The best Nvidia driver
1000WATT
Re: The best Nvidia driver
Post by 1000WATT » 15 Oct 2025, 14:25
kyube wrote: ↑
15 Oct 2025, 11:36
If someone doesn't want to read the official, recommended and "bulletproof" way on how to figure out performance problems on Windows & then continues rambling clear nonsense without any sources or proof, what else is left other than point out the errors?
Trolling seemingly sells better. :)
Have fun with whatever you're trying to do.
I'm still waiting for the moment when you fold your hands.
And you will lean towards the dark side. ;)
aymancader
Post by aymancader » 28 Oct 2025, 08:46
kyube wrote: ↑
15 Oct 2025, 11:36
You should read these forums more often to understand why my manner is variable depending on the type of post in question.
I also fail to understand why you've necro'd such a old post in the first place, but let's move past that... ;)
The user you're trying to defend (let's assume you're not one of the 50 different alt accounts which "spams" nonsense here) has shown clear lack of interest in approaching this topic in a matter of how Windows performance troubleshooting is supposed to be handled.
These things being discussed here aren't intangible, nor something abstract.
They're practical, concrete & specific software "problems" which can be "fixed" using methods described by 1st party sources (Microsoft Nvidia, AMD,...), most of which are written by HW/SW engineers
"Feelings" are prone to human (physiological, psychological, environmental) bias, therefore cannot be used as extrapolation onto every possible hardware & software combination.
Either way, majority of these "problems" purported around here have been solved ages ago or lack incentive to be tested properly due to lack of knowledge & lack of dedication.
Cool story, bro. Well. I tried the 566.03 driver and the little micro-stutters, stability, texture pops and overall gameplay experience improved quite noticeably and I'm glad I found a solution.
Oh and what else is left other than point out the errors?
Carefully place your opinions and assumptions in your back pocket and continue scrolling. Not everyone has the time to type 379 brilliant words of absolutely nothing, so I thank you for your time. Cheers.
