Logical Problem Solving Way
timecard
Re: Logical Problem Solving Way
Post by timecard » 21 Oct 2023, 11:01
Can you see if you're getting any significant debounce latency? Some keyboards won't go lower then ~22ms on this test because of it (razer huntsman elite), the newer huntsman elite v2 can change this setting.
https://blog.seethis.link/scan-rate-estimator/
The easiest way to get low results is to lightly tap/flick the edge of the key so key up/down state is near instantaneous. Maybe it'll provide additional insights into your issues.
InputLagger
Post by InputLagger » 25 Dec 2023, 22:07
Mods, why not to move this topic to input lag forum, so more people can find it and give something positive to these tests methodology ?
velorias
Post by velorias » 26 Dec 2023, 03:33
InputLagger wrote: ↑
25 Dec 2023, 22:07
Good idea. But who can do it? Admin only? I don't think, I have permissions for this.
delve
Post by delve » 27 Dec 2023, 12:15
60-80ms, with mechanical keyboard, lowest is 33ms.
