Help Understanding G-Sync Windowed 40fps behavior
Re: Help Understanding G-Sync Windowed 40fps behavior
Post by jorimt » 18 Mar 2025, 12:40
ZTylerDurden wrote:
18 Mar 2025, 12:21
Absolutely CRUSHED IT. Faq #5 worked to use nvidia inspector. I got g-sync active now in Dolphin. F------ excellent work.
Nice, guess I should have led with that then.
ZTylerDurden wrote:
18 Mar 2025, 12:21
Only thing now is that I get slight flicker at 30fps (60fps games are fine).
That further confirms your monitor model refreshes at 30Hz VRR (when at a physical 60Hz+) with 30 FPS (as it doesn't support LFC).
I had an older G-SYNC monitor that had slight flicker at lower framerates due to its lower LFC threshold. This is another reason newer G-SYNC monitors have a higher LFC threshold (I.E. using 60Hz LFC at 30 FPS instead of 30Hz, etc), as to avoid it.
The first few TN panel G-SYNC models were also prone to the below (though not sure if it applies to your model, since it was such an early mod):
https://web.archive.org/web/20210414014 ... heres-why/
vlad54rus
Post by vlad54rus » 19 Mar 2025, 09:23
jorimt wrote:
18 Mar 2025, 09:31
it seems Dolphin still uses a legacy flip model for windowed mode, at least on my configuration
Dolphin has been using flip model since 2017, it should enter Hardware Composed: Independent Flip as long as nothing interferes with it.
Post by jorimt » 19 Mar 2025, 10:11
vlad54rus wrote:
19 Mar 2025, 09:23
Right, but as I noted in that same comment, my monitor uses DSC, and MPO is required for Hardware Composed: Independent Flip.
Post by RealNC » 19 Mar 2025, 10:17
jorimt wrote:
19 Mar 2025, 10:11
Without MPOs, you should get "Hardware: Independent Flip" though. Unless you have something else showing on top of the window.
Post by jorimt » 19 Mar 2025, 10:28
RealNC wrote:
19 Mar 2025, 10:17
In Dolphin borderless mode (alt + enter), I just checked, and yes, but in it's windowed mode (as a small window on my actual desktop when focused), no for my specific hardware with DSC enabled on my particular monitor for whatever reason. I have to use the legacy G-SYNC borderless/windowed option in the NVCP for VRR to engage in this case.
Could be app/config-specific. There are too many variables nowadays to be easily sure, and I don't care enough in this instance to troubleshoot the exact reason (I use the actual consoles with a RetroTINK 4k instead of emulators now anyway).
