Install Help [G-SYNC Upgrade Kit]
- Solar
Re: Install Help [G-SYNC Upgrade Kit]
PoWn3d, i also have gtx 670 sli, but i didn't experience that issue. If you haven't already try only connecting the G-Sync monitor. When i started mine up it was automatically in G-Sync mode, and that may have something to do with it.
From the screenshot, it looks like it's only inside the windows (GPU rendering activities). Chrome is GPU accelerated, so that squarely places the blame on your GPU, and not the G-SYNC monitor.PoWn3d_0704 wrote:Okay, here is a GREAT kicker for everyone. Getting my GSync installed now and My monitors are going crazy...
--> Have you upgraded your graphics drivers? G-SYNC requires the latest beta drivers at the moment.
--> Try connecting only the G-SYNC monitor, as the primary monitor.
PoWn3d_0704
A restart seemed to fix the issue. It seemed to start when I had SLI disabled (just on boot up), and then I manually turned it on.
Rebooted and the SLI was enabled by default this time, so no weird artifacts.
However, I now have THIS problem...
I'm on driver 332.21 which is all I'm seeing in Beta or WHQL drivers.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
Try a fully clean driver reinstall. I know that worked for at least one person.
PoWn3d_0704
Seems to have worked for now. Just trying to make sure that I have in game settings set correctly. Setting GSYNC on in the nVidia Control Panel should override everything and force GSync, right? What about if I turn on ULMB? Does it just bypass Gysnc and go Vsync off?
- Solar
As of right now you can't switch to ULMB if your running a game that's set to G-Sync in the control panel, it will automatically switch to G-Sync mode. Hopefully a future driver will add the ability to switch on the fly regardless of settings. There's also a setting in there called preferred refresh rate, if set to highest available you can't switch to ULMB since the refresh is at 144Hz.
Yes, you have to turn off G-SYNC in order to use ULMB in games.
It's a little inconvenient sometimes; hopefully utilities will come that makes it easy to switch between G-SYNC and ULMB.
PiERiT
Anything back from nvidia regarding my pictures on page 1?
Nealb90
I also am interested in the response from NVIDIA regarding the rainbow effect because this happens to me when I boot up some games. Also somebody mentioned a setting for preferred refresh rate. Is this the refresh rate setting in the Nvidia control panel or is there another setting to set the "preferred refresh rate"?
Can you record a video of the rainbow effect?Nealb90 wrote:I also am interested in the response from NVIDIA regarding the rainbow effect because this happens to me when I boot up some games. Also somebody mentioned a setting for preferred refresh rate. Is this the refresh rate setting in the Nvidia control panel or is there another setting to set the "preferred refresh rate"?
This will give NVIDIA something to look at.
