Page 3 of 6
Re: Fixed the desync/input lag issue.
Posted: 28 Sep 2026, 16:42
by codetechceo
Shade7 wrote: ↑
28 Sep 2026, 13:43
codetechceo wrote: ↑
28 Sep 2026, 07:16
3 days pc still stable, it smoother than ever, before all that i had 3 different setup and laptop with same problems, now its all gone , thanks
So what exactly did you do?
Configure Secure boot the way he recommended?
Use default RAM speeds (XMP/DOCP OFF)?
All of the above?
Complete first five steps. Thats it
Posted: 28 Sep 2026, 20:23
by Shade7
28 Sep 2026, 16:42
Shade7 wrote: ↑
28 Sep 2026, 13:43
28 Sep 2026, 07:16
All of the above?
What do you think (out of those five steps) was likely to make the most significant difference in your case?
Posted: 29 Sep 2026, 05:08
by codetechceo
Shade7 wrote: ↑
28 Sep 2026, 20:23
28 Sep 2026, 16:42
Shade7 wrote: ↑
28 Sep 2026, 13:43
28 Sep 2026, 07:16
All of the above?
i think secure boot settings before installation and driver installation order
Posted: 29 Sep 2026, 07:20
by cursedgamer12
it will all come back eventually. if you have the existing ghost lag there is no getting rid of it Period
Posted: 29 Sep 2026, 10:25
by codetechceo
cursedgamer12 wrote: ↑
29 Sep 2026, 07:20
it will all come back eventually. if you have the existing ghost lag problem, there is no getting rid of it Period
maybe but for now its best state i ever see on my pc
Posted: 29 Sep 2026, 23:17
by naporitan
A bit of information about overclocking RAM: when you overclock RAM, you are guaranteed to get error correction, and the more you overclock, the more error corrections you get.
When you buy RAM, you get a guaranteed stable JEDEC profile, and if you go beyond this profile, you get error correction. For this reason, you won’t see any errors in stress tests. Error correction can occur on the FCLK side and also on the RAM side itself, since DDR5 has On Die ECC technology — this is a memory error‑correction technology built into each DDR5 standard chip.
When overclocking RAM, there is no error correction level indicator, but if you use the JEDEC profile, you get 0% error correction.
An interesting development at the time of the Ryzen 7000 launch was the following official announcements:
AMD confirmed that the Ryzen 7000 series of processors officially supports DDR5-5200 memory for single-rank and dual-rank configurations with one DIMM per channel. When using two DIMMs per channel, the officially supported speed drops to 3,600 MT/s.
Posted: 30 Sep 2026, 01:42
by kvc
Disabling EXPO and using JEDEC fixed the input lag issue for me. Thank you :)
Posted: 30 Sep 2026, 01:50
by qbBA
When are you going to ban that kid?
Posted: 30 Sep 2026, 08:32
by RealNC
qbBA wrote: ↑
30 Sep 2026, 01:50
No one is forcing you to read his thread/
Posted: 30 Sep 2026, 08:36
by flow
qbBA wrote: ↑
30 Sep 2026, 01:50
I don't want to be that guy but, these screenshots are from official websites. Why are we hating on that?
