Re: the only logical reson behind unexplained input lag and inaccurate sensitivity
Posted: 11 Feb 2025, 00:29
Switch to cpu encoding/decoding from gpu in observed settings. You can also record local file to exclude "ISP problem"spkii wrote: ↑10 Feb 2025, 09:39Ping is OK when streaming, FPS dont dropes lower than 230-240fps on CS2, Valorant or Marvel Rivals... idkgreenenemy wrote: ↑10 Feb 2025, 08:39@spkii
Check ping wile streaming it could be bufferbloat creating ping spikes or even packet loss both can be perceived as input lag feeling. You can also try to limit your fps to free up some resources for the stream.
