Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
loccomacco
Post
by loccomacco » 07 Apr 2023, 16:16
asappppp wrote: β07 Apr 2023, 12:12
Update: While waiting for my online UPS order, I wanted to try playing again using a power station with a battery. Mouse was floaty again, even though I hadn't used my PC overnight. So I think my problem is related either to EMI or software/hardware, and since I've tried a lot of software tweaks and changed two PCs, I tend to believe it's 90% EMI. An online UPS won't help me in this case and it's just a waste of money, so I canceled the order.
Probably trying to use the very same PC at another apartment, even in offline mode, would be a good idea, but I don't have time for this. So I will stop investigating it further but will be checking this forum, maybe somebody else will be able to crack it. Good luck.
That's good to hear and bad at the same time, good for not wasting your money and bad for we couldn't find that if online UPS helps or not.
Btw if you really wanna waste your money, you can waste it on better options.
