They mentioned the next firmware update will improve Gsync pulsar somewhat so we can only hope it'll be more consistent in motion in the coming update.mawi wrote: ↑11 Aug 2026, 07:44i am not sure if its the same but i have a similar experience with CS2. When playing normal games on online servers (with similar settings as you, also rtss, vsync off etc.), its all looking fine. avg fps are maxed out, 1% lows are also around 300, looks very nice.liquidshadowfox wrote: ↑08 Aug 2026, 11:40Bro I really just wish nvidia would allow us to have an alternative pulsar mode with reduced duty cycle and reduced max brightness. I want at LEAST 20% (5x) duty cycle if they REALLY need to stay close to their 25% duty cycle target or 16.67% duty cycle (x6) if they can offer it. My room isn't completely dark but some games I play are still a little too bright for my eyes with pulsar set to minimum brightness (even with adaptive brightness off) and ULMB 2 mode works perfectly with lower duty cycle but it's not adaptive![]()
When I play workshop maps for aim training (especially prefire maps) they take place on the standard maps but with some modifications ans bots shooting at you.
I know since months these maps perform worse than standard games. Especially on my 4070 I had much lower 1% fps on these maps. But since I have the 5070ti, I also have around 300 fps 1% lows on these maps. But they still look weird. When panning the mouse fast, Its just not clean and smooth, as you said it looks a bit like double images.
When I reduce the fps to 240 it does not change. On standard maps 240 fps look perfectly clear and smooth. On these prefire aim maps they do not, although I have avg and 1% lows perfectly aligned.
Maybe I have to track the 0.01% lows as well. But where does it stop...
liquidshadowfox
- kyube
See, I would accept this explanation, if other vendors didn't implement the same exact method (global scan bstrobing) they're doing on these panels but with better performance, but this is not the case.
The most confusing part to me is the fact they've forsaken both brightness (by using less voltage boosting) & effective motion clarity
on these 240Hz & 360Hz modes... which is bizarre.
The complaints from my side would be far less if they'd use the same voltage boosting as they're doing on 60-120Hz ULMB & gimp the total effective motion clarity... but neither are a thing.
Nevertheless:
Here's an example of how 120Hz, 240Hz & 360Hz ULMB2 should stack up.
Note: This is only theory for now, using linear interpolation. Exact data isn't know as of the date of writing
The PW=10 @ 120Hz point is likely a very optimistic estimate.
As it stands now, based on the small sample data we got from Nvidia & the linear interpolation graph, only 120Hz ULMB2 PW<25 is “usable” for fast-paced games & can be claimed to be “CRT-like”
Close second would likely be 240-360Hz ULMB2 at similar settings, but I'd rather use the former.
Though, it highly depends on the frame rate you're getting & whether one is willing to sacrifice the reduction in sample rate (“smoothness”)
I somewhat can't recall this artifacting, do you perhaps have a visual example?
Salt_Blue
Running an RTX 3090 eGPU setup over OCuLink. G-SYNC and ULMB2 both work fine on my XG27AQNGV, but when Pulsar is active in the OSD with zero visible effect. Ruled out drivers, cables, HDR, color modes, lastest firmware, and fullscreen mode across multiple games. Anyone dealt with this on an eGPU setup, or have ideas what else to check? I can see the strobing working with a slow mo camera with Pulsar active, so there has to be some kind of timing error. I would really like to get this to work if possible on my setup.
Ferdin
- kyube
I don't know why, but I'm unable to make a post in the main Pulsar thread. I've contacted him in a DM, let's see if he'll reply
To diverge from the reply, I've decided to plot how ULMB2 used to behave on the PG27AQN vs the XG27AQNGV (based on linear interpolation data from the new FW 1.1.9)
The data for PG27AQN is based on TFTCentral's & Jisakuhibi's review. Linear interpolation was used.
Note: PG27AQN should have ~1000 cd/m² voltage boosting, while XG27AQNGV has ~1500–1700 cd/m²
Grasshopper85
How does the xg27aqngv compare to the xl2568x+ for a BR like PUBG?
I have the zowie but wondering if I should switch to the g-sync pulsar or even the new zowie xq2566x monitor?
BLooDS_inc
Idk how its compare to the xl2568x+, but to my old zowie xl2735 its night and day, but u cant fully play borderless, only fullscreen exclusive, cause with borderless mode in PUBG gsync stops working properly with 2 monitors setupGrasshopper85 wrote: ↑18 Aug 2026, 20:37How does the xg27aqngv compare to the xl2568x+ for a BR like PUBG?
RonsonPL
Hey
Could someone please tell me if the issues with this monitor were fixed or does this Asus model still lags behind other Pulsar motnitors in some important areas?
I wonder if it's THE one from Pulsar monitors to get, or maybe other brand did much better.
There's currently a very good promo on this one in my country, but I really value low refreshate motion quality. Currently I have almost perfect display for 60Hz and actually for anything between 50 and 120fps.
I am extremely demanding in terms of motion clarity. Not even sure if Puslar satisfies my needs or not, but I don't want to get the wrong Pulsar. Even if it's 25% cheaper than others. I'd rather spend more to get one which works really well rather than regredding the purshase and having to buy a different one after being disappointed.
Thanks in advance
Thanks in advance
mawi
AFAIK the Asus model was the best one... You can change ulmb pulse width and also some flaws from other models are not present on the Asus model.
- CriticalHit_NL
Depending on the brand availability in your region, I would suggest going for the Asus or Acer model.RonsonPL wrote: ↑19 Aug 2026, 06:32Hey
Thanks in advance
The MSI and AOC models had to wait for a longer period of time up until firmware 1.1.8 before they were able to change the fixed 25% pulse width in ULMB2 mode which you likely seek for the 60Hz clarity and thus their general feature updates seem to lag behind compared to the Asus and Acer models atleast at launch.
Personally the looks of the Asus/Acer are better since you don't have a webcam thing sitting ontop of your bezel for the ambient lighting, I remember seeing a review of the AOC were the stand seemed overly wobbly too.
Generally they use the same display panel and technology and firmware though, so it should not be like that they would vary extremely much in terms of visual quality, or should not, after both have all the feature sets unlocked.
But can you really go wrong with any right now? Probably not, depends on your personal taste and availability.
I must say, the 60Hz ULMB2 mode looks absolutely crazy sharp in motion, given you can handle the flickering and a bit dimmer brightness, however I believe the next firmware update is supposed to improve things even more as below changes are mentioned for the next firmware update, if that 60Hz scharpness can be met at these higher frequencies and keeping the brightness higher while also combatting the flickering impact that would be tremendous.
- improved moving image sharpness for 240 and 360 ULMB2 and Pulsar !
the sharpness of ULMB 60 will now be available for 240 and 360 ULMB, but at full 480 nits brightness
measured MPRT (Moving Picture Response Time) of 240 Hz at Pulse Width 50 is below 1.0 ms, or > 1000 Hz equivalent !
Main System:
i9 13900K @ 0.06v undervolt 0x10B microcode / 128GB (4x32GB) Corsair Dominator Platinum RGB DDR5-5400 CL40 XMP / Asus ROG Maximus Z790 Extreme (early 0219 bios, Sept 2022) / Asus ROG Astral RTX 5090 OC / 2x 990 Pro 4TB / 3x WDC Ultrastar HC590 DC 24TB / 3x HGST He10 Ultrastar 8TB / 1x HGST 7K4000 Deskstar 4TB / Corsair iCUE H170i Elite Capellix LCD 420mm AIO (6x Noctua NF-A14 IndustrialPPC 3000RPM) / Corsair AX1600i PSU (2025) / CoolerMaster HAF 700 EVO / Asus ROG Strix Pulsar XG27AQNGV 1440P 360Hz / Asus ROG Swift PG279Q 1440P 165Hz / BenQ BL2411PT 1200P 60Hz
Secondary System:
i7 3930K @ 4.8Ghz 1.4v / 32GB (8x4GB) Corsair Dominator DDR3-1866 CL9 XMP 1T / Asus Sabertooth X79 (2012 bios 3102) / EVGA GTX1080Ti FTW3 / 1x 840 Pro 256GB / 1x 860 Pro 2TB / 2x HGST 7K4000 Deskstar 4TB / Corsair iCUE H115i RGB Elite 280mm AIO (stock fans in pull) / Corsair AX1200i PSU (2014) / CoolerMaster HAF XM
Third System:
i7 950 @ 3.2Ghz turbo / 24GB (6x4GB) Corsair Dominator/Vengeance DDR3-1600 CL9 XMP / Asus P6T Deluxe V1 X58 / Asus ProArt RTX 4060 8GB / 1x 840 Pro 256GB / 1x WD Blue 1TB / Corsair HX750i PSU / CoolerMaster V6-GT CPU-cooler / CoolerMaster HAF 922
Fourth System:
Core 2 Quad Q9550 @ 2.91Ghz / 8GB (2x4GB) DDR3-1066 @ 1098 Royemai (SK-Hynix) / Gigabyte GA-G41M-Combo (Rev. 2.0) @ 343 FSB / EVGA GTX 560 SuperClocked 1GB / 1x860 EVO 500GB / 1x Samsung HD502HI 500GB / Artic Freezer 7 Pro Rev 2.0 / Corsair HX750i PSU / CoolerMaster Elite 331
Secondary System:
Third System:
Fourth System:
