Here is a more complete list of where I'm stuck. Please help me
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo i2cdetect 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- 37 -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- 49 -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- 59 -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo i2cdump -r 0-127 0 0x50
No size specified (using byte-data access)
I will probe file /dev/i2c-0, address 0x50, mode byte
Probe range limited to 0x00-0x7f.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 00 ff ff ff ff ff ff 00 09 d1 30 7f 45 54 00 00 ........??0?ET..
10: 0b 18 01 03 0e 35 1e 78 2e 9d e1 a6 54 54 9f 26 ?????5?x.???TT?&
20: 0d 50 54 a5 6b 80 d1 c0 45 7c 61 7c 81 80 81 bc ?PT?k???E|a|????
30: 95 3c 31 7c 01 01 02 3a 80 18 71 38 2d 40 58 2c ?<1|???:??q8-@X,
40: 45 00 13 2a 21 00 00 1e 00 00 00 ff 00 33 33 45 E.?*!..?.....33E
50: 30 30 39 37 34 53 4c 30 0a 20 00 00 00 fd 00 18 00974SL0? ...?.?
60: 78 0f 87 15 00 0a 20 20 20 20 20 20 00 00 00 fc x???.? ...?
70: 00 42 65 6e 51 20 58 4c 32 34 31 31 5a 0a 00 cd .BenQ XL2411Z?.?
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-0:49
flashrom v0.9.7-r1852 on Linux 3.13.0-24-generic (i686)
flashrom is free software, get the source code at
http://www.flashrom.org
Calibrating delay loop... OK.
Info: Will try to use device /dev/i2c-0 and address 0x49.
Info: WILL reset the device at the end.
Found Macronix flash chip "MX25L1605" (2048 kB, SPI) on mstarddc_spi.
Found Macronix flash chip "MX25L1605A/MX25L1606E" (2048 kB, SPI) on mstarddc_spi.
Found Macronix flash chip "MX25L1605D/MX25L1608D/MX25L1673E" (2048 kB, SPI) on mstarddc_spi.
Multiple flash chip definitions match the detected chip(s): "MX25L1605", "MX25L1605A/MX25L1606E", "MX25L1605D/MX25L1608D/MX25L1673E"
Please specify which chip definition to use with the -c <chipname> option.
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-0:49 -c "MX25L1605A/MX25L1606E" -r backup.bin
Reading flash... Error sending write command: errno 5.
Read operation failed!
FAILED.
Info: Reset command was not sent. Either the noreset=1 option was used, or an error occured.
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-0:49 -c MX25L1605A/MX25L1606E -r backup.bin
FAILED.
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-0:49 -c MX25L1605A/MX25L1606E -r backup1.bin
Reading flash... Error sending read command: errno 5.
FAILED.
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-0:49, noreset=1
Error: Extra parameter found.
Please run "flashrom --help" for usage info.
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-0:49,noreset=1
Info: WILL NOT reset the device at the end.
Reading flash... done.
ubuntu@ubuntu-Aspire-6935:~/flashrom$ tr '\000' '\377' < /dev/zero | dd of=firmware.bin bs=1k count=2k
2048+0 Datensätze ein
2048+0 Datensätze aus
2097152 Bytes (2,1 MB) kopiert, 0,0143371 s, 146 MB/s
ubuntu@ubuntu-Aspire-6935:~/flashrom$ dd if=XL2411Z_V2_20131209_8B72.BIN of=firmware.bin conv=notrunc
1664+0 Datensätze ein
1664+0 Datensätze aus
851968 Bytes (852 kB) kopiert, 0,00860375 s, 99,0 MB/s
ubuntu@ubuntu-Aspire-6935:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-0:49 -c "MX25L1605A/MX25L1606E" -w firmware.bin
[sudo] password for ubuntu:
Reading old flash chip contents... done.
Erasing and writing flash chip... Error sending write command: errno 5.
spi_nbyte_program failed during command execution at address 0x4500
Reading current flash chip contents... Error sending write command: errno 5.
Can't read anymore! Aborting.
FAILED!
Uh oh. Erase/write failed.Checking if anything has changed.
Reading current flash chip contents... Error sending read command: errno 5.
Can't even read anymore!
Your flash chip is in an unknown state.
Please report this on IRC at chat.freenode.net (channel #flashrom) or
mail
[email protected], thanks!
