G-Sync causing Battlefield 4 crashes
Re: G-Sync causing Battlefield 4 crashes
Hi ManualG,
I tried BF4 (ultra, high, medium, and low video settings) in 1080p at 144hz, 120hz, and 60hz and the problem still persists. The entire pc also crashed a number of times during the game when g-sync is enabled.
Neo_Bogard
My monitor is backordered, but I jumped on board despite this issue. I know I'll regret it.
But I'm hopeful that Nvidia can address any SLI/g-sync issues with driver updates. That said, this technology isn't exactly brand-spanking-new. There have been a number of g-sync users for several months now, and several tests run on Battlefield 4. I'm a little disappointed that this stuff is only coming to light now. Customers should not be beta testing advertised features several months after launch. That's for video game developers!
- ManuelG_NVIDIA
ardi wrote:Hi ManualG,
Thanks for the update
Please send me a PM if I fail to keep up on replying in any specific thread.
- ManuelG_NVIDIA
We have been unable to reproduce the crashes in Battlefield 4 with G-Sync enabled. Any other information that can help us repro this about your system? Have you tried to do a repair of the game through Origin?
Is there debug logging that can be enabled?
Hi Manuel,
Thank you kindly for taking the time to look through the forums. Hoping that you will see this and be able to pass it on to your technical staff for further review.
I too am experiencing stuttering in bf4 with sli/g-sync enabled which is not leading to a good experience whilst utilising your products.
Briefly I am running:-
-intel 2600k cpu
-16 gig ddr4 ram
-gigabyte 770 x 2 @ stock speeds
-asus swift g-sync monitor
-Freshly installed 340.52 drivers.
To reproduce excessive stuttering in battlefield 4:-
- g-sync enabled in nvcp
- sli enabled in nvcp
- v-sync disabled @ 60hz @ 1440p in game
Whilst the game is running at 120/144hz the effects are much harder to spot, but there is occasional stuttering and when there are fps drops from 110 to say 90/80 it is very noticeable.
By disabling SLI, g-sync would produce game play experience similar to 144hz.
Is this a driver related issue or can you make recommendations to resolve? I am able to create a short clip of this and upload this if this will help.
Thanks
Matt
-intel 2600k cpu
-16 gig ddr4 ram
Thanks
Matt
Will post DXDiag information this evening.
Turboman750
I'm not sure if this is relevant to this thread, but keep in mind that Rivatuner causes bf4 to crash if you are using the 64 bit version of bf4.
try to change your bf4 settings to 32 bit and see if that helps. I noticed many osd apps give bf4 trouble.
Also have a lot of stuttering with sli and gsync
670 sli
3770k at 4.5
8gb DDR3 1600
670 sli
3770k at 4.5
8gb DDR3 1600
have tried in x86 mode with sli and still stuttering
please find attached didiag output
System Information
Time of this report: 9/13/2014, 09:45:34
Machine name: MATT-PC
Operating System: Windows 8.1 Pro with Media Center 64-bit (6.3, Build 9600) (9600.winblue_gdr.131030-1505)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 11/01/12 09:41:04 Ver: 36.02
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16352MB RAM
Page File: 3332MB used, 29403MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Display Tab 3: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 770
Manufacturer: NVIDIA
Chip type: GeForce GTX 770
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_1184&SUBSYS_36031458&REV_A1
Display Memory: 3999 MB
Dedicated Memory: 1951 MB
Shared Memory: 2048 MB
Current Mode: 2560 x 1440 (32 bit) (59Hz)
Monitor Name: ASUS PG278Q
Monitor Model: ROG PG278Q
Monitor Id: ACI27B1
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: Displayport External
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.4072 (English)
Driver Version: 9.18.13.4072
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 8/13/2014 07:50:18, 17552560 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-52C4-11CF-0078-0E161CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1184
SubSys ID: 0x36031458
Revision ID: 0x00A1
Driver Strong Name: oem9.inf:0f066de34a958ed1:Section031:9.18.13.4072:pci\ven_10de&dev_1184
Rank Of Driver: 00DA2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_VLD DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: S23B300
Monitor Id: SAM08C9
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HD15
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1920 x 1080 (32 bit) (30Hz)
Monitor Model: SAMSUNG
Monitor Id: SAM02B2
Native Mode: 1280 x 720(p) (60.000Hz)
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (2- High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_10438469&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.03.9600.16384 (English)
WHQL Logo'd: Yes
Date and Size: 8/22/2013 04:38:21, 395776 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (7- Logitech G930 Headset)
Default Sound Playback: No
Default Voice Playback: Yes
Hardware ID: USB\VID_046D&PID_0A1F&REV_0100&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
WHQL Logo'd: Yes
Date and Size: 8/22/2013 04:37:34, 121088 bytes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: SAMSUNG-4 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0040&SUBSYS_14583603&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.03.0030.0001 (English)
WHQL Logo'd: Yes
Date and Size: 8/13/2014 07:50:18, 197408 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (7- Logitech G930 Headset)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Audio Controls
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0x0A1F
FF Driver: n/a
Device Name: Controller (XBOX 360 For Windows)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x028E
FF Driver: n/a
Device Name: Corsair Vengeance M60 Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B30
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04D9, 0x0174
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1C2D
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 8/22/2013 05:43:34, 422240 bytes
| Driver: usbd.sys, 8/22/2013 05:43:33, 28000 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: USB\Class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| Service: kbdhid
| Driver: kbdhid.sys, 8/22/2013 04:39:13, 32256 bytes
| Driver: kbdclass.sys, 8/22/2013 05:43:45, 58208 bytes
| Service: kbdhid
+ HID-compliant mouse
| Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| Service: mouhid
| Driver: mouhid.sys, 8/22/2013 04:39:13, 30208 bytes
| Driver: mouclass.sys, 8/22/2013 05:43:45, 51040 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 38.9 GB
Total Space: 114.1 GB
File System: NTFS
Model: KINGSTON SVP200S37A120G
Drive: D:
Free Space: 39.8 GB
Total Space: 114.5 GB
File System: NTFS
Model: Corsair Force 3 SSD
Drive: E:
Free Space: 123.7 GB
Total Space: 953.9 GB
File System: NTFS
Model: SAMSUNG HD103UJ
Drive: F:
Free Space: 87.7 GB
Total Space: 238.5 GB
File System: NTFS
Model: Samsung SSD 840 EVO 250GB
Drive: H:
Free Space: 513.3 GB
File System: NTFS
Model: Seagate Expansion SCSI Disk Device
Drive: G:
Model: ATAPI iHAS324 B
Driver: c:\windows\system32\drivers\cdrom.sys, 6.03.9600.16384 (English), 8/22/2013 01:46:35, 164352 bytes
System Devices
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_84691043&REV_05\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.03.9600.16384 (English), 8/22/2013 04:38:38, 78336 bytes
Name: 2nd Generation Intel(R) Core(TM) Processor Family DRAM Controller - 0100
Device ID: PCI\VEN_8086&DEV_0100&SUBSYS_844D1043&REV_09\3&11583659&0&00
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_844D1043&REV_04\3&11583659&0&B0
Driver: C:\Windows\system32\DRIVERS\HECIx64.sys, 8.01.0000.1263 (English), 7/2/2012 15:16:02, 62784 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_844D1043&REV_05\3&11583659&0&E8
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:33, 89952 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:34, 439136 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:34, 422240 bytes
Name: Renesas USB 3.0 eXtensible Host Controller - 0096 (Microsoft)
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_84131043&REV_04\4&108ABD8A&0&00E4
Driver: C:\Windows\system32\DRIVERS\UCX01000.SYS, 6.03.9600.16384 (English), 8/22/2013 05:43:33, 189792 bytes
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 6.03.9600.16459 (English), 12/11/2013 04:03:19, 325464 bytes
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\5&D93DF5B&0&1800E6
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.03.9600.16384 (English), 8/22/2013 04:38:15, 231424 bytes
Name: NVIDIA GeForce GTX 770
Device ID: PCI\VEN_10DE&DEV_1184&SUBSYS_36031458&REV_A1\4&80E7924&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 442312 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 8/13/2014 07:50:18, 1197380 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nvic.inf_amd64_f9460a1e20a30253\NvCplSetupInt.exe, 1.00.0001.0000 (English), 8/13/2014 07:50:18, 83133616 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 164544 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 8/13/2014 07:50:18, 13088 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 113056 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 191312 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 8/13/2014 07:50:18, 13088 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 130536 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 8/13/2014 07:50:18, 21904 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 8/13/2014 07:50:18, 843720 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.4072 (English), 8/13/2014 07:50:18, 228128 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 8/13/2014 07:50:18, 56689 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 340936 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 648152 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 8/13/2014 07:50:18, 61728 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 8/13/2014 07:50:18, 76232 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 12879304 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0013.4072 (English), 8/13/2014 07:50:18, 903128 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0013.4072 (English), 8/13/2014 07:50:18, 944928 bytes
Driver: C:\Windows\system32\NvIFROpenGL.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 391640 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 6.14.0013.4072 (English), 8/13/2014 07:50:18, 502048 bytes
Driver: C:\Windows\system32\nvapi64.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 3196864 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 22994208 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 13837320 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.4072 (English), 8/13/2014 07:50:18, 4246816 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 17552560 bytes
Driver: C:\Windows\system32\nvinfo.pb, 8/13/2014 07:50:18, 26155 bytes
Driver: C:\Windows\system32\nvinitx.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 166616 bytes
Driver: C:\Windows\system32\nvoglshim64.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 354064 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 31514568 bytes
Driver: C:\Windows\system32\nvopencl.dll, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 13925864 bytes
Driver: C:\Windows\system32\nvumdshimx.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 965360 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 18627368 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0013.4072 (English), 8/13/2014 07:50:18, 870176 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0013.4072 (English), 8/13/2014 07:50:18, 909256 bytes
Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 347936 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 6.14.0013.4072 (English), 8/13/2014 07:50:18, 417752 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 2814704 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 15296456 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 11223648 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0013.4072 (English), 8/13/2014 07:50:18, 3988952 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 14492936 bytes
Driver: C:\Windows\SysWow64\nvinit.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 146528 bytes
Driver: C:\Windows\SysWow64\nvoglshim32.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 305648 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 24200136 bytes
Driver: C:\Windows\SysWow64\nvopencl.dll, 8.17.0013.4072 (English), 8/13/2014 07:50:18, 11284944 bytes
Driver: C:\Windows\SysWow64\nvumdshim.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 846880 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 9.18.0013.4072 (English), 8/13/2014 07:50:18, 16123408 bytes
Driver: C:\Windows\system32\nvdispco6434072.dll, 2.00.0041.0004 (English), 8/13/2014 07:50:18, 1891272 bytes
Driver: C:\Windows\system32\nvdispgenco6434072.dll, 2.00.0019.0002 (English), 8/13/2014 07:50:18, 1541080 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_844D1043&REV_B5\3&11583659&0&E6
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:32, 285536 bytes
Name: Intel(R) P67 Express Chipset Family LPC Interface Controller - 1C46
Device ID: PCI\VEN_8086&DEV_1C46&SUBSYS_844D1043&REV_05\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:49, 17248 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_844D1043&REV_05\3&11583659&0&D0
Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_84131043&REV_04\4&DDEC341&0&00E1
Name: Intel(R) 82579V Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_849C1043&REV_05\3&11583659&0&C8
Driver: C:\Windows\system32\DRIVERS\e1i63x64.sys, 12.06.0047.0000 (English), 6/18/2013 07:45:26, 460288 bytes
Device ID: PCI\VEN_10DE&DEV_1184&SUBSYS_36031458&REV_A1\4&38AC18AC&0&0009
Name: Xeon E3-1200/2nd Generation Intel(R) Core(TM) Processor Family PCI Express Root Port - 0101
Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_844D1043&REV_09\3&11583659&0&08
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_197B&DEV_2362&SUBSYS_84601043&REV_10\4&20221DEA&0&00E3
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:31, 14688 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:32, 48992 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:41, 26464 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:41, 199520 bytes
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
Device ID: PCI\VEN_8086&DEV_1C12&SUBSYS_844D1043&REV_B5\3&11583659&0&E1
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 8 - 1C1E
Device ID: PCI\VEN_8086&DEV_1C1E&SUBSYS_844D1043&REV_B5\3&11583659&0&E7
Name: Intel(R) Desktop/Workstation/Server Express Chipset SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1C02&SUBSYS_844D1043&REV_05\3&11583659&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStorA.sys, 12.08.0000.1016 (English), 8/7/2013 14:23:46, 644968 bytes
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_84771043&REV_11\4&16B16BD2&0&00E7
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:31, 107872 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1B21&DEV_1080&SUBSYS_10801B21&REV_01\4&2B6CC657&0&00E6
Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_844D1043&REV_05\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 5 - 1C18
Device ID: PCI\VEN_8086&DEV_1C18&SUBSYS_844D1043&REV_B5\3&11583659&0&E4
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_36031458&REV_A1\4&38AC18AC&0&0109
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_844D1043&REV_B5\3&11583659&0&E0
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_36031458&REV_A1\4&80E7924&0&0108
Name: Xeon E3-1200/2nd Generation Intel(R) Core(TM) Processor Family PCI Express Controller - 0105
Device ID: PCI\VEN_8086&DEV_0105&SUBSYS_844D1043&REV_09\3&11583659&0&09
Name: Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
Device ID: PCI\VEN_8086&DEV_1C16&SUBSYS_844D1043&REV_B5\3&11583659&0&E3
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.03.9600.16384
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.03.9600.16384
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.03.9600.16384
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.03.9600.16384
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.03.9600.16384
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.03.9600.16384
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.03.9600.16384
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.03.9600.16384
MS ATC Screen Decoder 1,0x00600800,1,1,scdec.dll,15.00.4545.1000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.03.9600.16384
DV Muxer,0x00400000,0,0,qdv.dll,6.06.9600.16384
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.9600.16384
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.9600.16384
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.9600.16384
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.9600.16384
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.9600.16384
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9477.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.9600.16384
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.9600.16384
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.03.9600.16384
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.16384
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.03.9600.16384
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.9600.16384
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.9600.16384
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.9600.16384
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.9600.16384
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.9600.16384
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.16384
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.9600.16384
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.9600.16384
DV Splitter,0x00600000,1,2,qdv.dll,6.06.9600.16384
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.9600.16384
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.9600.16384
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.9600.16384
Video Renderer,0x00800001,1,0,quartz.dll,6.06.9600.16384
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.9600.16384
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.9600.16384
Video Renderer,0x00400000,1,0,quartz.dll,6.06.9600.16384
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.9600.16384
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.9600.16384
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.03.9600.16384
File writer,0x00200000,1,0,qcap.dll,6.06.9600.16384
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.9600.16384
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.9600.16384
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.9600.16384
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.03.9600.16384
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.16384
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.9600.16384
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.9600.16384
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.9600.16384
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.9600.16384
Null Renderer,0x00200000,1,0,qedit.dll,6.06.9600.16384
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.9600.16384
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.03.9600.16384
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.9600.16384
Smart Tee,0x00200000,1,2,qcap.dll,6.06.9600.16384
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.16384
NetBridge,0x00200000,2,0,netbridge.dll,6.03.9600.16384
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.9600.16384
Wave Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
File stream renderer,0x00400000,1,1,quartz.dll,6.06.9600.16384
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.9477.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.9600.16384
AVI Mux,0x00200000,1,0,qcap.dll,6.06.9600.16384
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.9600.16384
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.9600.16384
File Source (URL),0x00400000,0,1,quartz.dll,6.06.9600.16384
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.03.9600.16384
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.9600.16384
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.03.9600.16384
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.9600.16384
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.9600.16384
System Information
Memory: 16384MB RAM
DxDiag Notes
Display Devices
Monitor Id: ACI27B1
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Monitor Id: SAM08C9
Output Type: HD15
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Monitor Id: SAM02B2
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
USB Devices
+ USB Root Hub
| Service: usbhub
+-+ Generic USB Hub
| | Service: usbhub
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: kbdhid
| Service: mouhid
Drive: C:
Free Space: 38.9 GB
File System: NTFS
Drive: D:
Free Space: 39.8 GB
File System: NTFS
Drive: E:
File System: NTFS
Drive: F:
Free Space: 87.7 GB
File System: NTFS
Drive: H:
File System: NTFS
Drive: G:
System Devices
Driver: n/a
Driver: n/a
DirectShow Filters
DirectShow Filters:
