same, delete smooth is best for me.Syykfk wrote: ↑07 Aug 2023, 02:51I used MarkC's Remove Mouse Acceleration. So my SmoothMouseXCurve value is not the same as the default. But now I removed SmoothMouseXCurve and SmoothMouseYCurve. i feel better.wilkN wrote: ↑05 Aug 2023, 07:35What are you using in your SmoothMouseXCurve that doesnt seem default?Syykfk wrote: ↑28 Jul 2023, 08:57I am a player from China and I am currently a player of Valor Mythos 3.
I really like this forum and I have learned a lot so I would like to share my knowledge as well. One thing I would like to share is a registry change. It may fix your mouse acceleration/"floating" feeling problem.
First go to the registry and go to the following directory: HKEY_CURRENT_USER\Control Panel\Mouse
Create a new string value in Mouse and name it MouseAccel, set its value to 0 (as in Figure 1)批注 2023-07-28 214714.png, then restart your computer and feel the difference it makes.
You can also change the value of MouseSpeed to -, the correct minus sign is to the right of the number 0 on the keyboard, or you can choose to copy my "-"." MouseSpeed" is the "Improve pointer accuracy" in the Mouse Properties in System Settings, 0=unchecked, 1=checked. fps gamers usually choose to leave it unchecked, and changing it to "-" in the registry will give you a different feel.
The above two changes do not conflict or oppose each other, they have a stacked result. Together they will affect the way you feel.
If you don't like the feeling, just delete the MouseAccel string or change MouseSpeed back to 0.
I assure you, this is not a placebo and it will definitely affect your mouse speed.
Another registry change has to do with display scaling. It is associated with (Figure 2)批注 2023-07-28 214750.png
First go to the path HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\GraphicsDrivers\Configuration
There are many folders in there, click on Edit, then Find, type in Scaling and press F. (It's okay to delete the bunch, it will be generated automatically after reboot).
Modify only the values of the scaling ratio. Fullscreen=3, Aspect Ratio=4, No Scaling=2,0 are the ones I personally tested and downloaded the most.
This modification also affects the feel, it is recommended to backup the registry before modification. Just in case you can't adapt.
This may solve the mouse acceleration problem that's plaguing you!
- Slender
Re: This may solve the mouse acceleration problem that's plaguing you!
This is actually new to me -- which games turn Enhanced Pointer Precision back on via an API (arrgh, I will hate that game if they actually use that infernal API) despite Control Panel having it off? I don't think Valorant uses it though.
I guess that's what the hyphen does, to force-it-off, forcing it to ignore games that force-turn-on Enhanced Pointer Precision...
In an ideal world, rawinput would bypass all that, but I've seen weird sheningians behind the scenes that interact badly -- and which may make these tweaks placebo to some (because their system was okay), and these tweaks actually work (because there was actually an issue).
Please keep the data coming. I still like to study tweaks that work even for just 10% of users. In all the noise, there's often still a signal.
holiday
Popular old games that has enhanced pointer precision coded in are half-life and cs 1.6 before the 2013 update with raw input.Chief Blur Buster wrote: ↑08 Aug 2023, 04:20This is actually new to me -- which games turn Enhanced Pointer Precision back on via an API (arrgh, I will hate that game if they actually use that infernal API) despite Control Panel having it off? I don't think Valorant uses it though.
That’s why the cpl, cheese, markc etc fix came.
In half-life and cs 1.6 raw input works as it should. Csgo rawinput from 2012 from my experience not as different smoothmousecurves changes the mouse feel for me.
I researched this stuff with mouse acceleration and especially with cs almost 2 years if you need further information.
widow13
I'd love to hear if you ever found a solution.holiday wrote: ↑08 Aug 2023, 11:08Popular old games that has enhanced pointer precision coded in are half-life and cs 1.6 before the 2013 update with raw input.Chief Blur Buster wrote: ↑08 Aug 2023, 04:20This is actually new to me -- which games turn Enhanced Pointer Precision back on via an API (arrgh, I will hate that game if they actually use that infernal API) despite Control Panel having it off? I don't think Valorant uses it though.
I've been experiencing mouse changes/floaty mouse with Valorant/csgo since like forever and I've almost tried everything.
holiday
No it’s in the engines mouse code. I tried a lot but never solved the problem. Let’s hope they reworked their mouse code in source 2.widow13 wrote: ↑08 Aug 2023, 13:42I'd love to hear if you ever found a solution.holiday wrote: ↑08 Aug 2023, 11:08Popular old games that has enhanced pointer precision coded in are half-life and cs 1.6 before the 2013 update with raw input.Chief Blur Buster wrote: ↑08 Aug 2023, 04:20This is actually new to me -- which games turn Enhanced Pointer Precision back on via an API (arrgh, I will hate that game if they actually use that infernal API) despite Control Panel having it off? I don't think Valorant uses it though.
I didn’t played much valorant so I don’t know if there is also a problem.
widow13
Nah problem in valorant is way bigger, unless there is something else happening with my electricity or windows/bios that I am not aware of.holiday wrote: ↑09 Aug 2023, 05:45No it’s in the engines mouse code. I tried a lot but never solved the problem. Let’s hope they reworked their mouse code in source 2.widow13 wrote: ↑08 Aug 2023, 13:42I'd love to hear if you ever found a solution.holiday wrote: ↑08 Aug 2023, 11:08Popular old games that has enhanced pointer precision coded in are half-life and cs 1.6 before the 2013 update with raw input.Chief Blur Buster wrote: ↑08 Aug 2023, 04:20
awakencs
Can i have your wechat pleaseSyykfk wrote: ↑28 Jul 2023, 08:57I am a player from China and I am currently a player of Valor Mythos 3.
howcani
Hi what did you mean u need to change all scaling to 2(No scaling) or what?Syykfk wrote: ↑28 Jul 2023, 08:57First go to the path HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\GraphicsDrivers\Configuration
Syykfk
mmmmsamaawakencs wrote: ↑10 Apr 2024, 14:02Can i have your wechat pleaseSyykfk wrote: ↑28 Jul 2023, 08:57I am a player from China and I am currently a player of Valor Mythos 3.
Syykfk
yes, change all to "2" or "0"howcani wrote: ↑13 Apr 2024, 16:46Hi what did you mean u need to change all scaling to 2(No scaling) or what?Syykfk wrote: ↑28 Jul 2023, 08:57First go to the path HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\GraphicsDrivers\Configuration
Then feel which one suits you better
