Does CRU custom res introduce input lag?
daemonjax
Re: Does CRU custom res introduce input lag?
Post by daemonjax » 28 Jun 2025, 19:06
JimCarry wrote: ↑
28 Jun 2025, 19:01
you are funny do you play cs2?
No, but if I did, and wanted to play it at 640x480 @ exactly 240hz for some reason, then I'd make a custom res at native res @ 240hz and use integer scaling from 640x480. Boom. Done.
In a fps shooter, you can only use pixel perfect resolution scaling, otherwise you may end up aiming at pixels that don't exist.
JimCarry
Post by JimCarry » 28 Jun 2025, 19:08
daemonjax wrote: ↑
28 Jun 2025, 19:06
JimCarry wrote: ↑
28 Jun 2025, 19:01
ok so if i want monitor scaling and i play 1920x1080 how to do it ? and how to use "integer scaling " on amd ?
daemonjax
Post by daemonjax » 28 Jun 2025, 19:14
JimCarry wrote: ↑
28 Jun 2025, 19:08
I don't know the exact steps since I have an nvidia card, but...
I would check for something like "integer scaling" under something like "scaling methods" where you can change your resolution from a dropdown list in your AMD control panel software... maybe it's called adrenaline these days.
It's super easy to do within nvcp for nvidia cards.
JimCarry
Post by JimCarry » 28 Jun 2025, 19:17
daemonjax wrote: ↑
28 Jun 2025, 18:55
That gpu can do integer scaling.
yes you are 100% right,but as you said you need gpu scaling enabled first in order to use integer scaling.
daemonjax
Post by daemonjax » 28 Jun 2025, 19:52
You're really making this way more difficult than it needs to be. You tried nothing, and you're all out of ideas.
Enable gpu scaling first. You have it disabled.
Look, I'm not your personal google machine. You're on your own now.
JimCarry
Post by JimCarry » 28 Jun 2025, 21:29
daemonjax wrote: ↑
28 Jun 2025, 19:52
how da fak i must know that this f@cking option will be usable after i enable gpu scaling ?,after i did what you said now both are on.now what ?
