obviously if you goona try ground our self with anti-static wrist strap or something else its not gonna work
source is electromagnetic field caused by you
more specific low frequency one which is interrupt your rams which has under control all movements to be synced
if you are under stress hormon which is generate low frequency magnetic field you not gonna have good perception when you sit in front of pc
what people are doing here is very dangerously because reality is placebo can fix all your problem (but better is fix your life from scratch what ever happens in your life must be fixed because you dont wanna live under stress hormon which is generate negative magnetic field )
you can have literally somebody which you belive to tell you this is that is gonna fix your problem and if you belive him enough you will get improvement instantly
but if you not gonna belive in anything you will never get any improvement for long enough and you will always suffer from degrade situation no matter what you change
you can found what ever source and object about that and its up to you if you will belive or not but we alrdy now that nobody knows about what we are talking about we cant even recorded that properly because is our perception not everybody
https://www.frontiersin.org/articles/10 ... 84412/full
https://fb.watch/g8VN5ZTddW/
