Weird mousetester result
St1cky
Re: Weird mousetester result
Post by St1cky » 06 Dec 2024, 06:36
Found one culprit of those wierd arrows.
Its related to the Interrupt Routing Settings.
After changing Interrupt Routing Settings. [ 22000.2538 - Windows 11 21H2 ]
rem Einstellungen für die Interruptsteuerung\Modus für die Interruptsteuerung
powercfg /setacvalueindex 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c 48672f38-7a9a-4bb2-8bf8-3d85be19de4e 2bfc24f9-5ea2-4801-8213-3dbae01aa39d 3
rem Einstellungen für die Interruptsteuerung\Ziellast
powercfg /setacvalueindex 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c 48672f38-7a9a-4bb2-8bf8-3d85be19de4e 73cde64d-d720-4bb2-a860-c755afe77ef2 5
rem Einstellungen für die Interruptsteuerung\Auslöser für die nicht geparkte Dauer
powercfg /setacvalueindex 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c 48672f38-7a9a-4bb2-8bf8-3d85be19de4e d6ba4903-386f-4c2c-8adb-5c21b3328d25 0
rem To apply changes
powercfg /setactive SCHEME_CURRENT
If you want, you can also deactivate the Power service instead of changing the Power settings for the Powerplan.
Code: Select all
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Power
set Start to 4 ( Default is 2 )
WIN11 21H2
If you play around with DWM you can actually get very good results, the only problem is that it causes spikes, but overall it's not bad.
CS2 Ingame:
JimCarry
Post by JimCarry » 18 Dec 2024, 04:10
St1cky wrote: ↑
06 Dec 2024, 06:36
Code: Select all
Can you translate to english the first part and explain it please? and also is it safe to turn of this service? and are you talking about this option in power plan settings or i am drunk?
Bobo
Post by Bobo » 18 Dec 2024, 06:20
make sure you backup your current power settings, if you plan on tweaking them.
8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c is setting the power plan to high performance
2bfc24f9-5ea2-4801-8213-3dbae01aa39d is Interrupt Steering Mode - he set it to a value of 3
73cde64d-d720-4bb2-a860-c755afe77ef2 is Target Load - he set it to a value of 5
d6ba4903-386f-4c2c-8adb-5c21b3328d25 is Unparked time trigger - he set it to a value of 0
JimCarry
Post by JimCarry » 19 Dec 2024, 01:47
Bobo wrote: ↑
18 Dec 2024, 06:20
Thanks very much i will change this settings hayote also tell me to change Interrupt Steering Mode to the same value,but please can i disable the service sticky says ? power to 4?
