FreeSync isn't working properly on my Gigabyte M28U
Re: FreeSync isn't working properly on my Gigabyte M28U
Post by Chief Blur Buster » 05 Jun 2023, 19:13
lextra2 wrote: ↑
05 Jun 2023, 16:28
Freesync has stutters when you go below its minimum. Example: Range 48 - 120 Hz = You will stutter when you drop below 48 FPS.
This is especially true for 120Hz FreeSync.
Larger VRR ranges (e.g. 48-240Hz) will have fewer LFC stutters than smaller VRR ranges.
For divergence between gametime:photontime -- the stutter penalty is 1/120sec for LFC on a 120Hz VRR display, and the LFC stutter penalty is as little as 1/240sec on a 240Hz VRR display. So wider VRR ranges really help.
