CS2 hit registration. New installation of Nvidia drivers fixed my desync but not for very long
dermodemon
Re: CS2 hit registration. New installation of Nvidia drivers fixed my desync but not for very long
Weird stuff. I uncheck GPU from msi and check msi for the external ethernet card and make these priorities. Feels like i do not getting prefired left and right. My hits are more accurate now and i have more %1 lows. Haha wtf
- Untitled.png (30.27 KiB) Viewed 10484 times
cursed-gamer
No. All super duper secret tweaks are worthless. I've seen perfectly working CS:GO on a laptop with default settings. Even Nvidia settings were on default.samzor wrote: ↑26 Feb 2024, 10:51very interesting. One info would be that perhaps they have very special skilled guy in their organisation (which has a ton of money to spend) on tweaking all those stuff for them. As it is clearly an advantage against the other, they don't publish them.cursed-gamer wrote: ↑18 Feb 2024, 14:44I noticed that too. For some players like Zywoo, Donk, d0cc, ropz, twistzz Counter Strike works just perfect. Better than for the others and it's clearly visible.
And most important: it is consistent at all times
joseph_from_pilsen
The question is how many working cs installations you have seen at NEW MODERN hardware WITHOUT tweaks.
For me personally tweaking worked to make my performance rig running without delay and desync... Wasnt good before.
Issues i had - game desynced with noticable "behind feeling" very often. Solved by disabling all buffers + bufferbloats + disabling all saving features. So the client simply has now way how to buffer or get lazy (Russlan way - not allow him to sleep and keep him under pressure lol).
ApexLeg
What bufferbloat settings are you disabling?joseph_from_pilsen wrote: ↑26 Feb 2024, 13:35The question is how many working cs installations you have seen at NEW MODERN hardware WITHOUT tweaks.
samzor
would you mind posting your entire "tweaks/setup" please ?joseph_from_pilsen wrote: ↑26 Feb 2024, 13:35The question is how many working cs installations you have seen at NEW MODERN hardware WITHOUT tweaks.
Would be really cool. I'm trying to create the perfect setup for my gaming rigs, using Atlas OS and using my personal playbook with AME wizard to setup it for me.
jassine
I totally agree with you, i tried it today, my games felt smooth, no desync, no delay. after couple of hours, the bs went back.
I used nvcleaninstall.
gregoriusgreg22
Speaking of desync, I've stumbled upon a Reddit thread of a guy who showed a few of his clips. I can only feel for him. It looks like somebody set his CS2 difficulty to "very hard".
https://www.youtube.com/watch?v=4BfrMwsfvFM
https://www.youtube.com/watch?v=nP52v9m06-Q
https://www.reddit.com/r/GlobalOffensiv ... confidence
JimCarry
joseph_from_pilsen
Network card buffers are only 1 part, but yes, that should be correct.
Sadly, you need also to remove buffer commands in game client, but valve made many commands deprecated or server-sided only last months
Syykfk
How long will the effect last after you do this? Will it last until the computer is turned off?
