where can you buy it `?
Acer Nitro XV242F (540hz TN) discussion
petight
Re: Acer Nitro XV242F (540hz TN) discussion
I ordered from overclockers UK, but looks like Scan and Ebuyer also have stock
24G2Z - XV252QF - AW2524HF - XV242F - AG246FK6
forcedreg
Does it have strobing up to 540 hz? How is the brightness?petight wrote: ↑21 May 2024, 07:02I ordered from overclockers UK, but looks like Scan and Ebuyer also have stock
loosem5
Hello,
You only have 1 post in your records, and PM's only unlock when you have a few posts. This rule change occured because spammers were using PM's to send advertisements / etc. It might be better to discuss stuff publicly as a new forum member.
petight
So first impressions, I wasn't blown away by the strobing, I mean it's the best I've ever seen but you can still see crosstalk in the top portion of the screen at speeds 1400+ on UFO test. I was expecting that aspect to be better but from what I've seen it's no worse than the other 540hz panels. What also annoyed me a lot was that VRB locks the brightness, and it is super bright. I guess approaching 300nits, I usually use a screen around 200nits. So for me the VRB brightness was actually too much, I would have loved a pulse width setting to make the strobing stronger and reduce brightness. I ended up adjusting the colour settings and using a higher gamma to make the screen feel dimmer.
Colours - this is my first TN in like a decade. I was expecting it to be shit...and it really isn't. The colours are great. I had to fiddle with the settings for a few hours (panel was leaning warm and oversaturated) but now it looks fantastic. As good as any IPS I've owned from front on. As I said on another post it's 10bit, and if you turn off DSC you're stuck with 422 colour compression but 540hz still works.
For the money (I got it for 500 quid) it's a complete no brainer. Why would you pay twice as much to have slightly better OSD settings? 540hz feels fantastic and the strobing keeps the action clear. Oh one more thing the joystick control on mine feels so trash!
Overall I give the product an 8/10, value for money I give it an 11/10. Acer are still selling the 390hz IPS for nearly £500!
forcedreg
PumaDace1907
How the monitor feel is it responsiv ?petight wrote: ↑28 May 2024, 16:31So first impressions, I wasn't blown away by the strobing, I mean it's the best I've ever seen but you can still see crosstalk in the top portion of the screen at speeds 1400+ on UFO test. I was expecting that aspect to be better but from what I've seen it's no worse than the other 540hz panels. What also annoyed me a lot was that VRB locks the brightness, and it is super bright. I guess approaching 300nits, I usually use a screen around 200nits. So for me the VRB brightness was actually too much, I would have loved a pulse width setting to make the strobing stronger and reduce brightness. I ended up adjusting the colour settings and using a higher gamma to make the screen feel dimmer.
For the money (I got it for 500 quid) it's a complete no brainer. Why would you pay twice as much to have slightly better OSD settings? 540hz feels fantastic and the strobing keeps the action clear. Oh one more thing the joystick control on mine feels so trash!Overall I give the product an 8/10, value for money I give it an 11/10. Acer are still selling the 390hz IPS for nearly £500!
i buy the asus pg248qp and send it next day back cause my mouse was feeling very slow it was not fast responding like an input lag
Lucasre5
I have a 2566k and I picked up this 540hz Acer model a few days ago. I think brightness is a very personal thing, for me the brightness with vrb at the extreme is very low, I can't use it with the screen that dark, it's a much lower brightness than the 2566k with dyac+, but without vrb a screen has a higher brightness than 2566k. In fact, the monitor is responsive, but I found Zowie's implementations to be much superior. the black eq, color vibrance and sharpness make a lot of difference in distinguishing enemies and dark places.. the acer's super sharpness is very strange, unusable. The Acer's colors are better, but in game it's a difference that affects very little, the biggest difference is in navigation, the white is really white and not half washed like on the 2566k. I ended up keeping the 2566k and returning the Acer, because despite it really being a more responsive monitor, I didn't like the sharpness of the monitor and the Acer's implementations. Furthermore, the dayc+ at 360hz is clearer than the vrb at 540hz, with a much lower brightness.petight wrote: ↑28 May 2024, 16:31So first impressions, I wasn't blown away by the strobing, I mean it's the best I've ever seen but you can still see crosstalk in the top portion of the screen at speeds 1400+ on UFO test. I was expecting that aspect to be better but from what I've seen it's no worse than the other 540hz panels. What also annoyed me a lot was that VRB locks the brightness, and it is super bright. I guess approaching 300nits, I usually use a screen around 200nits. So for me the VRB brightness was actually too much, I would have loved a pulse width setting to make the strobing stronger and reduce brightness. I ended up adjusting the colour settings and using a higher gamma to make the screen feel dimmer.
Lucasre5
By the way, how do you turn off the DSC?petight wrote: ↑28 May 2024, 16:31So first impressions, I wasn't blown away by the strobing, I mean it's the best I've ever seen but you can still see crosstalk in the top portion of the screen at speeds 1400+ on UFO test. I was expecting that aspect to be better but from what I've seen it's no worse than the other 540hz panels. What also annoyed me a lot was that VRB locks the brightness, and it is super bright. I guess approaching 300nits, I usually use a screen around 200nits. So for me the VRB brightness was actually too much, I would have loved a pulse width setting to make the strobing stronger and reduce brightness. I ended up adjusting the colour settings and using a higher gamma to make the screen feel dimmer.
