Accidentally fixed my stuttering and input lag problem
Gias
Re: Accidentally fixed my stuttering and input lag problem
Post by Gias » 11 Jan 2025, 20:04
dermodemon wrote: ↑
11 Jan 2025, 19:28
I can still see my gsync indicator even in borderless mode. it's on even by feeling of the game. even with mpo is off and gsync in nvcpl is set to fullscreen games only. And it still shows hardware independent flip in borderless mode. i am a little bit confused
i didn't say you always need MPOs for independent flip.
i said MPOs allow the game to retain independent flip presentation in more scenarios such as when you have some external window on top of the game and in a few more scenarios...
akylen
Post by akylen » 20 Jan 2025, 13:26
Any update after one week ?
dermodemon
Post by dermodemon » 20 Jan 2025, 14:44
akylen wrote: ↑
20 Jan 2025, 13:26
Yes. It's still super sharp and no more mouse floaty feeling.
Have you tried this fix?
JimCarry
Post by JimCarry » 21 Jan 2025, 19:02
dermodemon wrote: ↑
11 Jan 2025, 14:52
So i don't know how to explain this but i suffered many years by this weird stuttering and input delay problem. Mouse felt like i am playing with vsync on and i had huge amount of stuttering (especially in unreal engine titles).
Basically how i fixed it:
1) I turned off afterburner power monitoring(i found a video about how to do it in here: https://youtu.be/bQH3DYNboM0?list=LL&t=611).
2) Next thing i did - disable FSO with this reg file:
Code: Select all
[HKEY_CURRENT_USER\System\GameConfigStore]
"GameDVR_DXGIHonorFSEWindowsCompatible"=dword:00000001
"GameDVR_FSEBehavior"=dword:00000002
"GameDVR_FSEBehaviorMode"=dword:00000002
"GameDVR_HonorUserFSEBehaviorMode"=dword:00000001
3) Than i disabled MPO with this reg file:
Code: Select all
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Dwm]
"OverlayTestMode"=dword:00000005
4) I also enabled resizable bar and HAGS + disabled setting called "optimizations for windowed games"
I don't know what exactly fixed my issue but after many years of trying every single fix i found here and reddit i am currently feel happy.
Games now feel completely smooth and sharp and no more floaty mouse feeling. I want to cry
Specs:
CPU: Ryzen 5600x
GPU: RTX 3080
RAM: 32gb ddr4 3600mhz
MOBO: B450m PRO4-F (Asrock)
Windows 11 24h2
GSYNC on or off, no matter what - i don't feel anymore stuttering and mouse problems
Hi
#1 for me you must run only steam and then cs2.exe the only software running on pc must be steam nothing more(while gaming)
#2 you are running settings that make fullscreen exclusive mode.i will show the script + source for it to confirm it.
#3 i also use this.i will show one source that show this setting as a "tweak"
and about above 4 g decoding and resizeble bar mine is off i test in benchmark no change in fps but its better when resizble bar and above 4g are disabled.
fse source https://youtu.be/PlACZ9Gp1xo?t=7439
# fullscreen exclusive fse regedit
reg add "HKCU\System\GameConfigStore" /v "GameDVR_DXGIHonorFSEWindowsCompatible" /t REG_DWORD /d "1" /f | Out-Null
reg add "HKCU\System\GameConfigStore" /v "GameDVR_FSEBehaviorMode" /t REG_DWORD /d "2" /f | Out-Null
reg add "HKCU\System\GameConfigStore" /v "GameDVR_FSEBehavior" /t REG_DWORD /d "2" /f | Out-Null
reg add "HKCU\System\GameConfigStore" /v "GameDVR_HonorUserFSEBehaviorMode" /t REG_DWORD /d "1" /f | Out-Null
Write-Host "May also be required:"
Write-Host "-game.exe"
Write-Host "-properties"
Write-Host "-compatibility"
Write-Host "-disable fullscreen optimizations"
Write-Host "-apply"
Write-Host ""
Write-Host "DX12 engines do not support fullscreen exclusive mode."
Write-Host ""
Write-Host "Press any key to continue . . ."
@source the is fr33thys youtube.
disable mpo :https://www.youtube.com/watch?v=fw_xv1Id6UM
Post by Slender » 21 Jan 2025, 19:31
you should have it like this.
no other garbage should be running.
Screenshot 2025-01-21 162954.png (1.61 KiB) Viewed 6386 times
dermodemon
Post by dermodemon » 02 Feb 2025, 14:05
akylen wrote: ↑
20 Jan 2025, 13:26
AAAAAAAAAAAAAAAAAAAND floaty fucking feeling came back. Feels like my mouse have smoothing+acceleration now. So fucking unpredictable. W T F is going on with this fucking PC
i am losing my fucking mind
