Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Post by Slender » 07 Jan 2026, 15:23
MK92 wrote:
07 Jan 2026, 04:22
Yes, I have been suspecting monitors for some time now. Any gold-rated PSU should easily suppress dirty electricity, so the PC is actually working fine. But then you have monitor plugged directly into the wall without any suppression from its own shitty power supply, and this is exactly why everything on the screen feels delayed, 250hz feeling like 55hz, desync, output delay, colours washed out, text is not sharp etc., because monitor is not working correctly, not PC.
I've tried 3 different montiros - one older 60hz, one 144hz, and one 250hz...and all of them feels exactly the same, and all of them are making a slight buzz sound, and power adapter cable makes buzz noise as well. Especially if you change the brightness levels, it gets louder - typical sign of unstable power.
psu with platinum rated, monitor 12v 4a connected via sata 12v dc, all things same.
ablemor
Post by ablemor » 07 Jan 2026, 15:29
and it was good, slender?
MK92
Post by MK92 » 07 Jan 2026, 15:41
Does your PSU, or monitor AC adapter, or monitor itself making any kind of high-pitch noise? Or maybe phone chargers? For me, even the modem power cord is making a buzz sound (but need to put my ear really close to hear it), this is probably a big clue if electricity is actually the problem, because dirty electricity = everything connected makes a coil whine / buzz sounds.
Post by Slender » 07 Jan 2026, 19:47
ablemor wrote:
07 Jan 2026, 15:29
im write you if im found something.
Post by Slender » 07 Jan 2026, 19:49
MK92 wrote:
07 Jan 2026, 15:41
yes, i think cpu, gpu vrm monitor coil whine sound is same issue like sound from any ac to dc adapters in apartment.
bluca9211
Post by bluca9211 » 09 Jan 2026, 13:35
pervysage19 wrote:
29 Mar 2025, 15:16
Just wanted to post about my experience in the hope that it may help someone someday who like me was just doing random Google searches every now and again tearing their hair out trying to figure out what was causing their issues.
The Issue: Floaty aim feel kicks in after playing a game for about 10-15 minutes or so and once it starts, will not go away until PC is restarted only for the cycle to repeat again. The floaty aim feel can be described as an almost accelerated sensitivity aim feel where the cursor is not feeling in sync with what I am trying to do with the mouse (clown cursor). Instead of feeling 1:1 it would always feel very slippery and inaccurate.
I tried basically everything and it seemed to even carry across different PC builds and even monitors (OLD build was a i7-8600K, 1080TI, 16GB 4133mhz RAM, CURRENT build is i9-13900KS, 4090, 32GB 7600mhz RAM). Older monitor was a 240hz ASUS PG258Q, current monitor is a 540hz ASUS PG248QP.
I have a triple monitor setup but with a two PC setup. Two monitors to my old rig, which I use for all purposes on the side and my new rig connected to ONLY the 540hz monitor and nothing else. The new rig is used strictly only for gaming for max performance and as to have nothing running in the background. I have always been very picky about going with lowest settings and maximum FPS, hence the 540hz monitor and overkill PC for 1080p gaming. I feel like I am very sensitive to changes in my setups and the floaty aim feel was absolutely killing my experience.
For reference I pretty much exclusively play Overwatch 2, uncapped frames NVIDIA Reflex Boost + On for lowest latency, 600FPS (max allowed on Overwatch) and in game I am usually holding a steady 580-600FPS with no issues at low settings. NVIDIA Control Panel: Ultra Low Latency Mode (gets overridden by Reflex anyways, Fixed Refresh Mode, Prefer Maximum Performance power mode).
So recently I had begun to notice that whenever the floaty aim feel would kick in, if I changed any NVIDIA GPU setting in the control panel, it would temporarily fix the floatiness for about a minute or so but it would immediately come back. I became convinced it was somehow GPU/driver related and tried changing every setting I could. Stuff like GSYNC would help it feel not as bad but you could still tell the floatiness was there a little bit.
Started messing with RivaTuner after I ran out of options in NVIDIA Control Panel to play with and I found that setting a frametime limit also felt a bit better but like GSYNC it didn't feel perfect and I hated the added input latency feel. Tried the scanline sync option and it felt much better than setting a frametime limit but I could still feel a hint of floatiness with that as well. Ended up giving up going down that road and un-installed Rivatuner. Back to square one with no solutions in sight.
Now I've had issues with electricity related interference in the past but won't go down that rabbithole as I don't think you can talk about that stuff here. But I have had excellent results having my entire PC setup running on a Medical Grade Isolation Transformer and implementing Quest VR fiber optic USB-C cables where ever possible. But this seemingly monitor/GPU related floatiness feeling just couldn't be resolved no matter what.
That is when the idea occurred to try a fiber optic DisplayPort cable. I was willing to try anything at this point and these things are relatively inexpensive on Amazon now if you can find one for a good price. Could always return it if it didn't do anything.
Got one in and replaced my regular copper cable immediately noticed a HUGE difference on the first day. Went a FULL day without any issues, great aim feel. On day 2, the floatiness seemed to come back which got me flustered. But then I began to wonder why it did seem like it was fixed for a day. Then I remembered I still have one more copper display cable going into my 540hz monitor that is connected to my old rig (basically sometimes I would use this HDMI connection to run all 3 of my monitors on my old rig). I unplugged that HDMI connection so that my gaming PC is strictly only connected to the 540hz monitor via the fiber optic DisplayPort cable and nothing else. So at this point the only thing connected to my 540hz monitor is the power brick and the fiber cable from my gaming PC. The great feeling from the day before immediately returned and now it stayed.
It has been two whole weeks now and the problem seems to be 100% fixed with certainty. The difference has been day/night and I am easily able to replicate the issue by introducing the copper cables back into my setup.
Totally bizarre and I don't know why it happens, but I am super grateful to finally have a solution to this longstanding problem that has been plaguing me for literally years.
Am not suggesting this will fix issues for other people as their symptoms or problems might be caused by completely different things, but for my situation it fixed the problem 100%. I am still in amazement and bewildered as to the why but I'm not complaining. Just been enjoying the feeling of gaming without dealing with stupid issues that no one else seemingly had to, it was so frustrating.
So yeah, hopefully this would help someone in the future!
From now on, I just use my 540hz monitor solely with my newer gaming PC via fiber optic DisplayPort cable and I use the old rig for my other two monitors.
Could you re- link ,again,the Amazon site of the cable and tell me the exact brand I want to try it
Thanks
dervu
Post by dervu » 09 Jan 2026, 15:59
If it's so reproductible let him first show the difference.
F1zus
Post by F1zus » 09 Jan 2026, 16:01
Slender wrote:
07 Jan 2026, 15:23
I've been using this setup for a long time. My internet cable is connected to an optical fiber converter, one of which is plugged into a regular wall outlet, and the other is powered by the computer's 12V PCI power supply. Now, interference from the ISP's internet cable and router doesn't reach my computer. The mouse has become more responsive, and aiming is easier.
With this setup, there's no difference between playing with the internet cable plugged in and unplugged.
Now, when I get a new monitor with an external power supply, I'll connect it to the computer's 12V PCI power supply. This way, interference won't be able to get through the monitor's low-quality power supply.
We'll see how much this reduces input lag.
The point is, I currently have a perfectly smooth image using fps_max 237 + vsync + freesync, but it seems to me that my opponents notice me 100-200ms before I notice them. That's electrical input lag. So even the weakest noob always has a 100ms advantage over me, which is quite a lot.
jeffeh12133
Post by jeffeh12133 » 10 Jan 2026, 15:28
F1zus wrote:
09 Jan 2026, 16:01
Slender wrote:
07 Jan 2026, 15:23
interesting you mention this, i used to do this setup too but i eventually got a PCIE fiber ethernet i210 into my motherboard so i only use one fiber media converter now instead of two. i plug the fiber wire straight into my PC into this PCIE fiber ethernet but it's the same concept. i did this because i noticed one night unplugging my ethernet made things feel extremely smooth so i just wanted to opt for a fiber wire to remove copper wiring and EMI. so now i have a full optical DP and full optical ethernet, next is the psu i guess :lol: :lol:
on a general note, i'm currently in the process of testing out the RUIPRO full-fiber displayport cable. i just received it yesterday. https://www.amazon.com/dp/B0FRMYY8PZ?re ... title&th=1.
i can't tell if it's placebo or what but something definitely changed in my perception but i cannot tell if this is placebo. i do notice that aiming feels different (this one is not a placebo). exactly like someone said earlier in this thread, it feels like enabling gpu scaling instead of display scaling (maybe due to an added layer of conversion happening). and this is not inherently a bad thing for me.
as for the image quality, i also feel like something changed - things look a bit brighter? but again, this could just be my perception. my eyes burn less and i'm really engaged into the games im playing but again i can't tell if this is placebo or not but i'm having a good time.
on an off-topic note, i also (along with this DP cable) got myself a fully mesh chair to replace my PU leather chair. i read that there is less static electricity buildup to my body from moving around so that's kind of a minor plus. not sure if this has anything to do with anything electrical for my case. i did read something about how the chair you're using can affect you or your peripherals very slightly and can cause inconsistencies because PU leather can build up static a lot more than a mesh chair. i think i saw someone a while ago mention that any time they brought their chair close to the monitor, their display would mess up so i just got a mesh chair since my old one was trashed up. still a win-win decision since i got a new comfy chair if it changes nothing anyway.
edit: im using a BenQ XL2546x+ so if anyone is worried that BenQ monitors might not power the detachable ruipro DP cable, have no worries because it works. I also have deep sleep disabled on my monitor.
themagic
Post by themagic » 10 Jan 2026, 15:54
You all have no Idea about you even talking and what Input Lag...pls stop this bullshit... :lol:
No one will see my message but maybe the moderators who have still sense of logic...
