Linux thread
[email protected]
Re: Linux thread
Post by [email protected] » 29 Oct 2025, 02:58
agendarsky wrote: ↑
28 Oct 2025, 10:48
well its in the code :D .
Setup Question = Connection Type
use scewin to do that
There is no entry like this for AsRock PG Lighning X670E :(
agendarsky
Re: Linux thread
Post by agendarsky » 29 Oct 2025, 03:01
yea that sucks , try to find every hot-plug in your dump and disable it, then u can check with live usb and command i provided , if u dont want to install linux
[email protected]
Re: Linux thread
Post by [email protected] » 31 Oct 2025, 06:28
I finally found this setting:
Setup Question = Discrete GPU Hotplug Mode
Token =3E // Do NOT change this line
Offset =22
Width =01
Options =[00]Basic Mode // Move "*" to the desired Option
*[01]Enhanced Mode
[02]Non-Hotplug Mode
But i can´t change it because import doesn´t work and i can´t find the setting in BIOS to disable the BIOS Lock..... :x
Does anyone know how to disable the BIOS Lock on a AsRock X670E PG Lightning?
Update:
ASRock
If you have an ASRock motherboard (Z590+, B560+, H510+ | X670+, B650+, A620+) follow the steps below. These motherboards require an additional workaround as they password protect the various runtime variables.
Go to Setup > Advanced > UEFI Variables Protection section of your BIOS
Disable Password protection of Runtime Variables
To access this setting, you need to mod your BIOS with UEFI Editor. ASRock's BIOS has 2 Advanced forms so you need to do a Menu swap in order to gain access to the setting.
nooo waaay.....
kriegsnake
Re: Linux thread
Post by kriegsnake » 31 Oct 2025, 17:39
[email protected] wrote: ↑
31 Oct 2025, 06:28
Offset =22
Width =01
*[01]Enhanced Mode
Same here Asus Rog B550-f :
Help String = Select Discrete GPU Hotplug Mode - HotplugEnhanced or HotplugBasic
Token =2B // Do NOT change this line
Offset =2B
Width =01
*[01]Enhanced Mode
I've changed it to Basic mode, but there is no difference, don't bother with it.
