Page 3 of 4
Re: Very long postinstall guide
Posted: 12 Dec 2024, 00:46
by PatheticBot
dermodemon wrote: ↑
17 Oct 2024, 04:53
Well. Shit. Now my pc won't start. After login in windows i have an error
sihost.exe - system failure.
Sorry for my english:
Sihost.exe – System error – The system detected an overrun of a stack based buffer in this application. This overrun could potentially allow a malicious user to gain control of the application.
Okay i fixed it. I pressed alt+ctrl+del, ran a task manager and run regedit
The problem was a regedit tweak:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\StateRepository
DO NOT CHANGE IT. Leave it at 2
default setting 2, shitty "tweaked" setting is 4
Yea it did the same for me, file explorer just wont load
Posted: 15 Dec 2024, 05:51
by Hyote
PatheticBot wrote: ↑
12 Dec 2024, 00:46
dermodemon wrote: ↑
17 Oct 2024, 04:53
Maybe this is connected to the newer versions. I remember being able to do all of these on the lastest Windows 10 without any issues but I'm not 100% certain.
Posted: 29 Jan 2025, 18:31
by PatheticBot
Hyote wrote: ↑
15 Dec 2024, 05:51
12 Dec 2024, 00:46
dermodemon wrote: ↑
17 Oct 2024, 04:53
Yeaa Win11 24h2 so definitely a newer windows issue apologies.
Still a great guide
Posted: 30 Jan 2025, 09:09
by Hyote
29 Jan 2025, 18:31
Hyote wrote: ↑
15 Dec 2024, 05:51
12 Dec 2024, 00:46
dermodemon wrote: ↑
17 Oct 2024, 04:53
Still a great guide
I should have put a disclaimer there earlier but still, thank you.
Posted: 06 Feb 2025, 23:08
by Hyote
I made a tweaks.bat file with every tweak that can be found here and much more else with explanations.
Posted: 04 Jun 2025, 23:12
by Hyote
I made a slightly more normal guide on GitHub: https://github.com/Hyyote/In-depth-Windows-tweaking
Posted: 05 Jun 2025, 01:21
by steamidwudichao
Hyote wrote: ↑
04 Jun 2025, 23:12
@Hyote thanks very much sir ! it's time for a all in one guide to reduce latency :)
Posted: 14 Sep 2025, 13:38
by AJ 47
Hyote, in your guide, how do you kill something like sihost.exe without it automatically restarting? I only managed to end explorer.exe.
Posted: 17 Sep 2025, 07:05
by Hyote
Kill the svchost above it and then sihost. I don't recommend it now because there aren't actual gains by doing it. Having a minimal service count (30-40) is enough, but even that doesn't make a difference, I just like not having many things running in the background.
Posted: 17 Sep 2025, 13:21
by dude03
Personally, I'm curious. What value are you using for the win32priorityseparation?
