What has been the resolution? Is the problem the monitor? (I still have time to return it if it is) Or my hardware?
Consistent tearline at top of screen with G-sync [bug?]
headachebr
Re: Consistent tearline at top of screen with G-sync [bug?]
Sorry to revive this post but I'm seeing the same issue on my Acer XB270HU. I'm using two GTX 680s and drivver 352.86
- nimbulan
When I upgraded to a GTX 970 the problem disappeared. It seemed to be a problem with my old GTX 760, rather than the drivers or monitor. I would suggest swapping your two cards to see if the problem lies with your current primary. I never did figure out what specifically caused the problem. I wouldn't worry about it though unless it's REALLY bothering you. I doubt the GPU manufacturer would accept that as a reason for an RMA.
headachebr
I was hoping that wasn't the resolution of the problem as the G-Sync technology was clearly made possible for Kepler cards...
Buying a newer GPU will make me spend more money and probably have a less performance than my current cards
I'll give it a try when I get home tonight to see if swapping the DP cable to another GPU fixes it, or swapping the actual cards.
*fingers crossed*
I can't imagine I'm the only one who has 680s and Gsync...
*fingers crossed*
- nimbulan
You're the first person I've found whose had the same problem as me, or at least the first person to have noticed it. My best guess is that it's a minor timing issue with the display output.
headachebr
I swapped the display port cable from one of the GPU and put on the other and that seemed to help a lot... I still see some kind of "line" at the top of the screen, but now it doesn't bother me that much.
Thank you for the help!
