News on the ROG Swift (PG278Q)
omgBlur
Re: News on the ROG Swift (PG278Q)
Post by omgBlur » 11 Aug 2014, 09:29
Linus just posted his review of the ROG Swift, while not as detailed as the other reviews out there, it's a neat video from a casual perspective.
Black Octagon
Post by Black Octagon » 11 Aug 2014, 09:51
Ryan Shrout of PC Perspective has also posted a review: http://www.pcper.com/reviews/Graphics-C ... -2560x1440
Alas, not too much about ULMB
kasakka
Post by kasakka » 11 Aug 2014, 09:57
mello wrote:I wanted to buy PG278Q but after reading about "Out of Range" problem that was reported by several people on asus rog forums i think i will hold off. The funny thing is that i have BenQ XL2420T (rev 2.0) and i experienced exactly the same "bug". I switched to DisplayPort cable 2 months ago and everything was working perfectly, but recently "Out of Range" message started appearing from time to time, and after about 2 weeks it is no longer possible for me to use DisplayPort at 144Hz, it just doesn't work anymore. I was forced to go back to DVI cable to be able to use 144Hz again.
It's an Nvidia driver issue I believe. I've had it with my PG278Q and from what I can tell it only happens @ 60 Hz. As the button on the display cycles the refresh rates, when it hits 60 Hz you get a blank screen. It seems the display has a hard time accepting the refresh rate change command when it's stuck like this too as even moving from 120 Hz to 144 Hz takes several presses and wait whereas normally it is nearly instant.
So far the fix has been clean reinstalling Nvidia drivers, disconnecting DP cable and reconnecting. If the 144 Hz option is missing, try adding it via Nvidia control panel using "Custom resolution". For me it simply adds it to the native res instead of creating a custom resolution. For some reason in Screen resolution -> Advanced 144 Hz is available but only works with 256 colors.
I also tried using the Display Driver Uninstaller from https://forums.geforce.com/default/topi ... 08-10-14-/ and reinstalled drivers. So far everything seems to work.
I really hope Nvidia fixes this quickly as the refresh rate button is a nice way to quickly switch between ULMB and no-ULMB (as it's not available at 144 Hz).
omgBlur
Post by omgBlur » 11 Aug 2014, 10:16
Black Octagon wrote:Ryan Shrout of PC Perspective has also posted a review: http://www.pcper.com/reviews/Graphics-C ... -2560x1440
Great review!
Towards the end I noticed this piece.
Could it be true?!?!?! The 26 is the magical date? Does that mean it's going to pop up on Amazon,NewEgg, and TigerDirect with a "Add to Cart" button?
glenster
Post by glenster » 11 Aug 2014, 12:33
IwantGSYNC
Post by IwantGSYNC » 11 Aug 2014, 12:47
Noone tested this monitor in LA Noire, NFS Rivals or any other game limited to 30 fps :x Does G-Sync work in such games? I guess even if it does, it is still impossible to use it with ShadowPlay because ShadowPlay has small 2-3% performance hit that will drop the framerate below 30 fps.
Haste
Post by Haste » 11 Aug 2014, 14:04
I haven't tried these.
On the other hand, I don't consider games locked at 30fps worth playing.
Monitor: Gigabyte M27Q X
Turboman750
Post by Turboman750 » 11 Aug 2014, 15:26
I think you are a little bit confused. If a game is locked at 30 fps, having a g-sync enabled monitor will have no effect (g-sync benefits variable FPS).
Also, Shadowplay has a small 2-3% 'GPU' performance hit... NOT FPS performance hit, if your gpu is capable of pushing 60 fps then you wont see your game drop below 30 fps with shadowplay enabled - even if the game is locked at those frame rates.
PoWn3d_0704
Post by PoWn3d_0704 » 11 Aug 2014, 16:40
I cannot wait for Chiefs review.
All the reviews are killing me. I just want this monitor! I even bought a 780Ti to help my fps at 1440p.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
Haste
Post by Haste » 11 Aug 2014, 18:53
PoWn3d_0704 wrote:I cannot wait for Chiefs review.
well I have the monitor on my desk right now. All I can tell you is that 1440p 144Hz is really nice. :D
