Electricity input lag fix !
akylen
Re: Electricity input lag fix !
did it changed anything ?
wadge
Plznoinputlag
- dervu
If you have some experience you can tell it is working properly for them despite differences in live play vs recording. Just remember to not fall into that trap where you think game should look like video recording. It will always be smoother on recording.
Adaamz
Hey I'm having the same problem , I know this is an old post and you probably fixed that problem already , I'm hoping you will answer and tell me how , because I literally changed everything possible untill I realised its a Electricity related problem , thanks in advance:)yonaxsangi wrote: β18 Apr 2021, 10:56Ok hello guys first of all sorry for my english its not good but ill try my best to help for people who have this annoying electricity problem.
i lived with this inout lag for 5 years without potential fix i tried every windows tweaks nvidia drivers, motherboard drivers, changing most parts of the computer, monitor changing the electricity wires, outlets, own grounding, earthing, surge protectors, emi filters. those things will improve things for 1 hour but u will still get the problem after some amount of time.
I mainly play csgo, 2400 elo faceit , global elite
but i achieved this ranks and level just because of experience and even low lvl or ranked players always prefired me holding position is almost impossible, i have benq 2540 240hz monitor but it feels like its has alot of input lag like make the monitor feels like 10ms!! it should be 1ms. the player movement its too fast tracking is like almost impossible the hitreg is bad u spray and pray to kill an enemy.
-But i have some fix but its not 100%
i can say its very consistent i played like 3 days in the morning and night its always the same(consistent).
I dont know if it will work for some people but for me its worked perfectly its not like 100% fix but i can say its 70% and its playable now.
- so guys i have gigabyte z390 aorus pro motherboard and i saw one guy said theres hidden feature called RFI spread spectrum , PCIE spread spectrum so i enabled all of them from software called AMIBCP and updated my bios. what it does its reduced my RFI/EMi to almost 50mv its like nothing , before it was 850mv is too high and risky for health also. so try to edit your bios and enable all this features.
I hate to be the bearer of bad news. But electricity problems are like snowflakes. No two snowflakes are alike. Different people often need different solutions for problems that are deemed to be electricity related.Adaamz wrote: β14 Apr 2022, 07:49Hey I'm having the same problem , I know this is an old post and you probably fixed that problem already , I'm hoping you will answer and tell me how , because I literally changed everything possible untill I realised its a Electricity related problem , thanks in advance:)
Also, it's kind of a recommended etiquette to present convincing evidence that your problem is, indeed, of course electricity related. Due to this reason, we ideally suggest that first-posters lurk longer and wait to post in the EMI forum. Until new posters can spend the time to write a very long multiple-page post.
Forum Rules wrote:ββ1. Rule #1: Be Nice. This is published forum rule #1. Even To Newbies & People You Disagree With!
ββ2. Please report rule violations If you see a post that violates forum rules, then report the post.
ββ3. ALWAYS respect indie testers here. See how indies are bootstrapping Blur Busters research!
BFC
I have PCIE spread spectrum in my bios and if i enabled problem solved?yonaxsangi wrote: β18 Apr 2021, 10:56Ok hello guys first of all sorry for my english its not good but ill try my best to help for people who have this annoying electricity problem.
BFC
Hi dude which setting are you talkin about for "255" i read all comms but i cant figured it outalexander1986 wrote: β21 Apr 2021, 14:07ahh I see well I wish you good luck sir, am still trying to figure out best way to just make this single change to 6% from 1.5% default value and then reflash..blackmagic wrote: β21 Apr 2021, 09:14ye i do many pretty stupid things here...
but i have good hope to make this board work again...
i already order a eeprom flash bios usb with clip only 12 euros and watched some youtube tutorials where guys manage to flash/reflash on that way there bioses and make it work for the new cpu where boards dont supported before and bios update was need...
gonna then report tomorrow if i manage to recover the black screen on that way...
the 255 value is for intel ICC spread%...
@yonaxsangi said that in one of his comments on page 1...
if I can ask just for some extra info, what did you use exactly to bios file and then reflash?, did you use AMIBCP patched version to edit the file, then rename it to original name and put on USB + flash from normal bios flashing utility in BIOS after boot?
because maybe I could use your method but not remove any strings or put the 255 value, only put the 6% on rfi spread spectrum instead of 1.5% and pray it works![]()
x7007
Hey can you help also with Asrock Z690 Extreme WIFI 6e?Plznoinputlag wrote: β25 Feb 2022, 15:59yeah we can go teamviewer ill done it for youwadge wrote: β25 Feb 2022, 15:48Plznoinputlag wrote: β25 Feb 2022, 14:35u can edit your bios with scewin and just restart your pc without even going to bios. its better than all this modification and flashing bios
Do you have any guide on how to do it ?
Tea
I also have a mouse problem, but because of the language barrier, I am not sure whether I have the same problem as them. It feels similar but not quite similar, which gives me a headache. Can you tell me if the Chief can detect whether I have a power problem?Chief Blur Buster wrote: β14 Apr 2022, 12:50I hate to be the bearer of bad news. But electricity problems are like snowflakes. No two snowflakes are alike. Different people often need different solutions for problems that are deemed to be electricity related.Adaamz wrote: β14 Apr 2022, 07:49Hey I'm having the same problem , I know this is an old post and you probably fixed that problem already , I'm hoping you will answer and tell me how , because I literally changed everything possible untill I realised its a Electricity related problem , thanks in advance:)
