The issue is caused by all the electric and wireless usage in your environment, so of course it change by the hour...
I've worked for this for two years by now, I know what I'm talking about, there was a thread on nvidia forum where people noticed exactly the same that I did, it is factually caused by electromagnetic interference and dirty electricity.
Unixko, I'll do picture later in the day.
Unixko
Post by Unixko » 15 Sep 2020, 02:40
Mylliah wrote:
15 Sep 2020, 00:25
nuggify wrote:
14 Sep 2020, 14:58
ok sir but crucialnugg is here for more then 5 years with this problem and he trying to find core of this issue no just reduced this symptoms which is usually not working at all
Mylliah
Post by Mylliah » 15 Sep 2020, 03:03
Unixko wrote:
15 Sep 2020, 02:40
Mylliah wrote:
15 Sep 2020, 00:25
nuggify wrote:
14 Sep 2020, 14:58
Here is a link of all the Aulterra whole house usb/plug pictures I took and how I use some of those on my network/computer/back-ups/monitor/modem:
https://imgur.com/a/wpO9ciF
The best way to fix this issue in my humble opinion, is to get out of the city and find a safe spot to have the less wireless interference possible, and then filter the dirty electricity left if you still have some of those issues, & shield every cable!
Reminder too that your computer case is not a faraday cage (it should be), and there are wireless signal coming in making interference.
Like my define R5 has some plastic parts on some of the side, and where the air must go through!
Every part of where the air must go through should be placed aluminium grid on, and no more plastic part on side of the casing.
The pc casing standard should be redesigned as faraday cage before aesthetic and easily able to be grounded!
Unixko
Post by Unixko » 15 Sep 2020, 03:17
Mylliah wrote:
15 Sep 2020, 03:03
Unixko wrote:
15 Sep 2020, 02:40
Mylliah wrote:
15 Sep 2020, 00:25
nuggify wrote:
14 Sep 2020, 14:58
so you have all this filters everywhere and you still have this problem yes?
nuggify
Post by nuggify » 15 Sep 2020, 03:31
Mylliah wrote:
15 Sep 2020, 03:03
You are making the mistake of not realizing this problem is an anomaly and not normal behaivor. Normal levels of wireless interference etc do not cause this issue. Most places in cities will never have this issue. The cause of this issue is external to our homes although the symptoms may make it seem like it is your devices causing the issues. Hence you can turn off and take all of your devices away, or run just a single circuit super minimal and the issue will still be there in its entirety.
axaro1
Post by axaro1 » 15 Sep 2020, 03:42
Unixko wrote:
15 Sep 2020, 03:17
He is unironically getting scammed, 80$ for each USB from a company that sells anti-EMF supplements and "energy pillows".
The only thing missing is the tin foil hat, judging by the amount of usb he has I wouldn't be surprised if he was actually tied to that company and his job is to sell this shit.
AND IN FACT
He has 2080$ worth of that USB crap, I looked around on the site and there's some sort of "affiliate selling program", this is a fucking MLM:
The Standard Affiliate Program is for those interested in online marketing, driving retail purchasers to the Aulterra website and is FREE to join. Standard affiliates are focused on marketing to end consumers. In return for your marketing activities, Standard Affiliates receive 25% commission on all retail purchases of buyers you send to our site. You will be provided with a multitude of banners embedded with your link that you can place on sites and social media. With these tools, driving traffic and making commissions will be a simple process.
I wish he would open up one of these USB so we can all make a good laugh out of what's inside (assuming there's some sort of PCB :lol: )
̶[̶b̶]̶[̶s̶i̶z̶e̶=̶2̶0̶0̶]̶W̶h̶e̶r̶e̶ ̶a̶r̶e̶ ̶t̶h̶e̶ ̶m̶o̶d̶s̶?̶ ̶@̶C̶h̶i̶e̶f̶B̶l̶u̶r̶B̶u̶s̶t̶e̶r̶s̶ ̶c̶o̶u̶l̶d̶ ̶y̶o̶u̶ ̶p̶l̶e̶a̶s̶e̶ ̶b̶a̶n̶ ̶M̶y̶l̶l̶i̶a̶h̶ ̶[̶/̶s̶i̶z̶e̶]̶[̶/̶b̶]̶
The last thing we need in this forum is shungite and energy pillows.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
nuggify
Post by nuggify » 15 Sep 2020, 04:03
axaro1 wrote:
15 Sep 2020, 03:42
AND IN FACT
From the rules: No classified ads, no buy/sell/trade ads.
With all do respect, Mylliah is a person with an incredibly difficult to diagnose technical issue that I and many others here experience. This problem is much more complex than you can imagine. Mylliah while misguided on what the cause is, is just trying to offer their experience to alleviate the issue. Now while those filters are what I believe to be a scam, that does not mean they are not actually affecting the issue. They probably employ some type of high pass filtering on a certain frequency. I personally do not think Mylliah is trying to sell that device and thus they should not be banned. I completely agree about the shungite though.
Speaking to Mylliah saying the PC should be a faraday cage. I do not believe this issue is a result of radiated interference although I once did. I came to this conclusion through the fact that unplugging my Online UPS and running off battery fixes the problem entirely (instantaneously) and the PC works properly. This would imply the interference (likely harmonic distortion) is conducted and not radiated. Others have observed the same by running their PC via portable gas generator not connected to the AC mains.
I currently believe that the reason it seems that other devices are affecting the problem is because they are imposing some differences on the harmonic distortion. When other devices draw current they will thus change how the issue manifests. Now whether it is a problem of power factor, or just current harmonic distortion, or some indirect affect such as overloading the neutral conductors- I am not sure. We should have more data soon, as a few more of us have purchased oscilloscopes to observe our AC sinewave and the THD.
Mylliah
Post by Mylliah » 15 Sep 2020, 04:16
Unixko wrote:
15 Sep 2020, 03:17
Mylliah wrote:
15 Sep 2020, 03:03
Unixko wrote:
15 Sep 2020, 02:40
Mylliah wrote:
15 Sep 2020, 00:25
Yes, it became acceptable, but not perfect, I'll have to move out, it was literraly unplayable before all of this, that's why I spent 3000€ on those...
axaro1 wrote:
15 Sep 2020, 03:42
Unixko wrote:
15 Sep 2020, 03:17
AND IN FACT
Did you try those usb key before saying it's scam?
The link I provided is devoid of affiliation, I just copy pasted the link after searching Aulterra.
Your post is pure defamation, you didn't try the USB key and say it's scam, and not only that you say I'm part of Aulterra affiliate selling program, without providing a link that show the link I provided is part of this program.
If the mods have issues with this, they can edit my post to remove the link to remove any doubt against me.
They work to attenuate the issues. IT'S A FACT.
Check the amazon product page of those keys, 80 ratings, 4 stars, you think it would have 4 stars if it was a scam.
If you live in a country where there is a right of return if you're not satisfied, I would suggest you to try, and return if you're not satisfied!
nuggify
Post by nuggify » 15 Sep 2020, 04:26
Mylliah wrote:
15 Sep 2020, 04:16
And again you are assuming that everyone will have the same experience. However this is not a problem everywhere. Most people will never experience this issue at all. I do believe you when you say those devices attenuate the issue to a certain degree- I have seen it myself with power conditioners, UPS systems, ferrite and toroid cores, isolation transformers and many other things that affect the electrical harmonics of our AC power systems. The problem is none of this is a true fix because we haven't been tackling this issue at the source, or in the least directing our mitigation techniques in the right direction: harmonic distortion, NOT EMF.
Locked
