Page 3 of 3
Re: LatencyMon Results
Posted: 26 Apr 2025, 16:52
by Saphyen
Just by playing the game on my PNY drive doesn't change anything. Maybe I have to move my windows drive to the PNY one if that is indeed the problem area. Also forgot to mention this since I wasn't sure about it. I don't do this, but I have in the past and thought it was weird. You know when you hold down the power button on a pc and it force shutdown? Well, when I have done it in the past, my computer will not turn back on until I cycle the power by turning off the psu. Not sure if this is normal behavior, I just thought I would mention it
Posted: 26 Apr 2025, 23:42
by Saphyen
Saphyen wrote:
26 Apr 2025, 16:52
Tried with windows on pny sdd and it's just the same
Posted: 27 Apr 2025, 04:45
by St1cky
Saphyen wrote:
26 Apr 2025, 16:52
You still didnt show the other Tabs in LatencyMon.
And forcefully shutdown, shouldnt cause this. Sounds more like a Firmware Issue, does the same happen with BIOS Default Settings?
Sounds like it could be either a corrupt BIOS image or Intel ME. At least, I've only seen these symptoms when something is wrong with the BIOS. ( Faulty Settings, Faulty Image or ... )
Does the same thing happen with a different BIOS version?
What does the BIOS say for Intel ME version?
- If it shows 0.0.0.0 as Version, Intel ME is not initialized.
Posted: 27 Apr 2025, 14:01
by kyube
Saphyen wrote:
26 Apr 2025, 23:42
The main game I play is Apex Legends so I ran the thing in it while moving my mouse around. I have also decided to redo the test as I did it in the firing range before and now I show it in an actual live match. It feels like my input constantly just cuts out and cuts back in over and over sometimes.
Saphyen wrote:
26 Apr 2025, 23:42
Before this gpu I had a 3080 and it was a while back, but I don't remember being affected by latency issues with the old 3080 and PNY ssd combo. I haven't tried to use the pny for gaming really after I swapped it to be a backup drive. I came into this 3080ti for free through circumstances in late 2023. Other than my current one, I don't have access to any other gpus.
As boring as this may sound, it might be your GPU...
There could also be some BIOS sheningans going on, as St1cky mentioned
Posted: 27 Apr 2025, 20:55
by Saphyen
St1cky wrote:
27 Apr 2025, 04:45
Saphyen wrote:
26 Apr 2025, 16:52
I reset the bios and yes it still happens. I have updated from 13~ to 16.02 through each update and it has been the same. It was like this when I had my old mobo as well. I looked in my bios and my intel ME version shows 16.1.30.2264. Is this the tab that you want shown?
Screenshot 2025-04-27 202447.png (87.17 KiB) Viewed 5529 times
Posted: 21 May 2025, 02:45
by Hyote
Kind of finished tweaking Windows 11 for about a month now. I want to see how these results fare.
Posted: 21 May 2025, 14:18
by kyube
Hyote wrote:
21 May 2025, 02:45
It would be nice if you could mention the test environment you've had when running this xtw report.
It seems that you've had some game running (dxgkrnl.sys is graphics-related driver).
As for what each metric in xtw means, here's a explanation from the creator (valleyofd00m):
Total Elapsed Time (usecs / microseconds) — the sum of elapsed time for each driver
there is also Count which just tells you how many times a ISR/DPC was scheduled for that driver but it can be kinda useless because you don't know how long each ISR/DPC will take to execute
interval (ms) — how often the ISR/DPC is scheduled in milliseconds
e.g. 1ms is 1000 times a second, 0.125ms is 8000 times a second, it's the same as mouse tester (or just polling rate in general)
you don't want unimportant drivers to be scheduled often, so a higher value is a good indicator.
Elapsed Time (usecs / microseconds) — how long it took for the ISR/DPC to execute
e.g. end timestamp minus start timestamp
Posted: 21 May 2025, 15:20
by Hyote
kyube wrote:
21 May 2025, 14:18
Hyote wrote:
21 May 2025, 02:45
Thanks for checking it, I actually had nothing open while running the script, dxgkrnl is my doing.
Posted: 09 Jul 2025, 01:23
by St1cky
Saphyen wrote:
27 Apr 2025, 20:55
St1cky wrote:
27 Apr 2025, 04:45
Saphyen wrote:
26 Apr 2025, 16:52
How long did you run it and please show everything, i want to see cpu tab too -DONT use very old Latencymon Versions!
Wdf01000.sys insane high, depends on how long you measured.
What you can also see is that all values ​​are relatively high. Even HDAudBus and nvme, which should normally be low. Is there something running in the background?
- Reset BIOS ( Disable only C-States, Disable any Auto OC, use Intel Stock Power Settings ( old asus boards in example had issues with very high power settings, causing massive issues. Maybe Update BIOS latest, Disable TPM and SecureBoot, i saw issues with TPM and Latencymon )
- Unplug Devices ( Do Measurment without HW connected, without !GPU!, Disabled NIC, Disconnected Devices )
( And do again measurment, best do it in safemod boot, per xperf or similiar, since latencymon doesnt work there )
You dont need to downgrade BIOS, since like 90% it will not downgrade your intel me firmware! Only BIOS.
How did you update Intel ME? - Never Update Intel ME or BIOS if PC is running fine.
( BIOS Flash + ME updates can have very negative effects and it is almost impossible to get the original condition back. )
"have updated from 13~ to 16.02"
The most important thing is to first find out what is causing the problem, whether it is a device or software.
