Locked
dervu
Post by dervu » 25 Oct 2020, 07:13
How does this PS Audio Power Plant differ from double conversion UPS doing AC->DC-> AC conversion? As far as I know it helped only to use double conversion UPS on battery, which doesn't last long.
sonexs
Post by sonexs » 25 Oct 2020, 13:46
Bobo wrote: ↑
25 Oct 2020, 05:59
I would recommend you guys to check some audiophile forums in regards to the power problems, they have alot of solutions.
Start with the power cables, something like the supra lorad should be enough. But if you really want clean power then get a power regenerator, something like the PS Audio Power Plant.
thanks for your points.
we already tested some equipment from audio/hifi-sector. (many filters like targa harmony, furman etc.)
the supra lorad and a dc-blocker was tested myself a while ago bc i was suspicious about there might be some dc on the line, due to living next to solar-panels. didnt help.
Bobo
Post by Bobo » 25 Oct 2020, 21:49
Supra lorad usually does the job and its quite cheap. but if that doesn`t work, see if you can borrow an Audioquest power cable that has DBS tech on it and try with that.
As for the power itself, if filters and conditioners don`t work then try a good ups that has a pure sine wave output, and if that doesn`t work then you most likely need a proper power regenerator.
nuggify
Post by nuggify » 27 Oct 2020, 18:59
dervu wrote: ↑
25 Oct 2020, 07:13
PS Audio Power Plant is a Power re generator. It takes the AC converts it and then produces a regenerated sine wave on the output side. There are still some power issues that can traverse this design, primarily common mode noise or inter system ground noise.
spkii
Post by spkii » 27 Oct 2020, 20:00
Tried with G PRO WIRELESS Mouse, same problem.
Unixko
Post by Unixko » 28 Oct 2020, 08:15
spkii wrote: ↑
27 Oct 2020, 20:00
not even for 1 day better ? unlucko
nuggify
Post by nuggify » 28 Oct 2020, 19:04
spkii wrote: ↑
27 Oct 2020, 20:00
Tried the same, it is actually even worst with wireless mice. I believe this is because it has nothing to do with the mouse, rather it has to do with the PCs logic reference being messed with.
bijay135
Post by bijay135 » 29 Oct 2020, 08:47
nuggify wrote: ↑
28 Oct 2020, 19:04
spkii wrote: ↑
27 Oct 2020, 20:00
Well, there goes my only hope :cry: . I guess I will just stick to controller. I will try the wireless mouse myself in future if I can find one for cheap.
Besides this, I can't find any flourescent tube around so have not been able to test the glowing under high voltage wires. I don't know if a led tube will glow but I guess I will try it anyway soon.
spkii
Post by spkii » 29 Oct 2020, 10:45
Tip: I tried with a NEW order Computer on a house near mine, like 5 minutes walking. Same problem with new computer in that house too...
Unixko
Post by Unixko » 30 Oct 2020, 09:39
spkii wrote: ↑
29 Oct 2020, 10:45
you need to try more then 1 place at least 5
Locked
