My experience with all sorts of Problems regularly mentioned here.
Locked
Z3CrosS
Re: My experience with all sorts of Problems regularly mentioned here.
Post by Z3CrosS » 30 Aug 2024, 15:13
I think that i don't think
TN_fun
Post by TN_fun » 30 Aug 2024, 15:44
Z3CrosS wrote:
30 Aug 2024, 15:13
Why people believe that they will get answers on every stupid questions or someone owe to answer on that?
He just avoids answer to why things suddenly work when moving PC to another place - I don't know what exactly schools/colleges/university teaches modern people, or maybe people's knowledge just questionable here who asks these kind of questions.
I answered on that tons of time and tired, but i will reply last time: If your PC works different depends of day time, depends of working your fridge or not, depends even of how wet your girlfriend, and differences so big that you even start to noticing it by your own eyes - its the sign ONLY of device instability and its weak/incorrect/damaged/bugged voltage controllers which based not only on hardware level but on software level too (CPU has voltage controllers inside SA - perfomance chipset, PCH has voltage controllers). Sure electricity can damage, but it will do only one time. For example PCH use 1v on all its drivers(modules), and System Agent has same voltage almost for System Agent. In CPU located Micro-kernel = Operation System + Microcode(physcal software, same as drivers - modules).
Why at night better? Because of less servers load(less load on Ethernet controller - PCIE lane), neighbours shut down TVs or even PSI generators - actually its nevermind what they disable, because it shows of device instabillity if microscopic interference affect device so hard that you see it with your own eyes, except ofcourse, if you not live on magnetar itself or your CPU is cooling via magnet on it.
If you have better experience at night so play at night. But no matter what it is day or night, judders will be at dota2 testufo test (144 hertz monitor will perfome worse there than 60 herts - and its answer on many questions: 1st for example an answer for CS players why they have "choppy mouse", because Dota2 testufo test emulates PANO CAMERA - it's your AIM (camera its aim in FPS games), and how can you proper AIM if your image itself on PC is *ucked all the time. 2nd - these happens because PCs with these symptoms sees devices as ANY, always same monitor no matter 300fps or 60fps. Because subsystem is stucked always in one position with one set of instructions which never changes - basic instructions to let owner use PC without any stutters/bsods, but you will see visual diffects on screen - triggered defence, each module could be switched of by subsystem if it sees malfunctions (same is with broken USB slots or HDMI slots, but PC still works. Mainly its damaged PCIE lane + DMI(PCIE lane too), thats why PCH has no thermodynamics(always same stucked temperature and only GPU and other ambience warms it slow, but zero dynamics depends of load or amount of connected devices). "Modern" PCs since 2008 +/- made according to the principle: would work even in a bucket of bolts state, slow/incorrect but will still work stable incorrect till the end. In safe windows mode - will be defects in window frame while you move that frame, text in normal Win mode will be wash out in motion on any monitors even on a the fastest and expensive one. Sure better is better but only with comparing, these PCs with these symptoms no match for PCs in ideal state, abyss difference.
People with ideal PCs will have huge advantages over these PCs, not only because of instable image/frames, but because of big latencies. They will see you faster(because your PC has not only wrong image/ frame building, but you are slow on servers, because of PCIE lane malfunctions, ethernet controller - PCIE lane - degraded)and yes thier camera will be always ROCK stable (even at evening or/and even when neighbours enabled all their electronics in a same time). Its not a mouse which choppy, PanoCamera - your AIM, or if to be precisely its image/frame building is bad because of conflicts inside PC.
So i will repeat another one but short this time and with your style(same balls but side view):
Day night different experience, wetty day, household interfence causes PC instability which you can notice even with your eyes, yes device is in Ideal state, sure problem in something else.
Why do you ignore questions about consoles? Be it ps5 or xbox
Z3CrosS
Post by Z3CrosS » 30 Aug 2024, 15:48
AudAmerica
Post by AudAmerica » 31 Aug 2024, 00:56
Z3CrosS wrote:
30 Aug 2024, 15:48
I am not ignoring.
PCs, consoles, phone, smart TVs, smart monitros - its all same balls.
Or do you think Consoles or Phones/Arm cpus its technologies from Andromeda?
Software rules the world, but hardware can be software (microcode - famous example).
Another software example - Resident Evil 4 Remake on Iphone
I mean without software PC cant make 2+2. Hardware and Software depends on each other, if something goes wrong, will be no perfect work
You have completely ignored the problem......
Why are you blaming others after they have tried your solution? If you really know the problem, you can declare not to use 14900K-Z790MOBO
There is nothing wrong with Lenovo computers. According to your logic, people who use Lenovo computers have input lag because they bought "unofficial" Lenovo computers
Why didn't you declare in advance that WIN11 purchased in Russla is pirated software?...... :D
TN_fun
Post by TN_fun » 31 Aug 2024, 07:02
Ok. What goes wrong when using the ps5 and a TV (or monitor)? Did you plug it in incorrectly or create the wrong account? I'm interested in your train of thought.
Why don't millions of users around the world have these problems, are they the chosen ones?
dervu
Post by dervu » 31 Aug 2024, 08:58
If there is any truth to his theories, he would let someone with access to a lot of hardware review it by trying such scenarios to break it.
Any youtuber with technical knowledge would thank you for such opportunity for free views and no one will waste money.
As it is so easy to break it by using bad license, it should be easy to reproduce and compare
Post by Slender » 31 Aug 2024, 15:26
equipment breaks down from interference over time. New PC in ideal conditions = fix
Z3CrosS
Post by Z3CrosS » 01 Sep 2024, 03:19
dervu
Post by dervu » 01 Sep 2024, 03:33
I didn't ask whether they have shown it. I asked whether you asked them to check your theory. It would be even better if you could help 80% of the people in the world. :lol: And this is the easiest way. Why won't you do it if you are so sure?
Z3CrosS
Post by Z3CrosS » 01 Sep 2024, 03:52
Locked
