BenQ Zowie XL2546K 240hz TN
gameinn
Re: BenQ Zowie XL2546K 240hz TN
rtings review just hit early access. Any leakers?
Just pay the early access fee.
(P.S. RTINGS is a partner in that they use Blur Busters inventions as part of their display testing)
The current standard for most monitors tended to be 75Hz-100Hz. From what I remember, the original XL2540 was 75-240.AddictFPS wrote: ↑02 Dec 2020, 17:47I wonder what DyAc+ single strobe range has XL2546K, can't understand why is not in oficial specs. Is like know the VRR range, both is a must be.
XL2746S has max 240 min 100 (or maybe a bit less than 100, seems nobody has tested the exact limit, but at 60 is double strobing, unbearable "double image"). I wonder if this lower limit is removed in this new model, in order to play 60FPS locked games without motion blur, no matter flicker, is assumed like in old CRT monitors.
- axaro1
If it was 2$ to access a single review I'd definitely buy it but I'm not spending 10$
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
mgabee
- axaro1
They generally don't release an early access review during the weekend so wait for next week
*= currently owned
*= currently owned
Inco^
I just got the PG259QN and my game experience is noticeably enhanced compared to with the XL2546K. The higher refresh rate really makes a difference. My first gaming session with this monitor was really a pleasure. The game I play handles 360+ FPS in most cases, I enable G-Sync, vSync=Fast, FPS cap below 360.
P̶G̶2̶7̶A̶Q̶D̶P̶ >> 480Hz OLED (1440p)
PG248QP >> 540Hz TN w/ strobing
XL2566K >> 360 Hz TN w/ strobing
XV252Q F >> 390Hz IPS w/ strobing
PG259QN >> 360Hz IPS
XL2546K >> 240Hz TN w/ strobing
Y27gq-25 >> 240Hz TN (1440p)
AG251FZ >> 240Hz TN
LaCie Electron 22 Blue IV >> high-end CRT (140kHz horizontal)
AG251FZ >> 240Hz TN
gameinn
So like should DyAc+ only be enabled when playing or keep it on all the time?
Boomchakadah
how does it perform at 240Hz in terms of motion clarity compared to the XL2546K.(with DyAc ON & OFF)?Inco^ wrote: ↑05 Dec 2020, 19:23I just got the PG259QN and my game experience is noticeably enhanced compared to with the XL2546K. The higher refresh rate really makes a difference. My first gaming session with this monitor was really a pleasure. The game I play handles 360+ FPS in most cases, I enable G-Sync, vSync=Fast, FPS cap below 360.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
- axaro1
Dyac+ can be a game changer in some games but the panel is very fast and clear even without dyac+, it truly comes down to personal preference.
There are some games where you'll need more general awareness and it will be a godsend and in some others where for example all you do is peeking angles and your main aiming startegy is solely focusing on the crosshair it will not have a lot of impact.
*= currently owned
*= currently owned
