Page 18 of 18
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Posted: 16 Jan 2026, 15:58
by MK92
Of course it didn't help, the problem is not a PC-->monitor signal as such, its your GPU / CPU data corruption while rendering and processing the information, so by the time the packet of information leaves MOBO to travel into the output (monitor), the data is already corrupted, so you can buy a DP cable for 500€ if you want and this won't help...this is literally like your car would have punctured tyre, and you would try to "fix" this by buying a new car windows.
If this actually worked for you, then you are among 1% of people which simply had damaged DP cable and therefore laggy data transfer, and now you think this is the entire fix for our problems.
Posted: 17 Jan 2026, 00:36
by Slender
MK92 wrote: ↑16 Jan 2026, 15:58
where i can read about it?
Posted: 17 Jan 2026, 04:17
by MK92
It's logical explanation, your monitor just displays what is rendered from CPU and GPU, so why would DP or HDMI cables be the problem?
+12V and +5V rails are not getting clean electricity, then the CPU and GPU activates their error-correcting protocol to prevent a system crash = output delay.
Now the funny part is where does this crap voltage comes from, because a good PSU, in combination with EMI-filtered surge protector, should easily handle dirty electricity...but we still get this problems, so apparently the electricity must by-pass the PSU and somehow enters the PCI slots from modem, monitor, speakers etc.
Posted: 17 Jan 2026, 08:43
by Slender
MK92 wrote: ↑17 Jan 2026, 04:17
because battery mode didnt fix issue.
issue appers and dissapers at the same time ac / battery mode.
Posted: 17 Jan 2026, 10:15
by MK92
Not for me, if I run laptop on the battery its perfectly fine, but if I remove the battery and run with a power cord directly into the wall socket it works like crap.
Posted: 15 Aug 2026, 17:29
by mustafaiq
[[/i] I bought a fiber optic display port and the problem persists.
Posted: 16 Aug 2026, 06:30
by ablemor
That's because there's a chip at the end of the optical cable, + there can still be copper in it this way.
Posted: 16 Aug 2026, 11:01
by Kyousuke
mustafaiq wrote: ↑15 Aug 2026, 17:29
same, I bought hdmi 2.1 optic cable.Except the problem actually fixed for 30-1 hour gaming, then the trauma came back like it had never gone away.
