This fixes the electrical input lag
Locked
getuliofmj
Re: This fixes the electrical input lag
Post by getuliofmj » 13 Dec 2022, 19:34
texre wrote:
13 Dec 2022, 18:54
The transformer gets infected as well worked good for only 1 day
What transformer model are you using?
F1zus
Post by F1zus » 13 Dec 2022, 21:25
Skeezv wrote:
12 Dec 2022, 12:03
This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
https://aliexpress.ru/item/400034986321 ... b7340abb90
First, it hasn't been tested yet.
Secondly, you did not personally try it, but read all sorts of nonsense and threw a link here.
Do you want people to waste money?
First you need to check it yourself, and then post links.
itsjNs
Post by itsjNs » 13 Dec 2022, 21:52
texre wrote:
13 Dec 2022, 18:54
Hey I thought you fixed the input lag by going OFF GRID can you tell me your experience with solar panel system?
Did you fix it and just trying to figure out what causing the issues on grid? or you never fixed it completly?
Post by Chief Blur Buster » 13 Dec 2022, 23:57
texre wrote:
13 Dec 2022, 18:54
Transformers don't get "infected". Something perhaps may happens after a while (e.g. cyclic interference, damage, etc), but it's not the word "infected".
texre
Post by texre » 14 Dec 2022, 11:09
itsjNs wrote:
13 Dec 2022, 21:52
texre wrote:
13 Dec 2022, 18:54
Going off grid completely fixes it. Unless you charge the battery with your electricity. Then you have to wait for all bad energy to leave. I want a fix on grid so I can play longer and it’s also winter time rn so the sun isn’t charging the batteries fast enough for me.
Sqnax17
Post by Sqnax17 » 14 Dec 2022, 11:47
Skeezv wrote:
12 Dec 2022, 12:03
the transformer mentioned, does it work or not? where is the evidence? evidence?
MegaMelmek
Post by MegaMelmek » 14 Dec 2022, 12:52
Sqnax17 wrote:
14 Dec 2022, 11:47
Skeezv wrote:
12 Dec 2022, 12:03
Work like what? Like fixing input lag - what is input lag? show me evidence of input lag? I need evidence…
Sqnax17
Post by Sqnax17 » 14 Dec 2022, 15:01
MegaMelmek wrote:
14 Dec 2022, 12:52
Sqnax17 wrote:
14 Dec 2022, 11:47
Skeezv wrote:
12 Dec 2022, 12:03
well... if they're saying it fixes the input lag caused by bad electricity, show us the truth.
F1zus
Post by F1zus » 14 Dec 2022, 16:55
Sqnax17 wrote:
14 Dec 2022, 11:47
Skeezv wrote:
12 Dec 2022, 12:03
There is no proof and never will be. He just read a message from 1 person who bought this transformer and created a topic here. But as it turned out later, the input lag still sometimes appears even with a transformer. Therefore, I advise you not to throw away money.
dervu
Post by dervu » 14 Dec 2022, 17:43
There is something that toroidal transformers don't like, DC component. If you can hear it buzzing, then it means there is some DC. Then performance drops. I do not know if performance drop is high enough to cause any issues, maybe if someone bought low VA and is borderline enough?
Another thing worth considering is if nothing is going through ground cable, since it is the only cable having direct connection in balanced toroidal transformer. Myself I decided to work with ungrounded, if it fails at least I will know whatever was causing it, went through live or neutral that completely goes through transformer.
Locked
