Posted: 14 Jan 2021, 12:32
we have shity internet guys go buy better internet guy instatly become god again woaaaah how easy is thatmello wrote: ↑11 Jan 2021, 10:12How many times i need to say that ? As long as someone has these problems outside of online gaming, then obviously this has nothing to do with the internet. I do not contest that. These are obviously two separate issues. What i'm saying thought, is that some people *might* be going crazy about this whole thing and start thinking and convincing themselves that they have also problems outside of online gaming. There is a very high possibility of that being the case, due to how human brain works. As i said, i have seen in the last ~20 years, people making all kinds of ridiculous claims regarding certain bios settings, windows settings, game setting - "improving" or "fixing" things, making gaming "better", when in reality 95% of these "tips & tricks" are total and meaningless garbage. Same thing when it comes to hardware, peripherals, cables etc. Have you ever heard about the audiophile market ? Many audiophiles and "special high quality equipment" promoters make many claims about improvements in sound etc. What the reality looks like ? When you put it against an AB test, they usually fail to tell the difference and 'what is what'. The power of the human mind.nuggify wrote: ↑10 Jan 2021, 15:41That is funny. I have a discord of near 70 members with this issue, and it is certainly not internet. You can fully disconnect internet and its all still there. The only person that fixed it (like fully mitigated the symptoms- we still have no idea what the source is) did so with chemical grounding. He had all the classic symptoms of desync and input lag.
Had seen that argument million times already. Someone changes something, things magically improve, but after some time (same or next day usually) things get worse once again. I have been throught the exact same things in the past, making all kinds of both, dumb and smart, changes, feeling an improvement but eventually problem came back with full force. This happens because this problem fluctuates in severity on its own, which is very deceitful. Even if you do nothing, the problem goes away, comes back on its own and changes in severity without any interventions. Also, i'm also unable to know what issues other people are having and perceiving. So, we might be talking about the same, similar or completely different things.nuggify wrote: ↑10 Jan 2021, 15:41Maybe you should listen to me and consider what I have to say. That thread nicko started about net issues, he got a dedicated line (T1 connection) and still same problem. Then he started to realize it simply was not internet. He lifted ground prong to PC and the issue improved a ton (temporarily).
I can make this problem go away in 15 seconds, by switching the internet from one to another. Same server, same people, same map, everything is the same, an near immediate disconnection & reconnetion (15 seconds difference) to the server. One connection (Fibre 1 Gb/s both ways, ~10ms) = problem is constant, only the severity of it changes all the time, second connection (mobile internet, don't know the speed, most likley the usual ~20-80 Mb/s, ping ~25ms) = problem is literally non existent. I'm sorry, but you can't beat this with anything you do, say or hypothesize.
