Crazyness wrote: ↑06 Apr 2023, 04:56
Owners of this good and cheap monitor,i need your help..
I was experimenting with Dp versions in service menu..
and to my suprise picture was more clearer then on default dp 1.4..
So maybe i am wrong about this,so i need your help to verify..
DSC (displaystreamcompression)is the crucial part here.
disabling DSC with lower output dp version maybe removed some calculus and enabled some sort of faster image delivery..
even thou logic will say that DSC is what makes faster output..
not certain at all,just thinking outloud..
for example:
panning(watching from highest FOW-manual camera can allow, when spec someone gaming) in DOTA2 looks great
without any sort of tearing which is not the case on 1.4 version..
even thou the fps is low(compared to 390hz output for matching fps=hz)
like 200 droping to 150 in big team-fights.
1.1 version and 960x540 390hz(360hz even better) looks much more clearer than on dp 1.4..etc
enter service menu select dp 1.1 or 1.2 and just observe if there is any difference..
when you are in service menu just press joystick after you selected DP version,screen goes black for brief moment..and thats it,
enter service menu again to verify change.
if you had done something in CRU,
make sure you have some lower res created..so you will not face black screen..
bcs higher resolutions on DP 1.1 will be invisible.
how to enter service menu:
hold first button above the joystick,while simultaniusly pressing highest On OFF button,turn off monitor,
while not releasing button above the joystick
release the button above the joystick when monitor is booted.
press joystick,you are in the default menu now,you will see red F in top left corner in the menu..
press first button bellow On OFF and you are in.
EDIT:
didnt try with HDMI,different cable same principle applies.
