Because I wouldn't be utilizing what I paid for...RealNC wrote:I don't see how what you paid for affects what you get in any waybesweeet wrote:I opted to just deal with the limit. I paid for 155Hz and shouldn't have to decrease my frame rate.
Dell S2719DGF - I don't think G-SYNC CM is working...
besweeet
Re: Dell S2719DGF - I don't think G-SYNC CM is working...
crudolol
Hi, I have a question that might be stupid.
I have a gtx 970 and I'm thinking about buying the Dell S2719DGF.
Will I be able to use ULMB(or what ever the alternative is for this monitor) and Gsync with this Monitor?
I normaly only play Dota2 and my FPS are fixed around 80 FPS.
- RealNC
No. This is a freesync monitor. To use use freesync on an nvidia GPU, you need a 10xx nvidia card or newer. The 970 does not support it. Also, this monitor doesn't have any motion blur reduction mode.crudolol wrote:I have a gtx 970 and I'm thinking about buying the Dell S2719DGF.
crudolol
ooh thanks a lot. was about to order it.RealNC wrote:No. This is a freesync monitor. To use use freesync on an nvidia GPU, you need a 10xx nvidia card or newer. The 970 does not support it. Also, this monitor doesn't have any motion blur reduction mode.crudolol wrote:I have a gtx 970 and I'm thinking about buying the Dell S2719DGF.
so maybe the s2716DG sohuld be my way to go. thanks
- RealNC
Yes, the S2716DG (or S2716DGR, it's the same) will work in either g-sync or ULMB mode on a 970 just fine.
crudolol
RealNC wrote:Yes, the S2716DG (or S2716DGR, it's the same) will work in either g-sync or ULMB mode on a 970 just fine.
I know it might be not the right spot - but if I can get the S2716DG for 400€ - do you think that would be worth it or is there another one you would recommend?
I know its a bit off-topic
