mawi
Post by mawi » 18 Jul 2026, 19:06
tsarri wrote: ↑
18 Jul 2026, 17:36
Has the new update broken anything with Pulsar?
The first one (1.1.4) did... but the latest 1.1.8 is clearly the best. Go for it.
kevsei
Post by kevsei » 19 Jul 2026, 08:47
BLooDS_inc wrote: ↑
02 Jul 2026, 02:07
On the Msi monitor sleep bug going out, now pulsar working after sleeps well, but borderless bug in pubg stays here, when u get 2 monitors, and u set borderless mode ingame, pulsar stops working and monitor osd shows 144 fps(my 2nd monitor hz cap) instead of 342 that stays ingame(342 rtss cap), and gsync stops working too.
Trying the 60hz and 120hz modes, on 60hz in 10 width(the minimum u can set) flicker is very minor and u can use it, on 120 hz i don t see any flickering at all.
And now the GENERAL problem of this modes - if u use pulsar with 360hz ingame, and u wanna set 60 or 120hz modes, u cant do this fast, u need to change hz of monitor, turn off gsync, its so annoying idk, every time doing this, if u can get some BUTTON in nvidia APP that 1click turn on 60hz ulmb2 or 120hz ulmb2 and reverse 1click turn 360hz PULSAR it will be so good, but now, i dont wanna every time go in to the settings and set this changes over and over
Hey, I had the same problem. Try switching the ports on your graphics card (switch all DP-Ports on your GPU). It seems like one port is preferred for G-Sync.
liquidshadowfox
Post by liquidshadowfox » 20 Jul 2026, 07:31
WiZZard46 wrote: ↑
18 Jul 2026, 15:47
I like this a lot. I'd make just a few changes to improve readability and make it sound a bit more natural to an audience of technically minded people. I also removed one or two repeated ideas and slightly softened the wording so it invites discussion rather than sounding like a bug report.
Hi everyone,
I'm hoping someone here might have an idea because I've been investigating this issue for almost two months, and at this point I'm honestly running out of things to test.
My monitor is an ASUS ROG Strix Pulsar XG27AQNGV, still running the factory firmware MCM101.
The monitor itself works perfectly (360 Hz, G-SYNC Pulsar, HDR, etc.), but I cannot update the firmware using NVIDIA's official G-SYNC Pulsar Firmware Updater. As soon as I click "Allow browser to connect", it immediately reports:
"No compatible devices found."
So far I've ruled out pretty much every user-side variable I can think of:
Two different Windows 11 PCs
Two different NVIDIA GPUs
Google Chrome and Microsoft Edge
The original ASUS USB 3.0 Type-B upstream cable
A second brand-new USB 3.0 Type-B cable
Multiple motherboard USB ports/controllers
Linux Mint Live USB (same behavior as Windows)
The most interesting discovery came after comparing my monitor with another XG27AQNGV owner (huge thanks to @rexbinary for taking the time to help).
Immediately after entering Firmware Update Mode:
His monitor:
Enumerates as ASUS XG27AQNGV
VID 0B05 / PID 1D67
Exposes a DFU (Device Firmware Upgrade) interface
My monitor:
Remains ROG Gaming Display Aura Device
VID 0B05 / PID 1C2C
Never exposes the DFU interface
Even under Linux Mint, the monitor still enumerates as VID 0B05 / PID 1C2C, which makes me believe this isn't related to Windows, browser permissions, drivers, or WebUSB.
From everything I've observed, it looks like my monitor never actually re-enumerates into DFU mode, even though the OSD clearly displays "Firmware Update Mode." If that's the case, it would also explain why the NVIDIA updater immediately reports "No compatible devices found."
I already have an engineering escalation open with ASUS, but it's been almost two months and I'm still waiting for their response.
One thing that has also confused me is NVIDIA's firmware update page, which mentions using a Micro-B USB cable. The XG27AQNGV, however, uses a USB 3.0 Type-B upstream connection for normal PC connectivity and also has a separate connector labeled "For service only." Since ASUS doesn't document that connector as a user firmware update port, I've intentionally avoided using it until I receive clarification from their engineering team.
So I have a couple of questions for anyone who owns this monitor:
Has anyone with an XG27AQNGV successfully updated the firmware? If so, which physical USB connection did you use—the standard USB 3.0 Type-B upstream port, or the separate "For service only" connector?
Has anyone ever seen an XG27AQNGV remain VID 0B05 / PID 1C2C in Firmware Update Mode instead of switching to VID 0B05 / PID 1D67 (DFU)?
At this point, I'm simply trying to determine whether I'm dealing with a firmware issue, a hardware issue, or perhaps an early production revision that behaves differently.
Any ideas, experiences, or suggestions would be greatly appreciated.
Thanks in advance!
I updated using the micro usb port on the monitor, the other USB port does NOT work for the update.
WiZZard46
Post by WiZZard46 » 20 Jul 2026, 10:54
Hello, @liquidshadowfox!
I just found this out after busting my nuts for months trying to update. Thank you for confirming it to me. Got a Ugreen cable and the update went through like a charm.
BLooDS_inc
Post by BLooDS_inc » 20 Jul 2026, 14:07
kevsei wrote: ↑
19 Jul 2026, 08:47
BLooDS_inc wrote: ↑
02 Jul 2026, 02:07
Nothing changes, all dp ports are equals, trying all 3 diff places and nothing changes, borderless mode just dont works anyway
liquidshadowfox
Post by liquidshadowfox » 20 Jul 2026, 23:17
WiZZard46 wrote: ↑
20 Jul 2026, 10:54
Anytime buddy, anything for a fellow enjoyer of low motion blur! :D
bbxcearty
Post by bbxcearty » 21 Jul 2026, 01:01
Emax wrote: ↑
23 Jun 2026, 07:55
I got 48hz and 24hz to work on Pulsar with strobbing. Having the same clarity as 60hz. The cleanest video motion I ever seen. Surpases Plasma & CRT's.
Hopefully the 120hz update can put motion quality on par with 60hz. That way I can use 72hz. Right now 72hz isn't as clear because I'm using 120hz as my base. And using qft to go down to 72hz.
With 24hz and 48hz i'm using 60hz as my base for qft. Which gives me the same clarity as 60hz strobe. qft takes on the same clarity of whatever your starting base hz is. If I use 120hz as my base, for 48hz qft, then it's less clear. So it's best to use 60hz.
There is an issue though, turning off strobe, will have after flicker effects. Strobbing at 24hz or 48hz.
And another issue is that with high contrast elements, I get temporary image retention of that element. But this isn't exclusive to these Pulsar displays since I also see this issue on the Viewsonic XG2431.
So did anyone manage to get this 24hz pulsar to work? :geek:
brownvim
Post by brownvim » 21 Jul 2026, 06:49
bbxcearty wrote: ↑
21 Jul 2026, 01:01
Emax wrote: ↑
23 Jun 2026, 07:55
I managed to do it at 50hz and 24hz using Custom Resolution Utility. Posted it on the Acer Pulsar thread here: viewtopic.php?t=15462&start=20#p126102
Flicker is crazy though for 24hz, unwatchable imo, it is clear though.
50hz flicker isn't as bad but it does flicker a little more than the 60hz mode.
There's also way more image retention doing this.
Maybe doing this with the new 120hz mode could present better results but need someone who knows more about how it all works to chime in.
bahamutfan
Post by bahamutfan » 21 Jul 2026, 14:37
brownvim wrote: ↑
21 Jul 2026, 06:49
I've had good luck with creating 70/80/90/100 Hz custom qft resolutions based on the 120 Hz mode, with no image retention. The full pulse width range is available, so it behaves like a proper ULMB2 mode.
The only caveat is for whatever reason, the brightness is lower at these custom resolutions compared to the original 120 Hz mode. For example, with max brightness set to 500 and the pulse width set to 40, 120 Hz will be brighter than these derived resolutions. In terms of the difference, the brightness becomes roughly equivalent when the 70/80/90/100 Hz custom resolution modes are set to pulse width of 60 (compared to 40 at 120 Hz).
I'd definitely be curious if others are able to keep the brightness levels the same!
rexbinary
Post by rexbinary » 21 Jul 2026, 16:33
ManuelG_NVIDIA wrote: ↑
02 Jul 2026, 13:35
rexbinary wrote: ↑
01 Jul 2026, 22:10
I am sad to report that 1.1.8 does not solve the no pulsar after display sleep issue. At least not for me. I still have to run the monitor in 240Hz desktop to work around the issue. This is on 4080 SUPER.
Could you provide additional details on how you are reproducing this issue?
  • When the issue occurs, does only the display enter sleep mode, or does the entire PC also go to sleep?
  • Are any additional monitors connected to your RTX 4080?
  • Have you changed any NVIDIA Control Panel or NVIDIA App settings from their default values that could affect display behavior (for example, custom color settings, power management, or other display-related settings)?
  • Do you power off the monitor when not in use, or do you leave it in sleep mode?
  • Approximately how long does the display need to remain in sleep mode before the issue can be reproduced after waking it?
  • Are you currently using the latest NVIDIA driver (610.62)?
  • Are there any other steps or conditions that consistently help reproduce the issue?
I figured out this only occurs when 10bpc color depth is set in the Nvidia App. If I switch it to 8bpc the monitor will work properly after sleep. I am on 612.74 currently and firmware 1.1.8.
EDIT: I seldom post without an edit.
