Re: [EMI] 1500mV When computer is running!!!
Posted: 03 Mar 2023, 07:02
Yeah I mean the lag will shortly then comes back fast when you do those things like not opening it for couple of days or reinstall windows or etc etc, it will fix lag for couple of hours then will come back fast, this is my experience and stuff I heard from others but yeah very bizzare things tbhdervu wrote: ↑03 Mar 2023, 05:21By saying "fully settles in and then can't be fixed" do you mean that it is not working better even if you disconnect PC completely for whole day or more and then connect again?assombrosso wrote: ↑03 Mar 2023, 02:08In a bad location, what we noticed is, electricity affects components gradually until lag fully settles in and then can’t be fixed, that should take around 6-9 days to fully settle in, so be ready, god bless.KingAzar wrote: ↑03 Mar 2023, 00:27Here is what's going onThatweirdinputlag wrote: ↑02 Mar 2023, 16:58
That's actually pretty neat! You ended up plugging the filters back to back?
Did you try gaming while the meter is on? Can you also do more measurements at different times/days? No need for a video ofc, just a follow-up..
I guess for you now the testing phase begins, 3-4 weeks should be optimal. Plus you still have 2 more filters on the way..
I now have 4 filters and the gain is not huge but still good to see. The best configuration on a small single circuit power bar would be 2 + 2 and have your pc connected in the middle. Now I am between 50 to 65mV with, smart light ON, 4 phone charging, dimmer light on: Video
Gaming-wise, all my mice are very responsive, I don't even know which one to use, the floating lag feeling has been gone since I went from 1500mV to 120mV and now at 55mV, it feels the same. In-game experience is also great, I have more time to react when my ping is on the good side (depending on which server I play) but even on high ping (65) I still do things that were head-hurting to accomplish before!
To be honest I am happy for now! I will keep you posted in the next coming weeks! I decided to return the Furman, this 4 little guys are doing great
