Page 3 of 3
Re: 1000 Hz: The Journey Begins
Posted: 12 May 2021, 03:52
by MCLV
Well, if you have insider information that displays with such specific refresh rates are planned then you can ask your source to give you an indication of timeline as well ;)
Otherwise, you can have a look at my plot but there is no guarantee that displays with such these refresh rates will even exist. Or if they do, they might not be released in consecutive order.
Posted: 12 May 2021, 06:27
by Kamen Rider Blade
MCLV wrote: ↑
12 May 2021, 03:52
I think we're at the beginning of a diminishing return curve and that the rise to 1,000 Hz is going to take longer than expected for many reasons out of our control.
Posted: 12 May 2021, 07:18
by MCLV
I don't think that we are near the limit for motion blur in sample-and-hold displays but I also expect that journey to 1000 Hz might take long time. I expect that strobing/black frame insertion will become more widespread and the go-to solution for gaming. This is because generally reaching 1000 fps in majority of games is harder than reaching 200-400 fps and using strobing to reduce persistence to <1 ms levels. Second option gives you higher quality of in-game graphics with very reasonable input lag while partially suppressing artifacts connected with strobing at lower framerates. But let's see what happens and which solution gets mainstream acceptance.
Posted: 17 May 2021, 16:14
https://arstechnica.com/gadgets/2021/05 ... ra-sensor/
The display is a Sharp-made OLED with a whopping 240 Hz refresh rate. Sharp has made 240 Hz displays before, but it says this one is the "world's first" display to have a dynamic refresh rate that goes from 1 Hz to 240 Hz, depending on the content.
Why can't we get this type of VRR on Desktop monitors?
I would love for 1-240 Hz VRR window.
Posted: 24 May 2021, 17:53
Kamen Rider Blade wrote: ↑
17 May 2021, 16:14
It might be doing that via LFC-style algorithms (Low Frame Rate Compensation).
On LCDs, the use of LFC already does this, and LFC can produce superior quality to native Hz.
Because low native Hz can have degraded quality, LFC prevents flicker issues, gamma issues, less varying ghosting-vs-corona issues, and inversion artifacts. Even OLED is not immune; OLED can get gamma issues at low vs high refresh rates, while LCDs can have inversion flicker effects.
With wide VRR ranges (240Hz or 360Hz), LFC stutter is actually nonexistent, and LFC produces some image quality improvements. Repeating 24Hz 24 times to generate 1Hz usually produces superior 1Hz refresh cycles, without the screen-memory-decay-effect flickering.
So that means 1fps=1Hz, LFC can produce superior image quality sometimes than native 1Hz, depending on the screen technology and how it handles low native refresh rates without flicker/gamma/inversion/ghosting artifacts. But at the end of the day, who wants to play a slide show of 1 frames per second, anyway? :D
Posted: 20 Feb 2024, 11:03
by Supermodel_Evelynn
What I don't get is Nvidia has a 1700 HZ screen in their lab they have had it for 10 years now
So why then are we still at 500 HZ like 10 years later?
Posted: 21 Feb 2024, 08:35
by Cwuster12
Supermodel_Evelynn wrote: ↑
20 Feb 2024, 11:03
This is an experimental laboratory display. And as I see from the video, they move the screen on rails and thus it creates the effect of movement on the screen, but high Hertz + high fps + probably 1080p means that there is so little motion blur (probably at a speed of 0.5-0.25 seconds for horizontal movement ) that there are no more than 4 blurry pixels
Posted: 03 Sep 2025, 13:47
by Undisplayed
Now that we're getting ever closer to the goal, where should the journey end, or at least take a short break?
I think 1200 Hz could be a good rate to reach because it contains many of the frame rates relevant to video as factors (25/50 are PAL):
Factors of 960: 2, 3, 4, 5, 6, 8, 10, 12, 15, 16, 20, 24, 30, 32, 40, 48, 60, 64, 80, 96, 120, 160, 192, 240, 320, 480.
Factors of 1000: 2, 4, 5, 8, 10, 20, 25, 40, 50, 100, 125, 200, 250, 500.
Factors of 1080: 2, 3, 4, 5, 6, 8, 9, 10, 12, 15, 18, 20, 24, 27, 30, 36, 40, 45, 54, 60, 72, 90, 108, 120, 135, 180, 216, 270, 360, 540.
Factors of 1200: 2, 3, 4, 5, 6, 8, 10, 12, 15, 16, 20, 24, 25, 30, 40, 48, 50, 60, 75, 80, 100, 120, 150, 200, 240, 300, 400, 600.
Posted: 08 Sep 2025, 19:25
Undisplayed wrote: ↑
03 Sep 2025, 13:47
Yes -- however, there's something even better:
Why do we need integer divisibility when we can use framerateless video containers?
Let's Go Big or Go Home with Framerateless Video Format Concepts
You can output 23.976fps, 24fps, 59.94fps, 60fps, 77fps, 120fps, 1000fps, 999fps, or whatever framerate you want.
All export framerates are all native framerates from a hypothetical framerateless master file format. No speedups/slowdowns, no audio distortions.
