Help for a Musician & Producer
There are over 100 ergonomic issues from displays, far more than just flicker and blue light. This forum covers the giant variety of display ergonomics issues.
AshX
Re: Help for a Musician & Producer
Post by AshX » 06 Feb 2026, 21:46
21 Jan 2026, 15:21
AshX wrote: ↑
20 Jan 2026, 23:39
What confuses me is I have no problem using the iPhone 13 or my CarPlay touch screen in my 2022 Chevy Malibu, nor self-checkout kiosks at CVS and grocery stores. I also could use an iPad Pro at Shake Shack to order until they updated the app and operating system and now I get the same motion sickness and tachycardia that I’ve connected to Apple’s dithering algorithm.
You’ve offered your help to many over the years here on Blur Busters. Have you noticed any commonalities between changes in display technology over the past decade and a rise in difficulty using said displays? Obviously I am a somewhat unique and some may argue, extreme case, as COVID was the singular trigger both in 2022 and 2024. Flicker and total light output (voltage/brightness/blue light) seem to be the main triggers. We’re obviously moving into more of a neurology/nervous system and visual system discussion but I’m not alone in this and if Reddit and Apple forums are any indication, more and more people are being affected.
Yes, more posts.
But is it more common? I don't know.
There's multiple angles:
1. It's not new. 1990s with CRT vs LCD. Back in the BBS/CompuServe/Usenet days, there were many people who could never use a CRT and had to pay lots of money for the early LCDs or use an LCD laptop.
2. Increased awareness = more people posts about it.
3. Increased online users = the outliers who couldn't earlier post now could post because there's more display choices today than in the past
_____
Yes, older used displays are definitely one viable option too.
Older CCFL-lit Apple displays definitely are coveted. I know some people buy them to solve this kind of problem.
Another approach is you can cast your Windows desktop to an iPhone or iPad.
Just install an app such as "Duet" on your IPad, and it becomes a Miracast client: See your Windows desktop.
The older iPad Pro's can be available on eBay for relatively cheap, but make sure it's still on that older iOS (or that the older iOS is still restorable via jumping through various hoops).
Even using a casting app an old obsolete iMac (27" Intel iMac from year 2015 with PWM-free LED backlight, though subject to IPS / FRC behaviors). Repurposing the screen as a casting-based or network-based computer monitor by installing an app on them. Just remember to keep them mainly on a firewalled LAN, or peer-to-peer connection, and avoid using the Internet on those unsupported MacOS systems with no security updates. They can become Windows/Linux computer monitors via casting method.
You could also visit your local thrift stores/used computer stores/etc -- or check your Facebook Marketplace/etc -- and check for 10-to-15-year-old LCD displays and try them out for cheap, even in-store (if you bring a laptop). Or see if you can grab some panels from your local electronics recycling center before they get broken up.
Thanks, Chief, once again for the recommendations. This is such a complex problem and certainly in my case, clearly very specific. I can’t really seem the hone in on one trigger. The usable devices I have are very contradictory, primarily iPhone 13 using AMOLED and a CarPlay LCD.
I wanted to update you that I did actually drive to the Apple Store on 5th Ave in NYC and B&H Photo Video to test the Pro Display XDR and the Eizo CS2740. I brought my 13” M2 MBP running Monterey 12.4 to connect. The results? For the first time in a year I could look at both the Pro Display XDR and the Eizo.
The Pro Display XDR is specifically advertised as true 10-bit by Apple - their only such device. I have confirmed through a contact I have in China that none of the other Apple products, with perhaps only the iPhone Pro Max, are 10-bit. Every other OLED and LCD of theirs is likely to be 8-bit+FRC.
Sadly they only had the Nano texture version, but I had no problems reading text or looking at the display even at max brightness. Sadly I didn’t get the opportunity to play videos or do additional testing because of their WiFi restrictions. I also plugged my MBP into the nearby Apple StudioDisplay and despite forcing 8-bit with BetterDisplay and disabling GPU dithering with Stillcolor, it was immediately uncomfortable: my left eye shut and it was hard to focus on the screen. Interestingly disabling dithering seemed to have no impact on the Pro Display XDR, implying it automatically tells the GPU not to dither.
The Eizo CS2740 was also usable in that I could look at without symptoms. Until I selected one of the MBP’s ICC profiles within BetterDisplay and it immediately made my eye shut. Switching back to the display’s profile was fine. It also seemed fine when the gentleman helping me first accidentally connected it via USB-C to HDMI which bottlenecked the connection to 8-bit. The text was less sharp, though.
So to me this definitely confirms temporal dithering via the GPU and FRC is probably trigger #1, with other forms of flicker coming in at #2. The lighting in both stores was incredibly triggering, so I did have a tachycardia response to a certain degree as a result. The only way to confirm these displays work is by buying them and trying them at home.
The concern I have with the Pro Display XDR is the local dimming zones which are said by Apple to be 10x the 60Hz refresh rate. I don’t know if this is PWM or if it will be an issue. I also didn’t get to mess with brightness so I have no idea how it will behave at lower brightness.
The concern I have with the Eizo is the text sharpness, how it behaved with ColorSync introducing some sort of weird processing and whether that will occur again, and the IPS glow.
So it seems the cost of solving this is between $2000 for the Eizo or $7000 for the Pro Display XDR. And that’s a lot of money to tie up. But I don’t know that I have another choice.
I may pursue trying to buy my old 2019 iMac. I found one sealed and new for a good price. I’d wager there’s a 50% chance it will be usable. At the very least it will confirm whether it became uncomfortable because of my health deteriorating or whether the panel started going bad.
I suspect polarization to also be an issue as when I tried on polarized sunglasses I got immediate identical issues. I’ve noticed a lot of the screens I don’t like including my MBP have a purple tint when the screen is off, clearly the polarized anti glare applied to the screen. Perhaps this is why I liked the nanotexture on the Pro Display XDR.
AshX
Post by AshX » 06 Feb 2026, 21:51
bobbie424242 wrote: ↑
22 Jan 2026, 10:21
The annoying thing with eye strain is that it is so difficult to find the cause as there is a myriad things that can potentially cause it (more probably a combination of them) and everyone is different.
It is kind of sad that the only way to try overcome it or reduce it is through empirical testing of various things.
To the point that it sometimes leads people into endless experiments, obsession and sometimes borderline conspiracy theories (see ledstrain.org).
For one thing, it shows how little we know about eye vision and its interaction with a monitor.
I've been on that quest to reduce eye strain since forever, having moderate eye strain using LCD panels. All I know is that it does not happen when I read on my Boox Page, a 7" e-ink e-reader with a stunning 300ppi display. But e-ink has many drawbacks and not suitable for many types of work. I've been toying with the idea of buying a 25" e-ink black and white monitor, but for know discouraged by the price ($1600+) and doubting about whether I would enjoy working on it or not.
The price is definitely a big factor. This whole thing plus my health struggles and medical bills have limited what I can try and also drawn own this whole ordeal an entire year - it will be 1 year this month, actually.
For me I’m not looking for a “perfect” screen. I know others are on that quest. I don’t expect a screen to be comfortable like a book. I’d just prefer to not be messed up for hours or days after a few minutes of use. So I think my expectations are reasonable.
The issue for me is being able to isolate variables, which is very difficult to do when:
A. Companies are not honest about what is going on under the hood of their device and
B. The symptoms are very severe with very short exposure.
I’ve sort of learned that contrary to what many others have suggested, trying to “acclimate” doesn’t seem to work out. It either works or it doesn’t. I’ve lost a lot of time trying to force myself to adapt to screens or devices, which only results in worsening symptoms. I suspect this is largely due to flicker via FRC and PWM. Clearly my brain and eyes just cannot tolerate it if it is too aggressive and too low frequency.
AshX
Post by AshX » 19 Feb 2026, 20:18
I tested a few displays and figured I’d share the results. Recorded at 240 fps slow motion on my iPhone 13. Warning: severe flicker on some of these.
Uncomfortable:
1. HP Omen Transcend 31.5” QD-OLED 4k: https://streamable.com/i1tl9e
2. 2019 iMac 21.5” 4K Retina: https://streamable.com/yp4oxa
3. Unknown TV: https://streamable.com/6zlj7z
https://streamable.com/wfuc90
Comfortable:
1. iPhone 13 on iOS 15: https://streamable.com/aetv2f
Unsure:
1. Pro Display XDR: https://streamable.com/ceudxy
2. Eizo CS2740: https://streamable.com/h6m7ne
Any conclusions to be drawn from this other than temporal dithering or really bad lower frequency flicker?
Post by Chief Blur Buster » 19 Feb 2026, 21:51
Unsure at this time.
I would get more useful data with custom shutter speeds than unknown-shutter on 240fps video.
If you have a phone with 1000fps (e.g. Samsung Galaxy Super Slo Mo)
... Or if you can use a third party app (not apple iPhone camera app or google camera app) to force a ultra short shutter speed (60fps video with 1/1000sec shutter is more useful than 240fps video at unknown shutter speed), maybe more data can be derived. Run the video long enough (record for a minute)
(Reason: to allow enough phase drift between PWM frequency and the camera shutter frame rate (the short shutter speed of 1ms will show behaviors eventually somewhere along the video file temporal axis).
No guarantee this will pick up more data, just that faster-than-1/240sec shutter, will reveal more information on certain attributes.
AshX
Post by AshX » 24 Mar 2026, 19:30
Latest update.
I ended up selling the 13” M2 MacBook Pro Touchbar and picked up a new MacBook Neo. I tested it in store and didn’t get any of the eye focusing problems. I could not look at any of the new M5 MacBooks or the new Studio Displays as they immediately caused my left eye to close. The glossy iMac M4 was the only one I could look at.
I’ve owned the Neo for about a week. According to NoteBookCheck’s review the Neo uses temporal dithering. It also apparently uses PWM, according to other sources. It is an sRGB 218 PPI panel with the ability to reach 1.07 billion colors.
I’ve only been able to make the Neo usable for extended periods of time by calibrating the color profile to a D55 white point and putting Night Shift on maximum. Using Stillcolor to disable GPU dithering and disabling font smoothing helps to make text legible without my eyes refocusing all the time. I’ve also disabled “dim display while on battery power” and “automatically adjust brightness” which seems to have helped stabilize the backlight somewhat. The display gets uncomfortable below 40% brightness or so.
If I don’t have Night Shift on I immediately start to get symptoms of a seizure aura. This display does not have True Tone. I do not know if it uses a standard YAG phosphor W-LED backlight or KSF (PFS). It is not a wide color display.
My friend lent me an Eizo CS2740. Eizo’s product manager confirmed to me it is true 10-bit and does not use FRC or PWM. Immediately upon connecting both the MacBook Neo and a Dell Latitude 5300 running Windows 11, I get incredibly severe seizure aura symptoms. I even get milder versions of these symptoms when turning the display on without a device connected with the Eizo logo bouncing around a black screen. I connected both devices via USB-C. I wrote to Eizo asking what backlight type they use.
So perhaps KSF is a trigger as is blue light. What is odd is my iPhone 13 OLED doesn’t need any special settings. I held it side by side by MacBook Neo laptop and the iPhone was much more blue compared to the Neo with maximum Night Shift settings, yet the Neo was much more uncomfortable.
Is it true OLED has 30% as much blue light as W-LED? I don’t understand this.
