gideonmontes
Unfortunately, I can’t suggest anything, because I don’t have enough information about your network cards.
mackalren
Hey, just trying it, but. Have you tried playing with "Advanced EEE" and "EEE"? As I see it's just entirely disabling or enabling EEE and Max Support Speed.gideonmontes wrote: ↑11 Jun 2025, 03:54Unfortunately, I can’t suggest anything, because I don’t have enough information about your network cards.
- n1zoo
This is because you need the Realtek PCIe 2.5GbE Family Controller driver (device manager should show like this). Enjoy your 2days effect buddy!bwainzz wrote: ↑10 Jun 2025, 20:00My realtek nic not show this option, motherboard is a B550 Gaming Plus MSI, you can help?gideonmontes wrote: ↑10 Jun 2025, 15:39Lv. wrote: ↑09 Jun 2025, 05:30gideonmontes wrote: ↑07 Jun 2025, 05:50Guys, try limiting EEE Max Support Speed to 10 Mbps.
Here's what people write about this setting on the Internet: EEE max support speed usually indicates the maximum network speed (e.g. 1 Gbps or 10 Gbps) up to which EEE technology can be applied. For example, if you have a switch with EEE functionality and its "EEE max support speed" is 1 Gbps, this means that EEE can only be activated on networks with a maximum speed of up to 1 Gbps.
Now let's imagine that we have a network device, such as a switch, and its specifications specify a parameter called "EEE max support speed". If this parameter is, for example, 1 Gbps, this means that EEE will only work on this device for networks where the maximum speed does not exceed 1 Gbps. If the network is running at 10Gbps, EEE will not be activated and the device will operate at full power without turning on power saving mode.
Wherever I look at various video settings, for some reason everyone always recommends setting it to 1 Gbps or more.
Woow, played a few faceit pugs @level 10 and my bullets seems to be connecting, wtf?
let me play a few more days/week to see if it keeps like this.
Thanks!!
Oh, glad you have everything working as it should. Once I changed this setting, everything works fine for me. By the way, many people wrote about the bad picture, as if you were playing on a 60Hz monitor. I learned something.Recently I changed the RAM on my PC and noticed that when I turned on the PC the red DRAM indicator was on, and then the GPU. I went to the forums to read what it could mean. I'll say right away that the video card and everything else is functioning normally. So, after reading on forums, most of them were related to Display Port cables. On various video cards, starting from the 2000 rtx series and ending with the 5000 series. In general, when turning on the PC, the monitor should be turned off with the button. When the operating system loads, turn on the monitor. After that, you need to switch the output in the monitor settings to HDMI (even if you do not have an HDMI cable connected). Then switch back to Display Port. Voila, personally, my picture is absolutely smooth after that, I am even now replaying Assassins Creed 2 in 59 fps, I would never have thought that 59 fps is very smooth.
Tell
JimCarry
n1ghtik
I own a b650 board with realtek nic, I bought an external pcie card with intel chip, the problem remains, my hitreg depends on the time of day. I have no problem with electricity or floaty mouse, my sens in game moves great. In one game I can make 3 quick headshots with deagle in another game I score 5-25 with the feeling that my opponents have a 300-400ms advantage.
From my findings I think it is a problem with isp, I chose another provider which has a different upstream provider from bgpview.io data but the problem remains
The game server monitors the packets I send it and in response sends me information about loss and jitter, but at any time of day my jitter does not change, it also stays between 1-5ms, as well as ping and loss.
How can I track this problem?
drosku
if u said u tested a lot of things then get the isp to check ur cable connection to the pole outside ur house/apartment just track down where u get ur internet from and make them check it physically if they say its not a problem the maaaain problem is faulty node check for quite some time with pingplotter or if u are advanced with wireshark you will need good evidence and some money but u wont have problems after goodluck!n1ghtik wrote: ↑20 Jun 2025, 02:44I own a b650 board with realtek nic, I bought an external pcie card with intel chip, the problem remains, my hitreg depends on the time of day. I have no problem with electricity or floaty mouse, my sens in game moves great. In one game I can make 3 quick headshots with deagle in another game I score 5-25 with the feeling that my opponents have a 300-400ms advantage.
n1ghtik
I tracked a couple of games with pingplloterdrosku wrote: ↑20 Jun 2025, 07:23if u said u tested a lot of things then get the isp to check ur cable connection to the pole outside ur house/apartment just track down where u get ur internet from and make them check it physically if they say its not a problem the maaaain problem is faulty node check for quite some time with pingplotter or if u are advanced with wireshark you will need good evidence and some money but u wont have problems after goodluck!n1ghtik wrote: ↑20 Jun 2025, 02:44I own a b650 board with realtek nic, I bought an external pcie card with intel chip, the problem remains, my hitreg depends on the time of day. I have no problem with electricity or floaty mouse, my sens in game moves great. In one game I can make 3 quick headshots with deagle in another game I score 5-25 with the feeling that my opponents have a 300-400ms advantage.
I just don't understand what properties to look at, the data from pingplotter does not correlate with my hitreg
I also don't understand why the game server doesn't report problems with the pockets I delivered
- kyube
I can give you a small troubleshooting list:
- Ensure optimal power quality, both in your house & (less SMPS in house are better, relying on linear PSUs is good)
- Ensure your ISP routing is "good" with minimal re-routes (closer to server = better)
- Ensure your networking hardware is OK (check cables, routers, switches etc.)
- Ensure your HW stability (either thro stress-testing or running maximum data integrity HW with ECC ram)
- Ensure your SW stack is in-tact (applying only parameters with known benefits)
Each of these topics encompasses a vast majority of sub-topics.
My guess is that you're battling with the 4th issue.
n1ghtik
hey thanks for replykyube wrote: ↑21 Jun 2025, 09:38I can give you a small troubleshooting list:
when changing any part of the components I do clean cmos + fresh windows, I don't do any tweaks in windows/bios when starting to play, only after I experience lags and bad hitreg I start doing cpu/windows tweaks.
I use keenetic hopper router, all settings are stock, cat5e utp cable. The only thing I'm not sure about is the box that converts the signal from isp cable to ethernet, in the future I want to try to get rid of this box and try to connect the cable via sfp port.
I have a 7800x3d + asus b650 + cl30 adata lancer blade ram (stock, hynix-a die). The memory serial number is on my board's supported list, I tried doing memTest86 and occt cpu+ram 1 hour but they didn't show any errors.
from my observations, enabling expo profile makes my game unplayable, it is noticeable immediately, also I tried using other memory that is not in the list of supported memory, with it also the problem remains (teamgroup 16x2 cl38).
