UPDATE 2 | Fixed input lag and floaty mouse with UPS
Blackjack_br
Re: UPDATE 2 | Fixed input lag and floaty mouse with UPS
Post by Blackjack_br » 07 Oct 2026, 10:58
Roxtar wrote: ↑
27 Nov 2025, 04:36
Quick update on my input lag / “dirty electricity” issue, in case it helps someone in the same situation.
In my first thread I talked about how buying a new PSU seemed to fix my input lag and “floaty” mouse feeling. For a few days it felt amazing: Valorant was crisp, flicks felt natural, and even moving the mouse on the Windows desktop looked super sharp.
But after turning the PC on and off over the next week, the bad feeling slowly came back. Each day it felt a bit worse, almost like the PSU was struggling more and more. My (non-expert) theory is that the PSU capacitors were gradually getting “contaminated” by dirty power from the wall again.
After about a week I was honestly crushed. I went back to lurking forums and watching videos until I found a post where someone mentioned that a double-conversion UPS fixed their issue. Not just any UPS, but specifically double-conversion, because those units convert AC → DC → AC, effectively filtering out most of the dirty electricity before it reaches your PC.
By the end of summer I’d started a programmer job, and the first thing I wanted to do with my first paycheck was buy one of these UPS units. I waited a bit to read more about it, and in November I finally ordered a double-conversion UPS (Salicru SLC Twin PRO 2 700VA Schuko SAI).
I set up my power chain like this:
Wall outlet → UPS → PC + both monitors
On the UPS I enabled LINE mode so it always delivers filtered power to the outputs. Then I booted up the PC and launched Valorant.
Results:
  • It didn’t feel 100% perfect, but it was much better.
  • Mouse control improved a lot, and aiming for the head felt more consistent.
  • The “60 Hz-ish” feeling was still there on the monitor, but overall I’d say the UPS removed about 60–70% of the issue.
I waited until the end of the month to see if the problem would slowly creep back like it did with just the new PSU. So far, it hasn’t.
Right now I’ve ordered a replacement PSU, because I suspect the remaining ~30% of the problem might be due to components that have already been degraded by years of dirty power. I’m also planning to buy a medical-grade isolation transformer to go even further with power conditioning.
I’ll keep updating this thread with any new results. Hopefully this helps someone else struggling with the same weird input lag / dirty power nightmare.
UPDATE 04-12-2025
The PSU replacement arrived, and I also ordered a new CPU (9800X3D) plus a new UPS with enough power (Salicru SLC Twin PRO 2 2000VA Schuko SAI).
At first, it felt horrible, just like when I didn’t have any UPS connected. Then I remembered that in the UPS manual it says the PC must be at least 20 cm away from the unit. With the old 700 VA UPS this wasn’t an issue because it was quite small, but the new one is gigantic, so I guess there’s more interference.
I moved the PC as far away as the power cable allowed and I have to say: the feeling is incredibly amazing now. Zero input lag, the mouse feels like an extension of my arm, I know exactly how much I need to move it to land headshots, and the monitor looks like real life at 1000 Hz.
I’ll keep updating weekly… if I don’t forget. :P
UPDATE 17-12-2025
Still doing good, however, I've watched some videos about dirty electricity and EMI in general, I think I'm going to buy some devices to help me document and find a better answer rather than just a plain 'UPS fixed it'. Will probably make another thread if I decide to keep researching and invest more into this.
How is the input lag with that UPS of yours these days? Do you keep it plugged into the mains all the time?
Any updates from anyone who managed to solve 100% the problem?
Based on my research, I believe the cause of my problem is likely my smart meter, which generates a significant amount of EMI inside my apartment. Image
The only thing I haven't tried yet is connecting my gaming PC to a double-conversion UPS with a pure sine wave output.
The last thing I tried—which resulted in a slight improvement (let's say around 25%)—was using "dirty electricity filters" that I built after watching a YouTube video. Image
The video recommended assembling several of them and distributing them across all the circuits in the house. Unfortunately, however, I’ve only managed to build two so far due to the high cost of the components required.
Captura de tela 2026-10-07 125622.png (821.58 KiB) Viewed 1548 times
adelsa123
Post by adelsa123 » 09 Oct 2026, 01:53
this ufc fighter talked about this probleme xD i think his true about nerfing thing
[url] https://www.youtube.com/shorts/lnJbLKptvDE
Hubcio
Post by Hubcio » 09 Oct 2026, 22:13
Idk but my iPad Pro m5 Fortnite works nice, I feel aim assist, playing through WiFi and Bluetooth controller and I’m winning games, I can also clutch 1 vs 2 for example and I feel like I can gaming again. Fights feels very fair like I can react to enemy. One dude was beaming me from air while I was trying to run all time using shockwaves etc like aim bot (maybe he was cheating or using mobile touch aimbot assist or he was cracked) 1v1 solo BR Fortnite so I decided to hide in building then under tree, and in close range from shotgun I demolished him with shockwave overdrive (I think it was this fight because after win I was raging on this dude so haaard because he almost beamed me from air and hiding play was a pro move XD)
astroasis
Post by astroasis » 10 Oct 2026, 08:10
online ups on battery does work but on line mode it doesnt work, so people who say offgrid doesnt work are either lying/still have a connection to grid like ethernet/have extreme airborne radiated interference. Im getting a power station soon
Mercron
Post by Mercron » 02 Nov 2026, 23:26
astroasis wrote: ↑
10 Oct 2026, 08:10
Hey, just to triple check here, your issues got better after getting a UPS? I might get one but they are expensive, looking forward to the reply
astroasis
Post by astroasis » 03 Nov 2026, 13:33
Mercron wrote: ↑
02 Nov 2026, 23:26
astroasis wrote: ↑
10 Oct 2026, 08:10
Mercron wrote: ↑
02 Nov 2026, 23:26
astroasis wrote: ↑
10 Oct 2026, 08:10
Hi, the online ups DID NOT work unless I run from battery unplugged from wall. I have the usual blurry image, bad colors, bad sound, desync etc as others here when plugged into wall outlet
Mercron
Post by Mercron » 03 Nov 2026, 19:41
astroasis wrote: ↑
03 Nov 2026, 13:33
Mercron wrote: ↑
02 Nov 2026, 23:26
astroasis wrote: ↑
10 Oct 2026, 08:10
Mercron wrote: ↑
02 Nov 2026, 23:26
astroasis wrote: ↑
10 Oct 2026, 08:10
so the only thing that works for you is running from battery? interesting, thats very insightful, thanks
astroasis
Post by astroasis » 04 Nov 2026, 10:34
Mercron wrote: ↑
03 Nov 2026, 19:41
astroasis wrote: ↑
03 Nov 2026, 13:33
Mercron wrote: ↑
02 Nov 2026, 23:26
astroasis wrote: ↑
10 Oct 2026, 08:10
Mercron wrote: ↑
02 Nov 2026, 23:26
astroasis wrote: ↑
10 Oct 2026, 08:10
Yes, on battery. Ecoflow delta classic 3 seems to be still working fine also after two weeks, which is just a lithium battery
unexpected8
Post by unexpected8 » 04 Nov 2026, 11:49
But you said the problem returned after a week.
I have an online UPS, but the problem didn't go away even when running on battery power.
And naturally, it wouldn't go away, because there is no grounding.
astroasis
Post by astroasis » 04 Nov 2026, 13:26
Yeah i thought it came back on battery but i actually had ethernet connected for multiple days, my router wasnt connected to the ecoflow. PC does work normally now. The ethernet was blurring the monitor perhaps through error correction or something im not sure
