Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
f1ndus
Post
by f1ndus » 23 May 2024, 14:10
widow13 wrote: β23 May 2024, 11:06
f1ndus wrote: β22 May 2024, 23:03
widow13 wrote: β22 May 2024, 05:53
Thatweirdinputlag wrote: β21 May 2024, 20:17
If you look at the back of almost any modern motherboard, you'll see the I/O shield. This shield is actually grounded, and the grounded shield of the stp/ftp/sftp etc cable comes in contact with it when male and female RJ45's are hooked, thus grounding the shield of the cable too. Problem is, why on earth is it making things worse? specially desync, hitreg latency and sluggish movement in general.
More to that, I've already tried to ground the ethernet cable by hooking a crocodile clip and a ground wire wrapped around a case screw. Made sure that the crocodile clip is grounded by testing it with a multimeter. Nothing changed really!
I really don't know, all I know is after the PC was left without ethernet cable for 10 minutes it felt insanely smooth after re-plugging it back and playing a game.
That wasn't even the intention, I was switching cable to see if it was causing my discord issues.
Well it's not 100% fixed tbh, could just been a coincidence and pc happened to act better these days.
Will see when I get back in 10 days I will have a double conversion UPS and see if it fixes the rest of the issues.
I am faceing input lag problem from 2016. Really i have already 3. Internet provider, every time other ethernet cables, routers, playing on WiFi Long time. It have nothing to do with internet or cables. Save your time with this theory.
Also UPS online do nothing to this problem, also every power helper what exist do nothing.dont buy nothing. Even 100 filter emi/rfi what I bought did nothing, maybe 5%better after filters
I've been having it for years too. 4-5 years.
This problem is not 100% the same for everyone and for sure won't have the same solution for everyone either.
I've read of people that fixed input lag issues with double conversion UPS (doesn't meant it's gonna help me too) but the quality of it might aswell play a big role.
UPS will be useful for the PC either way because the equipment is expensive so it's fine if it doesn't help, I'll keep it as extra protection or take it back and buy something else.
This is most likely my last resort either way, I'll probably stop trying if UPS doesn't help either.
I dont know anyone who fixed this shit problem with ups or something like that, if somebody told you that he fixed with ups or something what helping power he is lying. And yes everyone have the same problem, if you have problems with mouse floaty, desync in games, bad hitreg and you cant fix that even u changed PC welcome to the club.
And ye, i dont know anybody who even fixed this problem, only few what changed apartment with luck. gl brother, i know you wanna try that by yourself, i was same like you before, when somebody said change internet provider didnt helping, i was going to try it, when somebody said ups, power conditioner isnt helping - i was going to it and try it. GL bro but try to be not disapointed i know that pain.
widow13
Post
by widow13 » 24 May 2024, 01:59
f1ndus wrote: β23 May 2024, 14:10
Thanks brother.
I know and I don't expect much and most likely won't get fixed, so I won't really get disappointed.
I've tried PC on different houses which had bad internet and PC was working like a charm.
The house I tried it on was far away from the city and didn't have many people living in the area, so I believe low usage of electricity in the area makes a big difference and also that's the issue I'm facing in my house (high power usage during day times results in low voltage and noise in lines).
Gonna update when UPS arrives.
widow13
Post
by widow13 » 30 May 2024, 11:54
So my double conversion UPS arrived and even tho it helped by a lot, I felt like I needed a clean format to get rid of corrupted files that were caused and so far everyone seems to be working fine!
It seems like it becomes better day by day.
- Untitled.png (402.89 KiB) Viewed 6471 times
bwainzz
Post
by bwainzz » 30 May 2024, 12:04
widow13 wrote: β30 May 2024, 11:54
Explain more pls bro
What UPS exactly? Only plug, connect pc/monitor and play?
widow13
Post
by widow13 » 30 May 2024, 12:08
bwainzz wrote: β30 May 2024, 12:04
Double conversion UPS, I connected monitor/pc and both my routers.
The model is a Powerwalker VFI 1000 TG UPS On-Line 1000VA 900W
I used the cables it comes with(2x IEC C13 - IEC C14) to connect monitor/pc and an IEC C14 - Schuko female adapter to connect my routers.
You basically plug it, plug ur pc/monitor/router on it and switch to line mode and u are good to go.
widow13 on 30 May 2024, 12:14, edited 1 time in total.
bwainzz
Post
by bwainzz » 30 May 2024, 12:14
widow13 wrote: β30 May 2024, 12:08
bwainzz wrote: β30 May 2024, 11:54
[/quote]
tks for info bro!
look my game:
Did you have a similar problem? How much did UPS help?
widow13
Post
by widow13 » 30 May 2024, 12:17
bwainzz wrote: β30 May 2024, 12:14
tks for info bro!
look my game:
I've been having similar issue. Desync/input lag. Can't even react to enemies or hit easy shots.
UPS so far has resolved almost all of it and it seems to get better with every game.
I've been playing whole day with migraine and I can still frag.
widow13
Post
by widow13 » 01 Jun 2024, 13:07
So things are still fine, I had a small issue with my mouse but it was viper v3 pro polling issue.
It has issues when used wireless under 8k hz, changed the polling rate to 8k and everything is fine now.
Hopefully they fix it asap.
