New Zowie Monitor 540Hz XL2586X
daviddave1
Re: New Zowie Monitor 540Hz XL2586X
Post by daviddave1 » 19 Feb 2025, 16:39
https://www.testufo.com/frameskipping does not seem to work on 500 or 540hz? Cant get the status on Green/Ready? Chrome and Firefox? I get the "Sync Failure unable to Vsync error. Try closing all tabs an all aps" it works on 360hz.
| Now:
| Past: XL2586X 540Hz/PG248QP/271QRX/VG259QM with the Qisda panel/PG27AQN/XL2566K
daviddave1
Post by daviddave1 » 19 Feb 2025, 16:59
MSIfanboy wrote:
18 Jan 2025, 06:24
i did get 540hz HDMI 2.1 working with no DSC, alt tab
not sure if changing 32gbps to 48gbps did anything
disabled dsc, chose 500 EDID in benq monitor
i have a 48gbps hdmi 2.1 (not zowies one) unsure if that changes anything
made a custom cru refresh
im not actually sure how high i can go with pixel clock in zowie, and i dont really wanna mess up new 1000 USD monitor :lol:
it def doesnt overclock, do not ret above 540hz, i had to use another monitor to get into CRU in windows to reset/change it
Nice 540hz on 500hz mode works. using standard hdmi 2.1 cable with your settings! ty!
It also worked without changing 32gbps to 48gbps or enabling Fast Vactiv.
Can u check if https://www.testufo.com/frameskipping works? Cant get the status on Green/Ready? Chrome and Firefox? I could net get it to work also before the overclock. I get the "Sync Failure unable to Vsync error. Try closing all tabs an all aps"
it works on 360hz.
| Now:
witega
Post by witega » 07 Mar 2025, 21:53
Don't have Chrome or Firefox, but it does work on Microsoft Edge which is Chromium based iirc
daviddave1
Post by daviddave1 » 08 Mar 2025, 16:52
witega wrote:
07 Mar 2025, 21:53
tnx. i tried edge too. unfortunate still get the "Sync Failure unable to Vsync error. Try closing all tabs an all aps" error
| Now:
witega
Post by witega » 10 Mar 2025, 07:32
daviddave1 wrote:
08 Mar 2025, 16:52
witega wrote:
07 Mar 2025, 21:53
If "Efficiency Mode" disabled in Edge settings?
daviddave1
Post by daviddave1 » 12 Mar 2025, 19:51
witega wrote:
10 Mar 2025, 07:32
daviddave1 wrote:
08 Mar 2025, 16:52
witega wrote:
07 Mar 2025, 21:53
yes weird huh. also tried it with gsync on. 480hz, 360hz is stable for 2 seconds then a stutter warning also in kiosk mode.
Unfortunately 499hz and 540hz gives the same error as before. Also after factory reset monitor.
240hz remains stable longer. i think its my ddr5 mem .
do u use dp 1.4 or hdmi 2.1 cable?
shall i rma the monitor?
I had it fixed by zowie last month cause I had a green line across the screen that would not go away. maybe its damaged somehow?
| Now:
daviddave1
Post by daviddave1 » 13 Mar 2025, 00:07
witega wrote:
10 Mar 2025, 07:32
daviddave1 wrote:
08 Mar 2025, 16:52
witega wrote:
07 Mar 2025, 21:53
*Edit i used the dp 1.4 cable now instead of the hdmi 2.1 and 360hz remains stable. 540 hz works too for almost 10 seconds. Then a stutter warning. Do you get this too sometimes?
Edit 3 the framerate in hdmi 2.1 drops to 537 so i made a custom res with 537 hz. Now it remains stable for arround 10 secs then a potential browser stutter occures. Do u have this also?
| Now:
MSIfanboy
Post by MSIfanboy » 16 May 2025, 21:24
daviddave1 wrote:
13 Mar 2025, 00:07
witega wrote:
10 Mar 2025, 07:32
daviddave1 wrote:
08 Mar 2025, 16:52
witega wrote:
07 Mar 2025, 21:53
just use pursuitfrog, you can even screenshot the ufo in fullscreen and use that in pursuitfrog
