[FIXED] "ZOWIE" monitor not compatible with Strobe Utility
OKennobi
Re: "ZOWIE" monitor not compatible with Strobe Utility
Post by OKennobi » 15 Mar 2017, 00:12
croaky wrote:
OKennobi wrote:Guys i hat same problem with v4 and i menage to get the Utility work only by this way (try it so much more)
I just did prohibition on windows to update the driver i think this is not problem only when we use the Utility when we not turn it back I Hope will work for u too Uninstall this Monitor
Re: "ZOWIE" monitor and he will become Benq again. but if the drivers update is online it will update it back on.
I've got absolutly the same Problem im able to get it back to BenQ XL2411Z Driver but after secounds has gone it goes back to ZOWIE XL Driver.... I updated today my Firmware from V1 to V4
Here a picture https://www.dropbox.com/s/yogp305aqw3udhu/LOL.bmp?dl=0
Hello can you do this Image do this on win 8.1 but i think for 10 or 7 is somethink similar
Go on
My computer or This Pc
then go on Properties.
find Change Settings >>>> Hardware>>Device Installation Settings and do as i do on the picture next.
go in Device Manager, Uninstall the driver, but dont forget to mark "Delete the driver software for this Device" before Uninstall! it will get back again :D
After u do this the monitor will remain as Benq as it do for me all day no problems, but Display Driver does nor working properly which is fine by me.
cheers i hope this will work for someone soryy for the bad guide but im in little hurry.
croaky
Post by croaky » 15 Mar 2017, 11:06
Thank You for your Post but it still doesn't work for me :)
OKennobi
Post by OKennobi » 17 Mar 2017, 01:07
I don't know man for me is still showing like BenQ not ZOWIE when I did it, the first time did not work for me also I don't know why but when I double check it the driver was on ZOWIE again so I did it again don't know where I was wrong the first time, but on the second time it worked and still is working
Post by Chief Blur Buster » 17 Mar 2017, 11:16
Update, April 29th:
Finally got my renewed Comodo executable digital signing certificate.
Here you go, download Version 1.4 of Blur Busters Strobe Utility:
Webpage has also been updated at http://www.blurbusters.com/benq/strobe-utility/
Thread closed.
Please continue discussion in this new thread
Locked
