Re: Does CTA-861 triple buffer frames?
Posted: 04 Mar 2025, 14:52
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
not exactly, first i made an extionsblock with dp2.0 with Topology and under the same extension block i created the resolution with manual timings and 360hz refresh rate for example for my Asus Rog259qn (360hz Monitor). but Topology should be above the detailed resolution under the same extension block so when you use the resolution you configured for example 360hz its displayed in Topology and not in CTASlender wrote: ↑04 Mar 2025, 14:52https://youtu.be/gdYcXAtVK2w?si=6NbtMhUDRW9Ba-1r
your solution is like that?
How you apply those tweaks? Can you make a regedit bat or something like that?Mighty wrote: ↑02 Mar 2025, 12:25In my opinion the best option is to delete all default extension blocks create a tiled up topology one and in the same category create one with the default timings of your highest refresh rate your monitor can handle and as detailed resolution, helps tremendously with input lag. (detailed resolution should be below tiled up topology. You can also decrease the IL further by tweaking your monitor timings such as sync width and Back Porch
This Tweak made my Display crazy crisp and diminished all the Blurryness from my monitors default settings. Also there are other top secret tweaks i think a lot of people are searching for and cant find them who are very helpfull for Input Lag and Mouse Movent "AkA" Floaty Mouse... I'll explain them here since its also about Input lag...
probably allot of you who searched for floaty mouse fixes heard of the Windows 8 Tweak with in the Appcompat/layers Folder in Regedit... well the thing is most users use this tweak in the wrong way because its told commonly to put the path to exe file of your application as name of the REG SZ key but you dont simply type in NoDTToDITMouseBatch because it doesnt' work this way in Windows 10 and 11. If you want to apply you have to type NoDTToDITMouseBatch=1 for it to work.
Fun Fact. If you make a REG MULTI SZ there you can apply multiple tweaks for any games you want to make Mouse Movement insanely responsive and HITREG soo good i'll leave them here as i know a lot of you guys just like me are going insane about this topic.
this is the list of tweaks i use in CS2 for example:
NtTNoBatch=1
NTTThreshold=0
DisableProcessWindowsMouseAcceleration=1
NoGDIHWAcceleration=1
NoAsyncInput=1
DisableMouseAcceleration=1
DisableFullscreenOptimizations=1
NoLowLevelHooks=1
NoBufferedInput=1
DisableDpiScaling=1
MouseNoSpeedScaling=1
NoAsyncRender=1
ForceThreadedInput=0
NoHyperThreadingInput=1
DisableInputPrediction=1
DisableVSync=1
DisableGameDVR=1
DisableMouseSmoothing=1
NoInputLagCompensation=0
NoSwapChainOverride=1
NoBatch=1
FixRelativeMouseMovement=1
NoLegacyMouse=0
NoForegroundLockTimeout=1
NoTimerResolutionOverride=1
DisableSystemTimers=1
DisableBackgroundTaskOptimization=1
DisableMulticoreScaling=1
NoTiledRendering=1
NoFlipQueue=1
NoSpeedScaling=1
DisableRawInputBuffer=1
EnableDirectInput=0
EnableLegacyMouseMode=0
EnablePS2RateOverride=0
ForceHighPollingRate=1
ForceUSBHIDMode=1
ForceRawInput=1
Ok i will change to Exact Reduced,i dont know what to edit in Manual? also why for example from the video that slender provide above on his monitor "Sync Polarity" are + and - ,why when i press Exact Reduced mine are - -
Reduced timings have higher scanout lag. See:
