broken scaling cause of heavy/floating mouse, desync, heavy car bug, input lag etc
naporitan
Re: broken scaling cause of floating mouse
Post by naporitan » 04 May 2025, 01:51
bargain purchase of a serviceable monitor!!!!!!!!!!!!
XL2746S
Screenshot 2025-05-04 154808.png (75.81 KiB) Viewed 3771 times
Screenshot 2025-05-04 154932.png (797.6 KiB) Viewed 3771 times
naporitan
Re: broken scaling cause of heavy/floating mouse, desync, heavy cur bug, input lag etc
Post by naporitan » 04 May 2025, 04:57
ROG Swift Pro PG248QP
Driver:
Screenshot 2025-05-04 185644.png (21.53 KiB) Viewed 3716 times
correct scaling:
Screenshot 2025-05-04 185437.png (204.04 KiB) Viewed 3716 times
naporitan
Post by naporitan » 04 May 2025, 06:42
this monitor is very good in terms of picture quality, but it is not suitable for competitive gaming!
there are a lot of these monitors on the market and I don't recommend buying them, always check the manual of the monitor!
ViewSonic XG2431
Screenshot 2025-05-04 203841.png (104.35 KiB) Viewed 3684 times
Screenshot 2025-05-04 165216.png (410.4 KiB) Viewed 3681 times
Misha1337
Post by Misha1337 » 04 May 2025, 09:41
naporitan wrote: ↑
04 May 2025, 06:42
ViewSonic XG2431
I don't understand what is wrong with the xl2566k and how to make it acceptable?
naporitan
Post by naporitan » 04 May 2025, 09:45
Misha1337 wrote: ↑
04 May 2025, 09:41
naporitan wrote: ↑
04 May 2025, 06:42
ViewSonic XG2431
I don't really understand you, why do you think xl2566k is problematic?
I have currently ordered a xl2546 monitor.
and in the right hands it will help you reach your full potential!
Screenshot 2025-05-04 233441.png (229.84 KiB) Viewed 3608 times
JimCarry
Post by JimCarry » 04 May 2025, 10:13
naporitan wrote: ↑
04 May 2025, 09:45
Misha1337 wrote: ↑
04 May 2025, 09:41
naporitan wrote: ↑
04 May 2025, 06:42
ViewSonic XG2431
very nice example this player is great matchfixer and also banned :)
naporitan
Post by naporitan » 04 May 2025, 10:18
Misha1337 wrote: ↑
04 May 2025, 09:41
The xl2566k has only four screen resolutions on which scaling will work. Please look at the manual of the specific monitor model, do not buy the monitor blindly.
But that doesn't mean xl2566k is bad as there is support for 1280x960 @360hz
JimCarry
Post by JimCarry » 04 May 2025, 10:22
naporitan wrote: ↑
04 May 2025, 10:18
Misha1337 wrote: ↑
04 May 2025, 09:41
But that doesn't mean xl2566k is bad as there is support for 1280x960 @240hz
create custom resolution maybe ?
naporitan
Post by naporitan » 04 May 2025, 10:26
JimCarry wrote: ↑
04 May 2025, 10:22
Unfortunately this doesn't fix the problem as the problem is on another level. If it were that simple, it would be possible to use display scaling and custom resolution via CRU.
