Two settings that eliminated a lot of mouse heaviness for me
Re: Two settings that eliminated a lot of mouse heaviness for me
Can you provide the option to revert the reg stuff, like you did with DEP ( enable or disable script) and then we can all do test.because when you provide revert script if someone dont like or see decrese in benchmakrs can revert,for example if you disable dep its better but you cant play face it,so you use the enable script in the first comment but for the reg stuff you cant test because there is no revert file.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Direct3D]JimCarry wrote: ↑24 Jan 2025, 09:09Can you provide the option to revert the reg stuff, like you did with DEP ( enable or disable script) and then we can all do test.because when you provide revert script if someone dont like or see decrese in benchmakrs can revert,for example if you disable dep its better but you cant play face it,so you use the enable script in the first comment but for the reg stuff you cant test because there is no revert file.
"DisableVidMemVBs"=dword:00000000
"MMX Fast Path"=dword:00000001
"FlipNoVsync"=dword:00000001
[HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Direct3D]
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Direct3D]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Direct3D\Drivers]
"SoftwareOnly"=dword:00000000
[HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Direct3D\Drivers]
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Direct3D\Drivers]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DirectDraw]
"EmulationOnly"=dword:00000000
[HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\DirectDraw]
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\DirectDraw]
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Direct3D]
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Direct3D\Drivers]
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\DirectDraw]
An error has occurred setting the element data.
The value is protected by Secure Boot policy and cannot be modified or deleted.
i changed secure boot from Windows uefi to other os and worked
placebodebil
the regedit part caused issues for both me and another person, making our games extremely choppy while using Win32Separation. We had to increase the value to 38 (hex) to reduce the choppiness until we eventually discovered that these setting were the actual cause of the problem.Hyote wrote: ↑21 Dec 2024, 12:25The first one disables Data Execution Prevention:
https://support.microsoft.com/en-us/top ... 2419135817
As you can see this one is a huge security risk but obviously I only care about latency.
Paste this into CMD or make it into a .bat file:
@echo off
bcdedit /set nx AlwaysOff
powershell set-ProcessMitigation -System -Disable DEP
powershell set-ProcessMitigation -System -Disable EmulateAtlThunks
echo DEP has been forcefully disabled. Please reboot your system.
pause
If you want to reenable it:
@echo off
bcdedit /set nx AlwaysOn
powershell set-ProcessMitigation -System -Enable DEP
powershell set-ProcessMitigation -System -Enable EmulateAtlThunks
echo DEP has been forcefully enabled. Please reboot your system.
pause
The second one is related to DirectX, supposedly they don't do anything now but there is definitely a difference with them applied:
The only place I found this was on a forum page where no one gave an explanation about what is being changed and this github page with a lot of registry keys I tried as well.
https://github.com/ionuttbara/fidelity/ ... _reg11.reg
"SoftwareOnly"=dword:00000001
"EmulationOnly"=dword:00000001
"DisableAGPSupport"=dword:00000001
"DisableInactivate"=dword:00000001
"DisableMMX"=dword:00000001
"DisableNoSysLock"=dword:00000001
hazzahodgson
I use this tweaks.
But I also use some dpc/isr tweaks along with it. I'm not sure if they are contributing the smallest bit but they never gave any bad results and I apply all my tweaks at once after testing them all while ago so I use them anyways. Another thing is, people say isolate usb controller thats got your mouse on away from core 0. But I get better results isolating other stuff and keeping mouse on core 0.
QuantumTaco21
These break NVIDIA shadow play for me but it does make my game feel a lot betterHyote wrote: ↑21 Dec 2024, 12:25Windows Registry Editor Version 5.00
You have to make a lot of sacrifices for low input latency, and the NVIDIA software is one of them.QuantumTaco21 wrote: ↑08 Apr 2025, 13:32These break NVIDIA shadow play for me but it does make my game feel a lot betterHyote wrote: ↑21 Dec 2024, 12:25Windows Registry Editor Version 5.00
