Software BFI options?
Re: Software BFI options?
Post by RealNC » 06 Sep 2024, 09:13
05 Sep 2024, 21:46
Damn. Your OLED is incompatible with QFT. Maybe move the excess to the Back Porch instead of Vertical Sync and Front Porch. VRR at low frame rates uses large Back Porch, so a more compatible QFT uses a large Back Porch.
If I reduce VT and play around with porch values, I can get it to a point where it stops gliching out, but it turns out the "ELMB" option that enables BFI gets grayed out in the OSD so it can't enabled with custom timings that deviate a lot from factory timings.
I'm not bummed out about it anyway. I don't use BFI, but I still like to experiment with it :mrgreen:
My only use case for BFI would be 60Hz retro games, but that's not supported anyway. But since Retroarch added BFI anyway, I'm good. Also, the OLED doesn't appear to have the image retention issues that I had with the IPS panel in Retroarch BFI.
